Edit: I'm dumbThis quote is hidden because you are ignoring this member. Show Quote
Yep truth. We have one set of shitty doors (in our master bedroom) that open onto a useless balcony. Plastic wrap on this is mandatory in these cold temps, but the rest of the house is triple pane and no issues.
Air exchange will dry your home very quickly without a dehumidifier or anything like that if you want to bring humidity down. I always want to bring my up, so I have stopped running my bathroom fans.
Exactly. Do this and your house will lose humidity really quickly.This quote is hidden because you are ignoring this member. Show Quote
If you have an old leaky house running your fart fans will do this as well at a slower rate. If you have a tight/newer house run the HRV, it'll change air over and dry things out.
And this. If you have moisture issue keep your blinds up and blast with a fan to dry them out. Its all about relative humidty and air movement around the windows.This quote is hidden because you are ignoring this member. Show Quote
Quick note...
Remove any screens on windows that are having ice issues as well.
It will increase air flow and allow the ice / condensation to dissipate faster.
2011 Ram 1500 QC Sport
2017 Jeep Cherokee Limited
That would require me to go outside and shit too cold for that.This quote is hidden because you are ignoring this member. Show Quote
I think he means screens that are on the inside. Outside screens on slider windows make zero difference for ice build up on the inside.This quote is hidden because you are ignoring this member. Show Quote
Right. That type of window.This quote is hidden because you are ignoring this member. Show Quote
HRV isn't going to do shit when the air coming in is more humid than what is inside your house.
You fail science.This quote is hidden because you are ignoring this member. Show Quote
No condensation/ice here, new (since moving in) windows were worth it, double pane but also wallet pain.
I almost said the same thing before I quickly remembered I was a dumbass and forgot the R in RH.This quote is hidden because you are ignoring this member. Show Quote
D'rell on here has reminded all of us that we should use dew point for clarity.
Or just trust me when I say the air outside is dry as fuck.
Nothing is dry if you approach it just right...This quote is hidden because you are ignoring this member. Show Quote
bah, I fail. Too busy at work to devote thought. I should stay off internet.This quote is hidden because you are ignoring this member. Show Quote
Baby monitor says 36%. I should open all the doors?
Z32 TT
1996 Integra - winter beater with studs - RIP (deer)
2002 WRX - to be sold
2010 sti - winter
Nah, that's like 4.5c dew point. Very reasonable, unless your windows suck.This quote is hidden because you are ignoring this member. Show Quote
The absolute humidity inside your house at 21°C and 40%RH is 69-times higher than the Absolute Humidity of that -30 air with 62%RH.This quote is hidden because you are ignoring this member. Show Quote
You almost had me…. LolThis quote is hidden because you are ignoring this member. Show Quote
How are you moist fuckers doing today? Door open 10 minutes will drop some humidity.
About an 1" of ice on all the windows upstairs and about the same are certain windows on the main floor.
People need to stop talking so moistly in this house
