Bike build and maintenance - Page 26 - Beyond.ca - Car Forums
Page 26 of 32 FirstFirst ... 16 25 26 27 ... LastLast
Results 501 to 520 of 632
Thread: Bike build and maintenance
  1. #501
    Jul 2008
    Transnistria
    Exploded.
    Quote Originally Posted by mazdavirgin View Post
    Something like these would likely fit in well with the style of your bike. No idea where to get these locally though... Also comes without the toe straps in a similar style.
    https://steel-vintage.com/kyokuto-top-run-pedals-detail
    I’m totally digging those
  2. #502
    Jul 2008
    Transnistria
    Exploded.
    I’m looking to restore a road bike and not sure where to go and get fixer upper on the cheap. Tons on Kijiji and FB but I have no idea on brands, what to look for, and the prices are all over the place: Nikishi, Miyata, Norco... $300?!
    But a Giant is 450$? No clue.
    Also there’s a women’s bike? Dafuq.
    Any tips on what to look for? Bikes are mind boggling.
    EDIT: Also anyone has a spare front v-brake set (I think that's what it's called) so I have a back up to my coaster brake?
  3. #503
    Quote Originally Posted by flipstah View Post
    I dont think your bike has V-brake bosses, you probably want to run a regular road caliper brake.
  4. #504
    Jul 2008
    Transnistria
    Exploded.
    Quote Originally Posted by bigboom View Post
    Oh okay, any recommendations? I'm definitely newbie when it comes to bicycles.
  5. #505
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Clean lines... you remove brakes, not add them... how fast do you honestly think you’re gonna go that you need more stopping power???
  6. #506
    You could probably get away with something cheap, just see if you can find a long reach caliper and check if your fork has a mounting hole for that kind of brake. The key will be the long reach because you look like you're running some pretty big tires.
  7. #507
    Oct 2009
    rally pig
    this, road caliper brakes will be too small as they are good only up to 700x28.
    maybe something like this?
    https://www.ebay.ca/itm/WEINMANN-VIN...S/293643983472
    you're best bet is to maybe go to The Bike Shop or Bike and Brew, they work on fixie bikes so they might be able to source you the right brake levers and calipers for you.
  8. #508
    Jul 2008
    Transnistria
    Exploded.
    Quote Originally Posted by ercchry View Post
    According to Strava, I average 13kph but got up to 30kph! :O
    Thanks @bigboom and @taemo
  9. #509
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    And on the brakeless fixed gear I average about 30km/h and hit over 50km/h...
  10. #510
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Its easier to just never KOM things so he can't take them from you
    Got one he can’t KOM...
    Lake access road at the cottage... need to shave 37 seconds off over 3.8kms... currently have 3rd all time
  11. #511
    @flipstah check out the Tektro r559, that should fit.
  12. #512
    May 2005
    Wankels!
    Looks like one you can't KOM either
  13. #513
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Quote Originally Posted by Penguin_Racecar View Post
    Oh, I’ve got a little more left... just paranoid of dropping my chain so was doing minimal shifts
  14. #514
    Jul 2008
    Transnistria
    Exploded.
    Aaaaaaayyyy good deal
    Norco Avanti SL
    Going to do a closer look later today but going to seek advice from the gurus on how to maintain this bad boy
    Edit: needs a tune up as the brakes don’t work well so new cables or tighten it up, new seat, bar tape, shorter quill stem because I’m stretching my arms to reach down but shifts pretty well. Is “quill length” the right term to use? I want a closer handlebar experience
    12 Speed with Suntour Seven, Dia Comp brakes...
Size:  196.1 KBName:  C9A91676-3ACE-4C16-9575-0EBBD6A45587.jpg
Size:  124.1 KBName:  781112CF-E88D-493B-8AC5-798E154C5EAE.jpg
  15. #515
    May 2005
    Wankels!
    "Special plain gauge", whatever that means.
  16. #516
    Jul 2008
    Transnistria
    Exploded.
    I have no idea lol but definitely not chro-moly and just another learner bike for me! @ercchry told me to turn it into a fixie
  17. #517
    Subaru Outback
    when I saw the Tange sticker I just assumed it was some old school badass chromoly.
  18. #518
    Jul 2008
    Transnistria
    Exploded.
    Quote Originally Posted by Pacman View Post
    Same and from what I read, the Avanti SL is chromoly but it said 'Hi Tensile' so I'll assume it's not chromoly.
  19. #519
    From my very limited knowledge in frame building chromoly and hi-tensile are very similar in terms of frame builds and were terms used interchangeably back in the day, they are still steel frames and need to be treated the same in terms of protection. You'll want to get some frame saver and make sure you treat the inside as well. In regards to the quill stem you just want to get a shorter stem length. Just measure the length of the stem from center of head tube to center of mounting bracket and then get a stem 10-20mm shorter then that.
    Special plain gauge probably means its a straight gauge steel and not butted...fancy marketing words
  20. #520
    Jul 2008
    Transnistria
    Exploded.
    In terms of bike mechanics, should I also try and move the saddle forward vs finding a shorter stem?
  1. Replies: 87
  2. Low maintenance, or maintenance free yard
    By z24_wheels in forum Home and Garden
    Latest Threads: 09-07-2017, 06:58 PM
  3. Got my bike - maintenance walkthrough?
    By woodywoodford in forum Cycling
    Latest Threads: 08-08-2014, 01:28 PM
  4. New Bike Maintenance
    By flipstah in forum Cycling
    Latest Threads: 05-19-2009, 10:10 AM
