50% of the Canadian Rig fleet active! January 2017 - Fuck Yeah - Page 12 - Beyond.ca - Car Forums
Page 12 of 17 FirstFirst ... 2 11 12 13 ... LastLast
Results 221 to 240 of 324
Thread: 50% of the Canadian Rig fleet active! January 2017 - Fuck Yeah
  1. #221
    Really can't unpack that from this data. But much less than 50%. Maybe less than 20% I'd guess. Expiries in the US aren't a big deal right now because companies have been drilling hard for years.
    The note on expiries is not true at all. In heavily developed areas like the Bakken this may be true, but a lot of companies in Texas/OK are going to struggle with acreage retention. There are 2 problems for companies on acreage retention.
    1. There is a lot of land in “core” areas being held by old vertical production that is will be negative LLI at this point. Companies will need to keep producing at a loss to hold acreage - companies were producing at losses on old verticals at $50 oil so it will be even worse now. With every company cutting costs it will be interesting to see how they keep fields running with negative LLI’s. Typically when wells go down a company has 60-90 days to turn them back on. 2 problems come up which are either the company decides to stop producing at a loss, or with companies reducing field staff they don’t properly report offline wells to the office & don’t get wells back online on time. On top of this, a lot of the old leases use the term “producing in commercial quantities” in regards to retention meaning that operators producing at a loss may also risk losing a lease if a landowner wanted to force the matter, however, The majority of private landowners typically aren’t sophisticated so this issue won’t be pushed.
    2. Acreage retention terms in new leases in TX/OK are absolutely horrible for companies. Typically you will only retain the “bench” you have drilled, and could typically have to drill 4-6 HZ’s to retain a bench in a standard section. An example of benches in Alberta is the Upper/Middle/Lower Motney...Under new TX/OK leases drilling the middle Montney would only let you retain the middle Motney while the upper and lower would expire. Companies typically claim they have 4 bench’s in the Wolfcamp formation meaning to hold the wolfcamp formation in a section a company would need to drill 16-24 wells. Companies hold all acreage under these newer leases typically through “continuous drilling clauses” which basically say you can hold the entirety of a lease if you continue to spud wells within a certain timeframe (90, 120, 150, 180 days), but if you ever miss that all rights under the leases not held terminate. Companies can’t afford to keep drilling at these price levels so there acreage will expire through walking away from a CDC.
    There is obviously a lot of variability when it comes to private leases but the long and short of it is that a lot of land will be expiring if prices remain depressed.
  2. #222
    North America dropped 88 rigs this week. Half Canada and half USA.
    What's the over/under for next week? I'm saying it'll be even more.
  3. #223
    May 2004
    Cayman
    I have been doing a daily rig report at work for the last 9 years and I don't recall ever seeing under 10 drilling. I assume that 5 or less will be a possibility.
  4. #224
    Jul 2011
    Ford F150
    From everyone I've talked to at drilling and directional companies, I can't believe we have as many as that right now.
  5. #225
    Fresh BH Rig count. Another 77 down. Canada down to 41, and the daily tracking from JWN shows even less than that.
    Name:  BH Rig Count 2020-04-03.PNG
    I'm personally bettering next week we will show a drop of OVER 100.
  6. #226
    Rigs not being laid down as fast as I predicted, but still pretty steady. Down to 512 for USA onshore.
    Name:  BH Rig Count 2020-04-17.PNG
  7. #227
    Down another 68 this week.
  8. #228
    Any ideas where the 26 Canadian rigs are? Who is still drilling?
  9. #229
    Can't speak to the completeness or how current this is, but here ya go: https://riggertalk.com/drilling_rigs.php
  10. #230
    Aug 2004
    N/A V8, TTV6, DOHC N/A V6
    Thanks for the info
    -H.P. Lovecraft
  11. #231
    Don't get too excited though about those rigs drilling in canada...take a look at what they are drilling for.
  12. #232
    May 2009
    Medicine Hat AB
    General Motors Competizione
    If they make use of my services I don't care what they drill for. Drill until you run out of pipe and then cement back to surface for all I care.
    2007 GMC 2500 Duramax
    1981 GMC C1500 454
  13. #233
    Yes I'm not sure what point you are making @bigboom . Alberta and BC are gas basins predominantly.
  14. #234
    Quote Originally Posted by SKR View Post
    And then pump an additional 100% excess cement just for good measure (and to keep me employed )
  15. #235
    The point is that most of the focus on rigs running right now is the glut of oil and why are companies still drilling, just wanted to point out that all these wells drilling in Canada are for gas not oil focused.
  16. #236
    True enough. Although the "legal" classification as a gas well doesn't mean they aren't producing light oil, or largely "gas liquids". And prices on those have gone down too.
  17. #237
    Yea mostly of those “gas wells” will IP30 nearly a thousand barrels a day of “condensate” before going through deep cut and dropping out another thousand barrels of NGLs with a solid C5+ component.
    Just like on the other side of the imaginary liquids line the “oil wells” are still producing millions of cubic feet per day of gas.
    Well license classifications are a joke, just a game for operators and the government to play to determine which disclosure regulations and royalty structures apply. You would be better to pay classification no mind.
  18. #238
    I'm too lazy to look up the price for every liquid product right now, but I assume most of them have gone way down too. And methane's been nearly zero in a local sense for years in NEBC
  19. #239
    Rig count update, 56 more laid down :
  20. #240
    May 2008
    Wildflower Ranch
    Neo-Liberal Anarchist Mobile
    I am encouraged that we are drilling for "Unknown" products. Let the drillers drill! FREEDOM!
  1. Mercedes big rig active braking system fails
    Latest Threads: 01-25-2013, 10:35 AM
  2. PIMPafied...Yeah, Yeah!!
    By EK 2.0 in forum General
    Latest Threads: 03-03-2006, 01:42 PM
  3. Fuck Yeah
    By Sacred in forum Subaru Owners Club
    Latest Threads: 12-25-2005, 06:27 PM
