Rear diff leak - Beyond.ca - Car Forums
Results 1 to 16 of 16
Thread: Rear diff leak
    Calgary,AB
    2015 Kia Forte5 SX
    Default Rear diff leak
    Got a service on Thursday and the tech told me I had a possible rear diff leak which after looking at my garage I have a confirmed rear diff leak. It’s a 2013 Toyota Highlander 4wd, from previous experiences I would prefer to not take it to the dealership mainly due to how much they charge was $1200 just for brakes, can anyone recommend where I could get this done and approximate range it could cost?
    Is it leaking from the fill plug or the cover? Either one should be something you can attempt to repair at home easily. YouTube and rockauto should have everything you need.
    Calgary,AB
    2015 Kia Forte5 SX
    I’m unsure where it’s leaking from I can take some photos underneath the car to see where it looks oily if that makes sense.
    Drove up on some lumber to Gove you space to work, then use a clean rag to wipe carefully around to find the leak. If the oily mess is anywhere on the top or sides of the diff cover, that's a cover leak. If it's at or directly below the fill plug, that's probably a plug leak.
    The overlap is if it's leaking from the cover at the bottom, that's harder to trace.
    Nothing Good.
    I have a good honest shop that can do the work much cheaper pm if you want it
    A Ferrari is a high maintenance chick, you spend money regardless of what you do with her. You can baby the C63, or slap on all seasons, and you won't be spending anything but yearly maintenance. Of course that's like dating a stripper and refusing to fuck her, which would make you gay.
    Originally posted by Rage2
    Generally leaks from the axle are either pinion seal or cover.
    Feb 2003
    DT 780
    LEXUS LX470
    I would clean the area really well with some brake cleaner and then use rags to get it clean. Then drive for a day or so and go back to inspect. Should help narrow down the source.
    Tap, Rack, BANG!
    Calgary,AB
    2015 Kia Forte5 SX
    These are the photos, seems unclear on where it could be coming from theres oil everywhere, mind you at my service they did change the diff fluid which maybe why the drain and fill plug are oily.
Size:  91.2 KBName:  IMG_0228.jpg
Size:  93.6 KBName:  IMG_0227.jpg
    a fun 4 cylinder
    That’s your pinion seal leaking. Based on the oil on you gas tank.
    Calgary,AB
    2015 Kia Forte5 SX
    Any ideas on where to get it done? I’m in the SW
    Or how hard that it to do at home? The parts are cheap.
    pinion seal isn't "hard" but you do need to be careful.
    Varies by diff, but the common issue is that the pinion needs to be removed to replace the seal. The pinion nut is generally torqued to around 100-200lb-ft (not fun to do under the vehicle) If your diff uses a crush sleeve, that torque sets the pinion bearing preload - screw that up and your $10 seal replacement becomes a $1000 diff rebuild. Pinion preload is checked with a 0-60 in-lb beam or dial-type torque wrench with the axle shafts removed, although some will take shortcuts on this by marking the nut and yoke. If the diff uses solid spacers/shims for preload instead, it's a lot easier and you just need to tighten the nut back up, no need to check preload as it's set by the shim stack.
    Edit: Here's the Highlander service guide (not sure which year): http://www.tohighlander.com/rear_dif..._4wd_-631.html - it uses a crush sleeve.
    Jul 2007
    Blue boy
    If your diff uses a crush sleeve, that torque sets the pinion bearing preload - screw that up and your $10 seal replacement becomes a $1000 diff rebuild. .
    Happened to me
    Jul 2006
    NA
    Thanks for the 14 years of LOLs. Govern yourselves accordingly and avoid uppercut reactions!
    Calgary,AB
    2015 Kia Forte5 SX
    So far I only got a quote from the dealership near me and it was $450 which doesn’t seem too bad. Haven’t called the other two places yet because they are both in the ne and that’s really inconvenient
  1. Whats The Best Leak brand to stop powersteering leak
    By 88CRXGUY in forum General Car/Bike Talk
    Latest Threads: 07-05-2006, 08:36 PM
  2. only gettin 4 psi??? boost leak? vac leak?
    By |SpEncaA| in forum Forced Induction Talk
    Latest Threads: 04-03-2006, 01:45 PM
  3. Vacuum leak / Boost leak
    By Zenshi in forum Calgary MR2 Owners Club
    Latest Threads: 09-25-2005, 10:03 PM
  4. WTT:z32 tt diff for z32 na diff
    By Jason Lange in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 09-21-2004, 11:46 PM
  5. WTB:E30 iX rear diff
    By benzodude in forum Automotive Parts
    Latest Threads: 05-28-2003, 04:32 PM
