LF: Rust repair recommendations? - Beyond.ca - Car Forums
Page 1 of 4 1 2 ... LastLast
Results 1 to 20 of 61
Thread: LF: Rust repair recommendations?
    '91 NA1 ADVAN'D
    Default LF: Rust repair recommendations?
    The windshield requires replacement, and there's a bit of rust around the top of the windshield. So looking to find a place that'll do this at an affordable price. The truck's got 422k km on it, so it doesn't need to look factory fresh. Just mainly looking to repair it to prevent further rust.
    Suggestions would be great!
    Top of windshield:
    Also, some other rust spots which would be "nice to repair"
    Bottom of the rear door:
    Rear Tire Well:
    Rear bumper requires pulling out:
    Subscribed
    Wildflower Ranch
    Neo-Liberal Anarchist Mobile
    Me too. I am also in need of a small repair.
    Roof will be a quick sand and repair but you may need to pull the windshield to see if the rust has gone behind it.
    Door just replace
    Fender will be cut and weld
    Will also be repainting involved
    Sep 2016
    Calgary, Ab
    2021 Zonda CRV
    Subscribed. Need similar work on the Zonda.
    Wildflower Ranch
    Is that like a fancy Honda with ZTEC?
    '91 NA1 ADVAN'D
    firebane - yes the windshield does need to be replaced anyway, hence I was thinking of doing it at the same time.
    As for the doors, I checked a wrecker, they wanted $650/rear door, then, of course, I would then have to repaint. Looking for the most economical method which will stop the rust.
    As for rear wheel well, it's surface rust, so thinking of sanding it down, use some rust converter, then primer and some paint, Put on a set of fender flares and we're golden. Don't even need to paint.
    Door's fucked. That type of rust is from the inside. Replace door or get a new skin put on but don't expect miracles. If it is a door from the wreckers it likely has the same problem. Door skin all depends on the extent of the rust inside the door. Unless it it is all cleaned out (near impossible) the rusty door frame will start rusting the new skin. Roof looks pretty bad. Sanding and painting will buy you some time but nothing will stop it short of a new roof skin. Box side looks like it is on the outside so it may be salvageable. Sand and repaint and cross fingers. Bumper, replace brackets and good to go. Rust is a bitch. Once it starts it is pretty much impossible to stop.
    '08.5 Mazda 3
    '90 Laser RS-T
    '07 Yamaha R6
    Quote Originally Posted by HHURICANE1 View Post
    +1, truck is a write off, sell it to me.
    Calgary, AB.
    210000 km oldie
    Beyond rust repair meet! 20 feet apart. Kinda like the cross fit meets :-)
    If someone needs some exercise repairing rust, HMU fam.
    '91 NA1 ADVAN'D
    Just an update. I've been getting some pretty wide ranges for quotes on rust repair. One shop I've gone to in the past, Pacific Autobody, quoted $2k w/ the windshield for just the roof. Another, Hinz, off of McKnight & 12th Street NE, quoted $800 + windshield for the roof.
    I think I'm going to hit up a few more places just in case to see if the right price is closer to the $800 mark.
    Jun 2003
    Subscribed, still need work on the Lexus, group buy if you find a place maybe we can get a Beyond discount?
    '91 NA1 ADVAN'D
    Clever - I'll approach these shops with the potential of additional work from other members. The only way a "group buy" can work is really just a discounted rate. Bodywork, in general, is hard to have firm prices on unless the scope is totally clear.
    For those who're interested in a "group buy" for bodywork services, please chime in here. I'll approach the body shops to see if they're interested in a potential stream of business from fellow automotive enthusiasts.
    Just keep in mind that each body shop has a different combination of cost/price, quality, and customer service of doing the work. I'm personally not needing the quality of work that Maranello provides for my truck.
    2020 Subaru Forester Sport
    For your fender damage, you could look at something like I just did on my wife's car, it's a rubber double sided fender flare....goes on easy with a heatgun and hides the damage + hopefully protects a bit. I did sand the spot down and paint it with rust paint just to hopefully prevent spread, but probably bought a few years of it progressing. I had damage on front fender and must more severe damage in the back. I cleaned it all out, sanded, rust paint and then rock guard spray on the inside of the fender to hopefully provide some protection.
    This is what I bought but comes in various widths and such: https://www.ebay.ca/itm/4pcs-1-5M-3-...53.m2749.l2649
    Can see it installed in this pic:
    The door edge I am trying to repair myself right now...but have to redo, was impatient and fucked up the clear coat
    This was my original front fender damage:
    And my rear:
    Edit here is the before and after with the fender rubber thing. Seems to look alright. This was the undamaged side of the car but naturally I had to make it symmetric
    I might be in for some body repair professionally.....depending how my second attempt at the door goes and if I can make it look good to my liking, being a perfectionist fucking blows when it comes to body work.
    Treg/B7
    Now that you know how much work it is..... How much would you like to charge for that fender and door repair?
    Jun 2003
    Yeah, I guess group buy is not the best term but if any shop if willing to give a discount for more work, I’m definitely interested. The rust damage on mine is quite extensive:
    Attachment 92168
    Attachment 92169
    Mar 2012
    NYC
    dumpster trains
    Really you need to ask yourself, is it really worth fixing...
    Originally posted by speedog
    So more beyond armchair activism at work again?
    BB6
    I'm definitely interested in a group buy for some rust repair
    Also interested. I have a rust patch on the hatch of my recession rocket (Honda Fit)
  1. Undercoating/Rust Protect Chassis. Product recommendations and experiences?
    By nobb in forum Trucks, 4x4 and Offroading Zone
    Latest Threads: 09-12-2013, 12:16 PM
  2. FS: RUST! (free truck with rust)
    By Tik-Tok in forum Trucks, SUVs, Vans, Trailers
    Latest Threads: 03-17-2009, 04:50 PM
  3. Rust, Rust more Rust
    By fresh in forum Cosmetic and Styling Modifications
    Latest Threads: 03-17-2005, 07:22 PM
  4. Fender rust repair?
    By redline_13000 in forum Mechanical
    Latest Threads: 02-22-2004, 09:15 PM
  5. extreme rust repair
    By Lo)2enz0 in forum General Car/Bike Talk
    Latest Threads: 03-19-2003, 09:12 PM
