Cisco Profile Dual 52 w/ Cisco C60 Telepresence Codec and PrecisionHD PTZ Camera
Price: $1800obo
System in Located in Didsbury, AB.
System Includes:
- Cisco Telepresence C60 Codec
- Cisco PrecisionHD PTX Camera
- Remote Control
- Two (2) Audio-Technica AT841UG Table Microphones with XLR->Mini XLR Cables
- Codec is currently running TC7.3.9
- All cables included to be fully deployed.
- Small scuff/dent on back floorplate (See additional pictures)
***THIS SYSTEM COMES APART INTO 3 PIECES, EACH PIECE WEIGHTS 120-150LBS***
Design features
• One of the most powerful and feature-rich codecs available with the ultimate in video and audio quality
• The next generation HD video collaboration codec
• 1 rack unit (1RU) high, rack-mountable, with rack-mounting solution included
• Professional-grade connectors
• Unmatched quality and flexibility
• Standards-compliant 1080p solution-compatible with standards-based video without losing features
Application features
• 720p30 HD embedded Cisco TelePresence MultiSite (MultiSite) with individual transcoding
• Collaborate with three simultaneous video inputs
• HD Collaboration with 1080p30 and WUXGA *
• One button to push (OBTP) to start a meeting
• Limitless integration possibilities
• Ideal for team-based collaboration, boardrooms, meeting rooms, and industry applications
• Seven video compositors (embedded)
Performance features
• Optimal definition up to 1080p
• H.323/SIP up to 6 Mbps point-to-point
• Up to 10 Mbps total MultiSite bandwidth
• Ability to connect up to five HD sources and four microphones directly into the interface
• Full duplex audio with high-quality stereo sound
• Full application programming interface (APIs)
• Ability to takes advantage of Cisco ® TelePresence Total Solution Management, transcoded HD MultiSite, recording and streaming, Multiway, and firewall traversal
• Cisco TelePresence ClearPath packet loss protection technology for optimal experience
• Cisco Unified Communications Manager native support (requires Cisco Unified Communications Manager version 8.6 or higher)
Audio Standards
● G.711, G.722, G.722.1, 64 bit & 128 bit MPEG4 AAC-LD, AAC-LD Stereo
Audio Features
● CD-Quality 20KHz Mono and Stereo
● Four separate acoustic echo cancellers
● 4-port (C60) 2-port(C40) Audio mixer
● Automatic Gain Control (AGC)
● Automatic Noise Reduction
● Active lip synchronization
● ALD (Assistive Listening Devices) support with acoustic echo cancellation (only C60)
Monitor
● 52" Full HD LCD, 16:9, 1080 x 1920 resolution
● Dual monitor option includes 52" Full HD LCD monitors
DIMENSIONS OF THE PROFILE 52” DUAL
• Height: 63.8” / 162cm
• Width: 94.9” / 241cm
• Depth (wall mounting): 10.2” / 26cm
• Depth (stand-alone): 17.7” / 45cm
• Weight: 518lb / 235kg
Cisco C60 Telepresence Codec:
https://www.cisco.com/c/en/us/produc...78-628595.html
Cisco Profile Dual 52 Brochure:
https://www.tandberg-conferencing.co...2-brochure.pdf
Cisco Profile Dual 52 Admin Guide:
https://www.cisco.com/c/dam/en/us/td...guide-tc70.pdf
Cisco Profile Dual 52 Installation Guide:
https://www.cisco.com/c/dam/en/us/td...et_for_web.pdf
ADDITIONAL PICTURES
