"Eh'ts for 8" Firebird Build - Page 4 - Beyond.ca - Car Forums
Page 4 of 4 FirstFirst ... 3 4
Results 61 to 77 of 77
Thread: "Eh'ts for 8" Firebird Build
  1. #61
    Mar 2005
    Foothills County
    is faster than yours
    How are the fuel lines plumbed to each rail? Could do a quick check to make sure fuel is getting to the driver’s side too?
  2. #62
    C-Spot
    11sec S14, Lux Family Bus, VQ35HR
    My bad, I'm not really on here on weekends. Only when I'm at work.
    If you need the fans still PM me I think I'll get an email. But it sounds like you've got that solved and found other gremlins.
    Is it possible the pump could have picked up something in the tank and now damaged or sending insufficient pressure? Or something in the tank is clogging the rail?
  3. #63
    Can you swap the rails with injectors easily or swap injectors?
    But I'm doubtful that multiple inj got plugged or seized at the same time.
    Start looking at the wiring. Squeeze the loom and see if you can maybe figure out when it comes to life and there's a broken wire in there.
  4. #64
    Sep 2008
    NE
    Ram 1500, '68 Camaro, S14
    Check the Term X software for number of cylinders and injection type, at some point mine changed and wasn't even thinking i had 8 cylinders haha.. I went over everything 10 times then was poking around on my global config file and saw that...
  5. #65
    Feb 2020
    Edmonton
    Crank sensor wire was resting against plug wire
    Seems to have fixed most issues. Tried to die outside Three Hills with the same issue, revving the piss out of it helped get signal back maybe.
    If I had known you guys would end up being such bitches, I would’ve opened the parenting forum.
  6. #66
    Running a shielded, grounded wire sucks. But might be the answer. Or just moving that sensor wire elsewhere.
  7. #67
    Aug 2012
    Down by the River
    GMC Sierra, LX570
    Saw a purple fire chicken going East past brooks. That you?
  8. #68
    Feb 2020
    Edmonton
    Yea it was!
    And its not purple *cry emoji* (Im in denial)
    Been stopping pretty frequently to figure shit out like heat management and fuel mileage
    Figure 13L/100km at 2800 4th unlocked.
    The organizer gave me vthe whole route, I get a 10 second 1/8 mile slip today.
  9. #69
    Feb 2020
    Edmonton
    Surviving, got into Saskatoon at 3am, stopped along the way to check on some stragglers that I was passing.
    Footnote: if you ever do anything like this, 4L80 is da way, just say no to a turbo 400.
    Made it to Hardisty last night, 37*C ambient temp, was about 50 in the car.
    Sometimes you have to improvise
    Got to Forestburg this morning, noticed a clunk. Found an axle wanting to leave for better places.
    Lucked out that I had some random grade 2 bolts kicking around and scrounged some off the guy next to me (thanks dude whose name I don"t know!)
    Fixed
    Track is open now for hotlaps, so I should be able to get my 3-4 passes in.
    Running 85psi fuel pressure now at the track, worked on my footbrake technique with this stock converter, and increased rev limiter to 7200rpm
  10. #70
    Sep 2008
    Turbo stuff
    Hahahaha the sun shield is great. Good to hear the car is mostly holding up, this is a really good shakedown for it. By the end of the week any possible issue will be sorted and it's turbo time
  11. #71
    Feb 2020
    Edmonton
    Axle wanted to leave so bad it decided to take the caliper with it...
    This happened in Bashaw. Basically the yuge calipers the original owner installed are mounted via the bearing retainer plates. So all the force from braking is placed through 4 1/4" bolts. Needless to say, the grade 2 chinesium bolts I installed didn't stand up to the first hit of the brakes at highway speed.
    Rolled into Rimbey at 830pm, about 2 hours behind schedule. Today was supposed to be the relaxed day... Tomorrow is Rimbey to Medicine Hat ��
    Ran an 8.5 today, best mph so far at 90. With a converter alone, car should be well into the 7's in the 1/8th or around 11.5 in the 1/4.
    Being in school in two weeks, I don't think I can justify a torque converter purchase.
    But next season, I expect I'll have a jegs xhd lockup converter in it by the start of the season. See how well it runs, then slap the turbski setup on for Miles of Mayhem.
    6 point rollbar is good to 6.39 in the 1/8th but that would be realllllllly pushing the budget for 2023. The GT45 might get me into the 8's, mission accomplished, but that remains to be seen.
  12. #72
    Feb 2020
    Edmonton
    Need to go drink beers, but made it to Medicine Hat at 930pm because #reasons
    Rockstar parking though lol
  13. #73
    Sep 2008
    Turbo stuff
    How was the rest of the week? Car make it home?
  14. #74
    Feb 2020
    Edmonton
    Quote Originally Posted by Sentry View Post
    I got home at 1030pm last night. Car made it home with lots more side of the road repairs. I have a writeup but I had to be out the door at 8am to move from my condo to my rental closer to UofA so... Story to come when I get a chance to breathe (writing this in an Edo haha)
    To whet the appetite
  15. #75
    Nov 2003
    06 EVO IX, 17 RAPTOR,13 JKRU, 18 TH Jeep
    Quote Originally Posted by zechs View Post
    i saw a ton of the participants on eastbound TC#1 that thursday night east of Calgary - was wondering where all of the cool cars were headed. i was coming back from Winnipeg that day. Very cool....
  16. #76
    Feb 2020
    Edmonton
    #youcouldsaythingsaregettingseriouspart2
    Purchased the CNC notching upgrade as well. Kit is specific for firebird t-top and the shop test fits it in a chassis they have onhand to make sure everything is correct before shipping.
    Basically just stick bars in place, weld, and go
  17. #77
    Elbonia
    Jeep of Theseus
    Srs bsns!
    If you're going to be streeting it, highly recommend some high quality padding on the bars. Cages are awesome for safety in major wrecks but the bars are relatively dangerous for head injuries in minor collisions if you're not wearing a helmet.
  1. Pre build or build out a pc? Need to upgrade my home desktop
    By cycosis in forum Computer Help Desk
    Latest Threads: 02-28-2020, 01:16 PM
  2. Replies: 87
  3. FS:15" rims, from mid 80s pontiac firebird
    By fox in forum Automotive Parts [Wheels/Tires]
    Latest Threads: 12-19-2004, 09:40 PM
  4. 17" rimsfor camaro/firebird/5-4.75 pattern
    By bol in forum Automotive Parts
    Latest Threads: 04-13-2003, 05:53 PM
  5. Me VS new Firebird. Got spanked BAD!
    By Daddymax in forum Street Encounters
    Latest Threads: 10-25-2002, 12:25 AM
