Well i was replacing my strut mounts this weekend and all was going well. i got the struts out with little hassle (thnx jeff for pitching in) but the first thing i noticed was that i had a spring cracked at the base of the coils. well this is just no good, it cannot do. It turns out both front springs are cracked, boooo.
So anyways, new springs for me. Im not sure what yet but i have some thoughts. Back to the story, i pull out the spring compressor and get to taking the units apart. everything goes easy. when they are all apart i pull off the bump stops and notice there is almost 0 resistance in the shock. both front ones are completely done, im not sure how the car was driveable in this condition???
so i guess everything will be replace. i was kinda planning on replacing the whole deal anyways, but now it looks like i dont have much choice.
So here are my thoughts : no coilovers. dont care for hight ajustability or the freaken cost.
i can get springs made reasonably cheap, but i dont think there is much warrenty on that, but the reason for this would be to keep the overall stiffness down. more than stock, but this isnt a race car! now spring rate is my issue, i can find info on that, but i plan on a 30mm drop at most. The car may see some autocross use this summer. So here is the point of this post --- what shocks should i go with for my 16v VW Jetta?
-bilstein hd or something from their line. quality stuff i hear, but i dont know much about it.
-tokico blues. ummmm, ya i dont know
-no agx's for my vw i believe so no luck there
-koni yellow are more than i want to spend
-other??? im sure some of you folks would know some others
2nd part - with a 30mm drop do i need to look into shocks designed for shorter springs, or is that drop pretty negligable?
Thanks for making it all the way down to here. i appriciate it.
-boge make some average shocks that i have heard average things about
