Finally upgraded my home wifi to something that works - managed wifi review - Page 41 - Beyond.ca - Car Forums
Page 41 of 51 FirstFirst ... 31 40 41 42 ... LastLast
Results 801 to 820 of 1002
Thread: Finally upgraded my home wifi to something that works - managed wifi review
  1. #801
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    Got my Purefibre installed. I had Shaw Bluecurve TV working through my router before.
    Plugged the Optik box into my network, was able to get a TV signal for about 20 seconds before it would die out.
    Followed this guide and was able to get it working stable.
    Now to figure out how to get failover working....
  2. #802
    Aug 2006
    calgary/AB
    95B
    So I did a Firmware update last night and now my whole network is down.
    After the FW update all the Devices ( Switch and AP's ) got disconnected.
    Did a factory reset on the UDM Pro and Switch.
    Switch is not at all showing up on the Device list. It looks like the switch is not even getting a IP address. Switch is on Solid White LED.
    From what I can see it looks like no activity at all on the ports of the switch (No LED). Looks like the FW update may have bricked the Switch??
    Has any one experienced this type of an issue?
  3. #803
    I've not had that with the unifi switches - but your next step is to paper clip it, basically - and then restore the settings. I've also found with some UNIFI hardware, the rest process takes 15 seconds, not 5 as they commonly advertise.
  4. #804
    Aug 2006
    calgary/AB
    95B
    Done that multiple times and no success at all. - With the full factory reset only I was able to get to Solid white LED. However it looks like it is not obtaining a IP address so I can't even SSH into it.
  5. #805
    06 S2000
    I'll take the switch off your hands.
    My car sounds like shit.
  6. #806
    Aug 2006
    calgary/AB
    95B
    Well if I am out of options and decides to replace it I will let you know.
    I might try the log in using the Console.
  7. #807
    Quote Originally Posted by ganesh View Post
    several options - disconnect from network and setup a workstation and the switch on the same subnet and try to access 192.168.1.1 (I think thats the default IP??) ie try to ping or SSH to it directly.
    Otherwise you can try to see if it shows up using a UNIFI discovery tool , https://chrome.google.com/webstore/d...emopofig?hl=en
    or use something like nmap (or better) to find the address of the switch
    but if this is a several years-old unit, this usually indicates an issue - and you are likely looking at replacement
  8. #808
    Aug 2006
    calgary/AB
    95B
    I will give this a try.
    Switch is about 3 Years old. I am slowly leaning towards replacing it. I need the stable network before the work week.
    Thanks for your help.
    I sent you a PM.
  9. #809
    Tried the Unifi communities?
    We are just complete jokers on here compared to those guys.
  10. #810
    Aug 2006
    calgary/AB
    95B
    I didn't try the unifi community. However I logged a ticket with Unifi it is a completely a joke. For the last 24 hours they are asking the same question do you have a IP address , what is your LED color, Can you do a hard reset.....etc.
  11. #811
    06 S2000
    Try r/unifi, r/ubiquity
    I think my USG is on the way out as well, might mean an upgrade to a UDM (not pro) in the near-ish future).
  12. #812
    Not Aspen
    Two from Freemont
    What would you guys do?
    The setup plan for the new house is to have 15 POE devices. Current switch is USW-16-POE that has 8 POE+at ports.
    Do I just grab a USW-Lite-16-POE that gives me another 8 ports, but is not rack mountable? Grab another USW-16-POE?
    Or grab a USB-24-POE and sell the USW-16-POE? What's a used USW-16-POE worth?
  13. #813
    06 S2000
    Not sure what the switch is worth, but potentially interested.
    Had my USG3 die last week, ran out to Memex to have them pricematch their last UDM-base. It doesn't like when I touch the subnets, refuses to hand out IPs to wired devices if I don't leave LAN on default subnet/DHCP settings, so I had to re-ip my entire network, but it's nice having each switch plug into the UDM directly, instead of daisy chaining a bunch of 8/5/6 port unmanaged switches. Also nice having a 3rd AP, so I could move the basement one up to the main floor, and have one per floor.
    USG kept hiccuping, and would need a power cycle for the internet to come back. Until it power cycled and the internet never came back. Nothing like losing internet mid team-meeting, and having to call it for the day.
  14. #814
    Not Aspen
    Two from Freemont
    Anyone try https://design.ui.com/ ?
    Seems to work nice. Gives you a bill of materials and how much cable you need if you setup the scale properly.
    Name:  Design_Center_03_26_21 (1)_Page_8.jpg
    Give camera coverage too.
    Name:  Design_Center_03_26_21 (1)_Page_9.jpg
  15. #815
    I used the old one that was built into the app. Cool thing with that one is you could walk around (had to tell it where you were for discrete readings) and get real signal readings from your phone for your wifi coverage which it would display on the map.
  16. #816
    Not Aspen
    Two from Freemont
    Like a cheap Ekahau. Now I just have to decide if I want to run all the cable myself or pay someone. It says I need 600m of cable.
  17. #817
    600M sounds kindof excessive to me. You start bordering on putting in intermediate switch gear at that point.
  18. #818
    Not Aspen
    Two from Freemont
    yeah, agree. I'm going to measure it the old fashion way.
  19. #819
    Mar 2005
    Calgary/Alberta
    2022 X2M
    If anyone needs a cloud key V2 or a FlexHD let me know. I always forget I have extras.
    E .· ` ' / ·. F
    Your tears fuel me
  20. #820
    Aug 2006
    calgary/AB
    95B
    If anyone is looking for In Wall HD AP's let me know. I have two of them they are EOL.
  1. Finally upgraded to a dual band DD-WRT router
    By WhippWhapp in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-04-2017, 10:49 AM
  2. FS: HP Procurve 1800-24G managed network switch
    By Smokem in forum Computer Hardware & Peripherals
    Latest Threads: 03-14-2012, 06:09 PM
  3. Managed Funds
    By cidley69 in forum Real Estate / Finance
    Latest Threads: 02-23-2012, 08:44 AM
  4. Something, something, something, Dark side
    By Tik-Tok in forum Entertainment
    Latest Threads: 12-27-2009, 08:15 PM
  5. FS: Netgear FSM726S L2 managed Switch
    By 02WhiteWs6 in forum Computer Hardware & Peripherals
    Latest Threads: 11-16-2007, 05:03 PM
