Bahahhahaaahhah.
Not my photo.
Yes
No
Not yet, but will do if things get bad.
Bahahhahaaahhah.
Not my photo.
Everything I say is satire.This quote is hidden because you are ignoring this member. Show Quote
Reverse psychology. They've run out and can't get more, so might as well do a Trump and mindplay.This quote is hidden because you are ignoring this member. Show Quote
Trudeau announced possible monetary support payable every two weeks to 15 weeks. That's a heck of a timeline to be planning.
Cocoa $11,000 per tonne.
So does anyone actually remember the days when you could get unscented or scented TP?
If there's still people in need of TP the walmart at deerfoot city has tons now. They're limiting one per family but its big 30=80 rolls bag.
https://forum.bodybuilding.com/showt...hp?t=110123441This quote is hidden because you are ignoring this member. Show Quote
I have recently made a mistake in my life, and I offer my story to you, that you may learn from my error. It all started, as many things do, with me having trouble ****ting.
No, I was not constipated; this was not a regularity problem but a matter of technique. It seems my butt-hair had grown to such a length that tiny grogans were constantly getting tied up in the matted jungle between my buttcheeks. It led to much frustration, with me KNOWING that I still had something to drop, but unable to shake the tenacious turd loose from its butthair dwelling. Eventually I would have to do two things: either reach down with some paper and try to pinch off the lingering loaf (which required careful precision to avoid smearing the creature all over my rear, especially since I had no way of seeing what I was doing) or just go for broke, start wiping, and hope that I could remove all the leftover fecal matter before the toilet paper reached its Can't-Be-Flushed threshold.
I was contemplating this problem, when I had what seemed at the time to be a bright idea. "Hey! This is my butt and my butt-hair, right? So why don't I just eliminate all the hair, and then my grogans will flow out like beer from a keg!" I said to myself. It is a statement that will go down in history with a lot of other regretted statements. "How many Indians could there be?" said by General Custer. "Looks like a good day for a drive!" by JFK. "There! America On-Line now has complete Usenet access!" by some idiot system tech. Such was my anal shaving idea.
I performed the operation that night, with a cheap disposable razor and a towel to sit on. Starting from the bottom, and shaving from the crack to the cheeks, I began the arduous process of ridding my butt of hair. Occasionally, I would have to clean the razor of accumulated hair and miscellaneous slime, which I did by wiping it on the towel. Slowly, my twin mounds and the between-ravine began to resemble the hairless cheeks of a newborn baby. Finally, I wiped the razor one last time, and surveyed my work. The towel was covered with a pile of hair. My butt was smooth as ivory. I smiled, satisfied, thinking my troubles were over.
Little did I know.
I now have a great respect for anal-hair. Like everything in this world God created, it has its mighty purpose in existence. It was only after I had removed it that I started to learn how much I had been taking it for granted. For one, it provides friction. I learned this the next day, when I walked out into the sun heading for class. After climbing two flights of stairs and starting to sweat, I started to notice something unpleasant. The sweat was accumulating in my crack, and was causing the unpleasant sensation of my two buttcheaks sliding past each other with every step. I thought about going to the bathroom and wiping it off, but had to get to class. Eventually, I thought, it would dry.
Unfortunately, it did dry, but only after mingling with the microscopic poo- molecules lingering around my brown starfish. When I stood up after class, my cheeks were stuck together with a slimy sticky ****/sweat combination. As I made my way back to my dorm, it started to itch. God-DAMN, did it itch! Felt like a swarm of ants was making its way up and down my crack. Fighting to keep from jamming my hand down there and scratching away, I rushed back to the dorm.
Unfortunately again, this exertion caused me to sweat, and when I finally reached my room, my cheeks were sliding back and forth against each other like a pair of horny cane-toads. I quickly dropped my pants, and attempted to dry my butt off by sticking it in front of a fan and spreading my cheeks. As I pulled the two mounds of flesh apart, a horrible stench burst free and filled the room. Every dog within a 4 block radius started to howl. I had it worst of all, as the ripe aroma of festering ****/sweat went into the fan and blew back into my face. I fought to keep from heaving. And as I sat there, fighting vomit, my butt cheeks spread and dripping, with the concentrated aroma of my body odor mixed with the tangy smell of my own ****blowing right into my face, I had only one thought: "It will be like this until the hair grows back. Weeks."
Later on, trying to deal as best I could, wiping my butt at every opportunity, I discovered another wonderful use for butt-hair - ventilation. I attempted to launch a fart, only to have it get stuck between my buttcheeks. Apparently, with no hair, the two pink twins can get vacuum sealed together, and the result was a frustrating fart that slid up and down between my cheeks like a lost gerbil.
As if that wasn't enough, I am now enduring further torture. As anyone who has ever shaved anything knows, when hair is first growing in, it comes in as stubble. Imagine your butt having the texture of a Brillo pad. Well, that is what I am dealing with now. It is a hellish torture, and there are many times when I just look out the window and contemplate why I shouldn't just jump out and get it all over with in one fleshy splat, rather than endure this constant agony.
Guys, DON'T SHAVE YOUR BUTT-HAIR!
My wife told me that I have to use the bidet from now on because on average I use about 30 sheets per trip - and 2 or 3 trips per day and in the last 2 weeks shes replaced the roll 3 times. I told her we have 38 rolls and that we have a 40 day supply according to that website https://howmuchtoiletpaper.com/
I just dont like that cold water hitting my hole
30 sheets per shit? That's pretty high.
Butter Chicken will do that to me tho.This quote is hidden because you are ignoring this member. Show Quote
It might be related to the standing vs sitting debate - but I guess Im half way between sitting and standing (squatting); if baffles me that people can wipe their ass while still sitting on the seat.
Jesus, 30 sheets 3x per day? This should be a diet discussion, not a TP discussion.
Jesus how does your corn hole feel?
only pooped once today I think i usued less than 15 sheets this morning.
I think since Ive been eating at home every day ive been shitting massive logs.
This is why the Kirkland brand extra wide sheets come in handy - you use less sheets per wipe but still have the same surface area of paper you are used to.
Werd, guy should be medicated. Even if just mentally.This quote is hidden because you are ignoring this member. Show Quote
30 sheets per shit lol. That’s like wiping your ass with a wad the size of a dodge ball.
I can only imagine the chafe with a 30x3 sheet daily wiping regiment. I need to go grab some lotion just thinking about it.
I use charmin, its like wiping your ass with polar bear fur.
you can get to 30 pretty fast depending on what you eat. 4 sheets per wipe, 5-6 wipes per shit, and if i'm at home i do a couple of wipes with wet TP (i'm not cool enough to bidet), then a couple to dry. easy to get to 30.
You mean you don't wipe your ass with actual polar bear fur? Found another poor person, guys.This quote is hidden because you are ignoring this member. Show Quote
