Lawn Thread - MEGA - Page 39 - Beyond.ca - Car Forums
Page 39 of 135 FirstFirst ... 29 38 39 40 49 ... LastLast
Results 761 to 780 of 2682
Thread: Lawn Thread - MEGA
  1. #761
    V8s
    Some quick googling shows you can get it up here at an astronomical price (>$200 for 1.25oz??). Also found some forums where people said it did some damage to surrounding grass when applied.
  2. #762
    Feb 2003
    DT 780
    LEXUS LX470
    Anybody know how long ez seed takes to germinate in our climate? I put some down about 10 days ago and have been watering 1-2 times per day to keep it moister than the pm's speeches. Still havent seen any shoots...
    Tap, Rack, BANG!
  3. #763
    I have legit had a bad batch of ez seed before.
    Give it a another week or 2 but otherwise I’m Pretty sure there is a satisfaction guarantee.
  4. #764
    Only 15min from Aspen!
    Nothing interesting anymore
    I did the same a couple of weeks ago. I put it in 1/2 dozen areas and only one spot has grass growing, and barely any.
  5. #765
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    Phew, I thought I was the only idiot that couldn't get ez-seed going. Had one spot for a month and I barely have shoots growing. Have another spot from a different bag that hasn't grown either.
  6. #766
    Aug 2003
    YH2/FK8
    Is there a place that can offer a service where they go out to property, take soil samples and get them tested for PH levels? Or is it worth it to buy a soil core sampler and test it yourself? I'm fertilizing and watering the front lawn just as much as my rear and the rear lawn seems to be doing a lot better than the front for whatever reason. The only variable now is soil quality.
    SneakerFiles.com | Blog | Team AM Fam
    1993 Honda Civic CX (B16A2) - 2002-2005
    1992 Honda Civic Si (K20A2) - 2006-2008
    2008 BMW 335i - 2008-2013
    2008 Honda Element EX AWD - 2013-Current
    2021 Honda Civic Type R LE - 2021-Current
  7. #767
    Bunch of Honda's
    I'm at 3 weeks and I have tons of germination. Light sprinkle mid-day and good soaking every night. Didn't have anything start sprouting for 2.5 weeks or so.
  8. #768
    V8s
    I've planted grass (not ez seed, mind you) a couple times in the last couple years. In my limited experience, it consistently takes a month to start seeing anything.
  9. #769
    2008 Z06
    Fyi, UFA in high river has lawn stuff for cheap:
    55lbs grass seed for $155: https://ufa.com/myUFA/Animals/Animal...g-bag/p/684398
    55lbs lawn fertilizer for $30: https://ufa.com/myUFA/Yard%2C-Garden...25-kg/p/885885
    I got 300lbs or so of fert.
    Doing some weed spraying
  10. #770
    Dec 2014
    Lariat 2.7 & StreetTriple R
    Yep from the pics you guys sent, its definitely quackgrass. Ill give removal a try with a bit of Roundup grass control, which as per the label apparently works on most grasses and quackgrass, on the roots. Hopefully it doesn't kill too much grass around it and I should be good to re-seed those areas
  11. #771
    Jun 2003
    Canada
    GMC Sierra
    Quote Originally Posted by Ekliptix View Post
    That's quite the lawn to look after. What product are you spraying?
  12. #772
    Using any amount of roundup on your grass will kill everything around it and downhill from it
  13. #773
    2008 Z06
    Quote Originally Posted by sxtasy View Post
    I used some commercial UFA chemical (requires rural address) that I borrowed from my cousin (plus the big sprayer). I ended up mixing it too weak (I realized later), so it did a half ass job on the weeds.
    I have a big jug of Par 3 myself, so I'll be using it, with the right concentration, in a week or so to try again. https://ufa.com/myUFA/Crop/Crop-Prot...-Jug/p/1122102
    If I were in a pinch, I think Killex concentrate would work fine too, but maybe not kill the thistles.
  14. #774
    S212 E63s / MK7.5 .:R
    Quote Originally Posted by OTown View Post
    Make sure you aren't spraying with the wand. You might be better off buying the concentrated one, diluting it yourself and doing the paintbrush method or manually "jerking them off" with PPE gloves dipping and applying by fingers only. I would only spray if you have a large infested area of quackgrass that isn't around healthy grass.
  15. #775
    Sep 2012
    The paintbrush method works great. Killed a whole bunch of quackgrass with it. They’re basically a colony so even painting a few leaves will kill the entire plant.
    Also buy a fresh batch, I find RU becomes useless after a couple of years.
  16. #776
    I like this idea. I have a lot of quackgrass.
  17. #777
    Bunch of Honda's
    Is this quack grass?
    Peep the bullshit coming through the fence. Also might have creeping bellflower in their front yard now. I'll snap a pic tonight. If it is I'll be wipeout-ing that shit when they're away.
  18. #778
    Definitely quackgrass.
    Pull an entire one out and look at the auricle. Quackgrass has a clasping auricle.
  19. #779
    Bunch of Honda's
    I should just go in their backyard and spray their entire 'yard', I'm sure its everywhere.
    If they have quack grass seeding and spreading on their side should I just pull an ES, give up and crack a cold one?
  20. #780
    Can you put a landscaping barrier in place under the fence to mitigate spread?
  1. LF: Mega Man ZX & Mega Man ZX Advent for DS
    By Despair* in forum Video Games / Consoles
    Latest Threads: 06-04-2010, 03:32 PM
  2. Calgary Flames MEGA THREAD: 2006-2007 Edition
    By Kirbs17 in forum Sports, Health & Fitness
    Latest Threads: 06-23-2007, 01:38 PM
  3. Calgary Flames MEGA THREAD: Info, Chat, Discussion
    By l8braker in forum Sports, Health & Fitness
    Latest Threads: 08-29-2006, 02:44 PM
  4. Fs: **mega Misc. Thread!!!**
    By cycosis in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 08-21-2006, 09:47 PM
  5. The 2006 World Cup Soccer Mega Thread
    By RickDaTuner in forum Sports, Health & Fitness
    Latest Threads: 07-13-2006, 07:04 PM
