Lipstick on a Pig - Page 7 - Beyond.ca - Car Forums
Page 7 of 8 FirstFirst ... 6 7 8 LastLast
Results 121 to 140 of 148
Thread: Lipstick on a Pig
  1. #121
    Sep 2008
    Turbo stuff
    Are the street legals always pro tree now or was it just last night? I don't mind it, not a serious racer anyways I just go to set an ET for the car. Always funny watching first timers figure out how to stage.
  2. #122
    Mar 2007
    Edmonton area
    Has wheels
    I don't recall, this is the first time I've been back since precovid days.
    Separately, I figured as much but really found out I need a different converter as well
    Only made 2 passes and I let off on the first one as I thought I heard a charge pipe or something pop (nothing did) and on the second pass I actually "loaded" the car and it's so damn lazy out of the hole, that was enough for me haha. 117 trap on that pass, I was cutting 11.2s @ 119-120 with my Malibu and thought that car had more yet with more seat time / set up.
    It's currently a roll car in this set up
  3. #123
    Feb 2020
    Edmonton
    Quote Originally Posted by Sentry View Post
    Took it drag racing last night and was able to get 12.5@117mph on the stock rear gear and stock converter. Leaving on zero boost. Should be able to run 11s next year no problem.
    I should visit Vex and we should race. Our competition of slow 60's and high top ends would be legendary!
    If I had known you guys would end up being such bitches, I would’ve opened the parenting forum.
  4. #124
    Sep 2008
    Turbo stuff
    For a rainy day. Got it 250 bucks off due to an Amazon pricing error. Should help this thing make a bunch more power at the same boost level.
  5. #125
    Sep 2008
    Turbo stuff
    Sep 2008
    Turbo stuff
    New rear tires. Crown THICC
  7. #127
    Cochrane, AB
    Trucks
    @Sentry , Now that you have some new rubber on her, may I suggest your next upgrade. ---> 27 litre V-12
  8. #128
    Sep 2008
    Turbo stuff
    350 bucks? No problem
  9. #129
    Might be a bit heavy.
  10. #130
    Jul 2008
    Edmonton, Alberta
    When your weight distribution is 90/10.
  11. #131
    Once you hook up on some Flintstone-sized Hoosiers and the front end comes up, all weight goes on rear, baby!
  12. #132
    Cochrane, AB
    Trucks
    It was made with all the high tech, featherweight, go fast materials of the 1940’s, like cast iron and high carbon steel and more cast iron.
  13. #133
    Sep 2008
    Turbo stuff
    The stupidest part was, they put those in airplanes and then ford built an ALL ALUMINUM v8 to stick in a tank.
    https://en.wikipedia.org/wiki/Ford_GAA_engine
  14. #134
    Sep 2008
    Turbo stuff
    Gave it a bit more pep in its step, changed rear gears from 3.27 to 3.73s. They should have came with these from the factory.
  15. #135
    373 to get ready for the 7.3 install.
  16. #136
    Sep 2008
    Turbo stuff
    Shes a fucking RACECAR NOW BOIS
    Got some red ignition coils off amazon for dirt cheap, threw some fresh plugs in it too.
  17. #137
    Each coil has a sticker, each sticker worth 3 hp.
  18. #138
    X5D, Fiesta ST
    “God help me, I got a racecar”
  19. #139
    Sep 2008
    Turbo stuff
    Todays project, build a throttle elbow. Picked up a 5.4 throttle off a junkyard F150 (larger than whats on my 4.6) and need to adapt it to the Vic Jr. I'll be putting on soon.
    All done and sandblasted.
    Also welded a couple little beads to the throttle so it'll hold the coupler on under boost.
    Just gotta do a Mopac run for some fittings for the new fuel rails and stuff and then I can install it!
  20. #140
    Sep 2008
    Turbo stuff
    One last look at the factory intake:
    Annnd Edelbrock intake swapped on:
    Yes it clears the hood.
    Here's a comparison of the throttle body upgrade, 65mm vs 75mm.
  1. Whole Pig - Pig Roast
    By TheCheff in forum Food and Dining
    Latest Threads: 08-06-2018, 08:19 AM
  2. How to get lipstick off shirt?
    By GTS Jeff in forum General
    Latest Threads: 08-18-2006, 12:09 AM
  3. Lipstick (lmao)
    By gorillam in forum Misc. Gallery
    Latest Threads: 01-03-2005, 11:06 PM
  4. Weighed the pig last night
    By HillBilly in forum Bike Talk
    Latest Threads: 10-02-2003, 11:34 PM
