The Bicycling Thread - Page 38 - Beyond.ca - Car Forums
Page 38 of 94 FirstFirst ... 28 37 38 39 48 ... LastLast
Results 741 to 760 of 1862
Thread: The Bicycling Thread
  1. #741
    (maah raahde)
    recommendations from MEC?
    I'm using the Cascadia II for hybrids and love them. Not sure how wide your winter tires are, but these are wide enough for 35c.
    https://www.mec.ca/en/product/5024-7...Hybrid-Fenders
    I went riding through big puddles for the fun of it yesterday just cause I could
  2. #742
    '14 Taco
    You get them to fit with discs?
  3. #743
    (maah raahde)
    Yup, it comes with spacers so that the arms clear the disc brakes.
  4. #744
    Jul 2006
    I have a ton of these as well. They work better than no fenders but don't work with every saddle. The stock saddle on my JTS doesn't work well because once you fold it away it doesn't return to the original shape.
  5. #745
    Oct 2003
    Has anyone used green slime in their inner tubes to prevent flats? I've had some problems with tiny leaks that don't show up unless the tire is pressurized (above 30psi) but when the tube is off the rim, I can't get the pressure up that high, it just blows up like a ballon. I had a mystery hole in one tube and replaced it with a new one and I'm still having leaks. They're a bit of a pain to get on and off (no quick release and the marathons have a very tight bead). just wondering if sliming it would be a good solution
    heloc that shit
  6. #746
    Dec 2008
    Quote Originally Posted by lint View Post
    I personally wouldn’t. If you get any of that crap in your pump it’ll probably ruin it.
    How fast is the leak? I think it’s natural for higher psi tires to lose pressure over time. I run my hybrid at 85psi and pump them up once a week.
    I use the Portland design origami fenders. Quick to put on and off, light and don’t have slush build up problems
  7. #747
    Sep 2002
    CGY
    Cayman, F150, Crosstour
    It will work....but, mixed results in tubes. In tubes the hole is so elastic (no fibres) it will easily change shape and not allow the slime to seal.
    So the small plug that forms will not stay in place and sealant will end up between the tube and tire. Especially an issue with higher PSI applications.
    I would convert to tubeless with a Stans setup or similar if you're worried about flats.
  8. #748
    Oct 2003
    Alright, I'll just try to find the hole in this tube and patch it. Just irks me that this is a brand new tube and I have a leak. It's not high pressure, dropping from 60 to 20psi in a couple of days.
    heloc that shit
  9. #749
    Dec 2008
    Could be the valve too if you can’t find a leak. I don’t think quality control is very high on tubes
  10. #750
    Oct 2003
    Fugh, never thought about that. I'll try to tighten the valve core. Thanks
    heloc that shit
  11. #751
    Sep 2002
    CGY
    MEC tubes? The quality seems to come and go. I've had more consistent luck with the continental tubes, and not that much more per tube.
    Soak it in a tub, or spray with soapy water to find the leak. Throw a real patch/epoxy on, not those quick stick on ones.
  12. #752
    Oct 2003
    Quote Originally Posted by CLiVE View Post
    Nope. From Bow Cycle. Haven't checked this new tube yet, but the last tube, couldn't not find the leak with soapy water, no bubbles, no sounds when it was off the rim. Could only get the pressure up to about 15psi, and the tube was already triple the size. But when on the rim under a tire and pressurized to 60psi, bubbles. I just tossed that one.
    heloc that shit
  13. #753
    Hybrid
    Snowfall warning in effect for Calgary
    15-25cm tonight through Saturday
    http://weather.gc.ca/warnings/report_e.html?ab12
    Who's gonna tough it out?
  14. #754
    (maah raahde)
    Just out of curiosity, are the tubes Presta or Schrader valves?
    Quote Originally Posted by Strider View Post
    Just swapped in my studded tires, put in my fat ass gel saddle, and tuned the disc brakes tonight.
  15. #755
    '14 Taco
    Success! Plus my 'you're nuts' ratio went way up at the office today
  16. #756
    Sep 2002
    CGY
    Was a fat bike day for me. No problem.
  17. #757
    '14 Taco
    What is your guys temperature cutoff for a 'fuk it, this aint happening'?
  18. #758
    -15 for me
  19. #759
    (maah raahde)
    On days like today when the snow is still really loose, I can totally see why people ride fat bikes. It would be so fun to just go plowing through the snow.
    For me, -30'ish with windchill. I find as long as my feet and hands are warm, I can deal with the cold.
  20. #760
    '14 Taco
    ya seemed to have nailed todays layer as wasnt cold at all, just curious how far i can go.. god damn its slow on studs though!
  1. Ford Trucks Thread WAS:EcoBoost Thread
    By freshprince1 in forum Trucks, 4x4 and Offroading Zone
    Latest Threads: Today, 11:43 AM
  2. Replies: 87
  3. Utility Bicycling Thread
    By flipstah in forum Cycling
    Latest Threads: 04-05-2013, 09:49 AM
  4. Replies: 77
    Latest Threads: 09-23-2004, 11:57 AM
