Roofer wanted to install additional vents - Page 3 - Beyond.ca - Car Forums
Page 3 of 3 FirstFirst ... 2 3
Results 41 to 60 of 60
Thread: Roofer wanted to install additional vents
  1. #41
    ExtraSlow dreams of building in the country with a really steep roof and no gutters. It'll be glorious.
  2. #42
    Bunch of Honda's
    I agree that your problem is very baffling! I hope you can figure it out.
    My gut says that it's not a leak but that the conservation is gathering IN the exit vent and then making its way back in to the house.
    Just a guess though... I'm not sure why I think that.
    That makes the most logical sense. If there was attic rain issues we would have seen them last winter or even last week. Its been warm for too long for it to just show up yesterday.
    Did not run the fan all night last night and the dripping and cold draft seems to have stopped. Still a small stain on the ceiling. What in the fuck? Unless whatever moisture issue is up there has frozen back up (ie: blocked vent) so no more dripping/draft. Probably to return later this week when it warms. Fuck off roof.
    Any recommendations for roofers to come take a quick look at this. Zero chance I'm climbing up onto the roof or through a tiny attic space to check this shit out further.
  3. #43
    Getting around in your attic might not be as horrible as you think. I had to take a few steps in and it was massively complicated by the fact that my blown-in insulation completely obstructs my view of the trusses, but with some good gloves and a head lamp... It was... Tolerable.
  4. #44
    2020 Subaru Forester Sport
    Yah it's not so bad. I ran cables up there before. Just have to make sure you feel the trusses before you take your next step, else you fall through the ceiling
  5. #45
    Bunch of Honda's
    4:12 slopped roof and minimum heel heights mean there is no space up there. Or very little, especially at the perimeter where the bathroom sits.
  6. #46
    Sep 2012
    Wear an N95 mask. That shit will rek your lungs.
  7. #47
    Feb 2003
    DT 780
    LEXUS LX470
    I have that low slope roof and you can basically take a look from the hatch but good f'n luck crawling around in there on your belly. Plus the attic hatch has a rectangle of fibreglass just sitting loose on it so I had to run strings over it to pull it down into place once the hatch was closed back up.
    Tap, Rack, BANG!
  8. #48
    True, I didn't say that I went all the fuckin way over there - just that I took a couple baby steps and it wasn't as life-altering as I thought it would be.
  9. #49
    Feb 2003
    DT 780
    LEXUS LX470
    Ok here is an update on my bathroom fan leak situation. It kept happening so I pulled the fan out to look at the ducting. No damper at the fan housing, flex vent went about 2' laterally then connected to a vertical rigid vent. I could feel cold air drafting in. I contacted the builder who put me in touch with the hvac guy. I told him about my roof damper theory. He said he has seen this issue often but the 2 most likely causes are:
    - fan housing takes up 8" of ceiling cavity so blown in insulation is thinner over the can. The 2" of insul doesnt keep the can warm eenough so condensation develops on can. Need to add insulation above fan if that is your issue.
    - second option is a blocked fresh air vent causing house to pull a vaccum and suck air in from the fan vent. Well sure as shit my fresh air vent was linted up the asshole and I didnt catch it during my fall maintenance. Cleaned it out and will see if problem resolves when I run fan tomorrow morn. Already it feels like less air draft coming in from the vent duct.
    Tap, Rack, BANG!
  10. #50
    Cochrane, AB
    Trucks
    Gotta go Brazilian on that one. Keep your holes clean, damn it.
  11. #51
    Canyonero
    are you sure that's your furnace's fresh air intake? why the fuck would it lint up like that?
    To me that screams dryer exhaust vent, which would explain why it's so lint-y.
  12. #52
    Elbonia
    Jeep of Theseus
    No damper, should be an intake vent.
  13. #53
    Not Aspen
    Two from Freemont
    Lint is on the outside of the grill, not inside.
  14. #54
    That's remnants from several vagrant rodents and other vermin participating in a soup kitchen at the air intake.
  15. #55
    Feb 2003
    DT 780
    LEXUS LX470
    I looked at the lint I vaccuumed/brushed out of there and I couldn't tell if it was mouse fur or dandelion fluff mixed with scuzzy dust. But we did have a lot of dandelions on that side of the house this past summer. I am thinking of suing my neighbour for spreading dandelions to my yard, thereby linting up my air intake, thereby pulling a vaccuum through my bathroom fan, thereby dripping water onto my waterproof floor and the side of my arm while I was taking a morning shit. So far I am calculating my damages at $1MM for pain and suffering and liability seems open and shut to me.
    Tap, Rack, BANG!
  16. #56
    Just whack off shortly before the next time you fuck his dad so you can really get some mileage out of it.
    Then you're pretty much even.
    /Arbitration
  17. #57
    Aug 2003
    Cochrane
    You can't have a screen on a dryer vent according to the code! It's probably an intake vent but it's good that you cleaned it.
  18. #58
    Feb 2003
    DT 780
    LEXUS LX470
    Ya that was the fresh air intake. Because it was clogged, the furnace and hrv was pulling a vacuum and making air suck in through the bathroom exhuast ducting. That cooled down the fan causing condensation which would melt/drip when the fan was turned on. I cleaned the lint, now the hrv/furn had good intake air and no more vacuum/air leak through the bathroom vent duct.
    Tap, Rack, BANG!
  19. #59
    Aug 2003
    Cochrane
    I ended up having Magic siding and roofing in Cochrane install these solar powered active vents. I went into that attic a week later and I can certainly feel the draw that 2 of these vents. They're hail resistant with a warranty included so they'll get the test next year haha.
    https://www.amazon.ca/Seasons-design...65724139&psc=1
  20. #60
    Sep 2012
    Quote Originally Posted by B69 View Post
    Anything pre-90s and you'll see the wackiest things. Anything pre-00s and it's only half crazy.
  1. Replies: 153
    Latest Threads: 01-13-2011, 05:57 PM
  2. Roofer experience?
    By Xtrema in forum Home and Garden
    Latest Threads: 11-27-2010, 12:05 PM
  3. Roofer Recommendations
    By 5gluder in forum Home and Garden
    Latest Threads: 09-24-2010, 09:38 PM
  4. Recommend a good roofer
    By black_2.5RS in forum General
    Latest Threads: 08-07-2006, 09:17 AM
  5. Wanted to Hire: Roofer, or Roofer helper.
    By npham in forum Careers
    Latest Threads: 06-21-2006, 11:48 AM
