Finally upgraded my home wifi to something that works - managed wifi review - Page 31 - Beyond.ca - Car Forums
Page 31 of 51 FirstFirst ... 21 30 31 32 41 ... LastLast
Results 601 to 620 of 1002
Thread: Finally upgraded my home wifi to something that works - managed wifi review
  1. #601
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    That's how I ran CAT6 to my outdoor AP. Just make sure you reseal it so shit doesn't get into your basement.
    Perfect, you just tucked it along the siding and stuff to where you need it? Obviously I'd be using outdoor rated cable.
  2. #602
    I buried it. Just used standard cable since it's buried and won't see UV haha.
    We'll see if it gets dug up and chewed up by animals. Heard wiring is tasty.
  3. #603
    Nov 2003
    So, it looks like there may be some fixes for the USW and UAP people with DHCP Issues, not a complete fix, but still nice.
    Im still having issues with my UAP-AC-PRO and the 2.4ghz Transmit Rate (Tx Retry/Dropped 91.7% / 0.0% on FW: 4.3.13.11253 )
    Another recent issue with their switches, is the new USW-Flex doesnt use LLDP so it cant negotate to receive PoE power above 15w, which means its useless unless you use an injector.
    Code:
    UAP/USW Firmware 4.3.17.11279
    Bugfixes
     [USW] Fix DHCP flooding between isolated ports.
     [USW] Fix DHCP packet inter-VLAN route loop by DHCP snooping.
    Improvements
     [UAP-G2] Improve Wireless Uplink stability on downlink.
     [UAP-G2] Increase authenticator log level, if debug logging is enabled.
     [USW] Improved server option checking of DHCP snooping.
     [USW] Align the Port ID info in LLDP.
  4. #604
    Quote Originally Posted by Alterac View Post
    Code:
    Bugfixes
    Improvements
    Wonder if that broadcast storm was actually DHCP flooding. I never wiresharked it, just saw the broadcasts.
    Funny that only the new adopters (me and GTS Jeff) saw it, and that the problem goes away by starting at an old firmware and upgrading back up lol. Just good to know I'm not on crack.
    edit - just an RC, not stable yet.
    edit 2 - reading the comments at the community, it doesn't fix the DHCP problem, and for some people, broadcast is completely broken so DHCP as well.
  5. #605
    Mar 2005
    Calgary/Alberta
    2022 X2M
    I wonder if I haven’t seen this because I have been on beta firmware since day 1. I am on 5.18, however that is the new hardware. I switched the the beta firmware back in November or December because it had a fix for the iOS wrong password garbage. I haven’t ever gotten on beta since then.
    Edit: checked some of the previous gen hardware and it’s on 4.4.51.5287926
    E .· ` ' / ·. F
    Your tears fuel me
  6. #606
    Looks like Unifi has 2 Wifi 6 AP's in EA now. Essentially a minor upgrade to the AC Lite and IW HD with Wifi 6 support. The Unifi 6 Lite is super cheap, 100 USD on the EA store though sold out.
    6 Lite is only 2X2 MIMO though so don't expect any speed increases from it, but the IW-6 is 4x4 MIMO.
    Will be getting the 4x4 MIMO 6 dome styles ( essentially whatever the Nano HD Wifi 6's end up being ) whenever they come out of EA, but encouraging to see they are out in the wild being tested at least.
  7. #607
    Okotoks North
    I will implement unifi WiFi 6 APs on my network once WiFi 7 devices start coming out since some of the benefits require all devices in range of the AP to also be WiFi 6.
    WiFi 6E is nice though with the 6Ghz spectrum.
    On a side note, funny how they switched to the number system to simplify wifi naming, and they've already fucked it up by introducing 6E.
  8. #608
    Not Aspen
    Two from Freemont
    Corona must be tapering off. Got my shipping notification yesterday.
  9. #609
    6 Lite will still do 1.2gbps on 5ghz, so a bit of an improvement. My timing of upgrading to unifi was perfect. Fuck sake haha. Guess I'll just skip this and wait till the new spectrum APs come out.
  10. #610
    Should have taken me up on my offer of borrowing lites I had sitting on the shelf unused lol
  11. #611
    Not Aspen
    Two from Freemont
    I've got my UDM Pro up and running. What's the word on Migration? backup file or start from scratch?
    My Controller version is 5.13.29
    UDM Pro is showing version 5.13.30
    Did a manual check on both and both showing as latest version.
  12. #612
    As long as your old controller isn’t newer than the UDM you will be fine. I did it with a backup file, took a little bit but worked well.
  13. #613
    Aug 2006
    calgary/AB
    95B
    Yes that's what I did. Took the latest back up from the old controller and then restored it on the UDM .
  14. #614
    Not Aspen
    Two from Freemont
    Are you guys taking advantage of the SFP ports to connect the UDM to your switches? Fiber seems like overkill for a 10cm run.
  15. #615
    My ONT is still 40 feet away from my UDM. Trying to figure that out. I’ve only got ~4 feet of excess fibre spooled up and having found many good answers as you how to patch the fibre over to my rack.
    I would really like to figure out how to get that fibre over so I can keep my entire network on a UPS so I don’t lose any downtime during power bumps.
    Kind of defeats the purpose of my WAN isn’t on the UPS.
  16. #616
    Not Aspen
    Two from Freemont
    Looks like I need this thing. https://store.ui.com/collections/uni...ac-patch-cable
    Canada store doesn't have it and Canadian retailers are gouging... $16USD != $50CAD even with shipping and tax.
  17. #617
    Aug 2006
    calgary/AB
    95B
    How are you guys connecting to ONT? Assuming that you have Optik TV setup.
    I tried to convince Telus to open up another port on the ONT and no luck so far.
  18. #618
    I feel like these aren’t proprietary cables.
    That said, yes one end of SFP+ goes into the UDM. Where are you plugging the other end into?
    - - - Updated - - -
    Quote Originally Posted by ganesh View Post
    Currently I am ONT-Telus Gateway- bridged port to UDM Pro
    I use the other ports on teluses gateway for Optik.
  19. #619
    Aug 2006
    calgary/AB
    95B
    - - - Updated - - -
    Interesting. I guess I will call again and see if they are going to allow me to do that.
    So far the answer I got was unless it is a multi dwelling setup they will not allow that.
  20. #620
    Not Aspen
    Two from Freemont
    USW-16-POE Gen2
    which I have now discovered is SFP, not SFP+.
  1. Finally upgraded to a dual band DD-WRT router
    By WhippWhapp in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-04-2017, 10:49 AM
  2. FS: HP Procurve 1800-24G managed network switch
    By Smokem in forum Computer Hardware & Peripherals
    Latest Threads: 03-14-2012, 06:09 PM
  3. Managed Funds
    By cidley69 in forum Real Estate / Finance
    Latest Threads: 02-23-2012, 08:44 AM
  4. Something, something, something, Dark side
    By Tik-Tok in forum Entertainment
    Latest Threads: 12-27-2009, 08:15 PM
  5. FS: Netgear FSM726S L2 managed Switch
    By 02WhiteWs6 in forum Computer Hardware & Peripherals
    Latest Threads: 11-16-2007, 05:03 PM
