questions on G35 Bushing replacement - Beyond.ca - Car Forums
Results 1 to 11 of 11
Thread: questions on G35 Bushing replacement
    Apr 2003
    Toyota, VQ35DE, B58
    Default questions on G35 Bushing replacement
    Quick newbie question, what is the rule of thumb for bushing replacement? (especially for an old car that is approaching 200K? )
    1) Do you "only" replace the broken one with an upgraded version? or do you do a complete overhaul for every bushing to save the headache down the road.
    2) Is DIY possible without the hydraulic press? and if not what does the average shop charge for a complete bushing over haul?
    "There are known knowns. These are things we know that we know. There are known unknowns. That is to say, there are things that we know we don't know. But there are also unknown unknowns. There are things we don't know we don't know."
    -- Donald Rumsfeld
    Jul 2007
    Blue boy
    Quote Originally Posted by KLCC View Post
    Change whats needed, unless customer wants to go all out. some bushings are able to be done without hydraulic press. price depends on vehicle
    Mar 2006
    Depending on your intentions with the older car you can also buy new suspension arms with the bushings installed. Might be more parts cost but it will definitely save on labour. Pressing out bushings sucks.
    Don't forget to tighten everything down with the bushings in the neutral stress position, or you'll be doing the whole job again in a month.
    Feb 2003
    DT 780
    LEXUS LX470
    +1 for buying control arms w/ pre-installed bushings whenever possible. Makes DIY much easier.
    Tap, Rack, BANG!
    Nov 2021
    E46
    By upgraded, do you mean polyurethane bushings? I would stick to the factory bushings unless this is a track car.
    G35's have mostly cast control arms, you are going to need a hydraulic press, a bunch of drivers and receivers, and some knowledge on how to press without damaging things or yourself.
    Buying new arms is going to be the easiest way. I'm going to assume the mounting bolts are seized into the bushings and the bolts cannot be removed so the arm will be stuck in the sub frame and has to be cut out with a Sawzall. It is super easy to accidentally cut brake, fuel lines, wiring harness doing this, so be careful.
    Usually you replace only what is needed. A few months ago I replaced all rear suspension bushings on a vehicle. It took me 10 hours. So not cheap.
    C-Spot
    11sec S14, Lux Family Bus, VQ35HR
    +1 for new control arms with the bushings pre-installed. And only replace what's broken.
    You're going to be in for a fight anyway with the bolts underneath.
    +1 for polyurethane also being a bad call.
    Apr 2003
    Toyota, VQ35DE, B58
    great advice for those who chimed in.
    I will only replace what's broken instead, I'll probably looking for an upgrade with the bushing pre-installed to save me the hassle, and time.
    Just curious why polyurethane is not advised compare to stock rubber? is it because of environmental? or just because it makes the ride harsh?
    -- Donald Rumsfeld
    Way more NVH and possibly squeaky nonsense that's terrible in a daily driven car and doesn't matter at all in a track car.
    I think of it as a track upgrade, only. Similar reason to never run track brake pads on a street car.
    Nov 2021
    E46
    Having some flex and give in bushings is a good thing. It helps isolate vibrations, bumps, and noise. Polyurethane has no give to it, you will feel every crack in the road. It makes the car just harsh. They squeak, you have to lube them every few years. Most regret installing them.
    One of the worst things you can ever do to a vehicle is polyurethane engine mounts.
  1. 400whp Infiniti G35 vs 350whp Infiniti G35
    By trev0006 in forum Cars, Bikes, Machines
    Latest Threads: 10-22-2007, 10:50 AM
  2. 2007 Infinit G35 AWD vs G35 sport
    By SilverRex in forum General Car/Bike Talk
    Latest Threads: 07-17-2007, 10:27 AM
  3. WTB: Front C-Arm Bushing
    By j_kevin_ca in forum Automotive Parts [Suspension/Handling]
    Latest Threads: 11-03-2004, 10:13 AM
  4. WTB: Subframe bushing set for a 90 240sx
    By teknical in forum Automotive Parts [Suspension/Handling]
    Latest Threads: 10-28-2004, 06:43 PM
  5. FS: TRD Bushing Kit for 86
    By Cueman in forum Automotive Parts [Suspension/Handling]
    Latest Threads: 09-03-2004, 03:28 PM
