New Deck - Wiring problem, need help... - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: New Deck - Wiring problem, need help...
    Earth
    Vorsprung durch Tecknik
    Default New Deck - Wiring problem, need help...
    I previosly had a Sony Xplod deck, on the back it had the input for 4 wires
    Front - Left - Right
    Back - Left - Right
    The new deck only has input for
    Back - Left Right
    WTF? Do I need a splitter or something? I only have sound coming from teh back...
    Any Ideas?
    May 2004
    Calgary Area
    07 JK, 01 J-body.
    what is the new deck, that would help alot...???
    -mike-
    Aug 2003
    Medicine Hat, AB
    Is a signal going into or out of those wires. If it is in then it is most likely an aux input. If it is out then something is wrong with the wiring harness. EVERY aftermarket Cd player has front L/R and rear L/R.
    I'm somewhere where I don't know where I am...
    That Blue Car
    no if its not amped.
    335i
    Sounds like your stereo needs an external amplifier - on the bright side, all of the highest quality stereos require an external amp. Like mentioned above, you need to tell us what kind of deck it is...
    Original Post NAZI Moderated
    Originally posted by r3cc0s
    Felon or Mistermeiner
    Aug 2003
    Medicine Hat, AB
    I was just assuming it was!
    I, in fact have a Head Unit that requires external amplifaction.
    PLEASE OH PLEASE tell us what make and model it is so i can sleep tonight.
    Earth
    Sony CDX-R3300
    Its amped
    The other deck had both front and rear left and right, the new one only has rear left and right, wtf?
    Feb 2004
    Calgary, AB Canada
    2000 Ford Focus SE
    It has 4X52W amp built in, But it only has one set of pre-outs.
    Not slagging your deck choice, But you should have payed attention and got one with Double or Triple Pre-outs.
    Then you would have Front / Rear / Sub. And you would be able to fade Independently.
    This deck is basically setup to run your amp off of the Rear Pre-outs so All you fading will have to be set up ahead of time on the amp or the crossover
    Get In, Sit Down, Shut Up, Hold On, don't fuck with the stereo.
    And whatever you don't press "THAT" Button
    Press the gallery link to see my ride
    also : Http://www.calgarygasprices.com
    Earth
    ehhhhhhhhhh, I have no idea what you mean. Here is my question. In order to get to to work for the front what do I need to do?
    Also If I where to choose to remove my subs and amps would this deck work with my stock system?
  1. need amp/sub wiring help!!
    By AfroBeav in forum In Car Entertainment / Electronics
    Latest Threads: 02-18-2004, 07:04 PM
  2. Replies: 4
    Latest Threads: 01-01-2004, 03:08 PM
  3. Need HELP QUICK! trailer wiring.
    By Bean in forum Mechanical
    Latest Threads: 08-22-2003, 09:05 PM
  4. Problem with the crx, need help fast
    By redline_13000 in forum Mechanical
    Latest Threads: 08-01-2003, 06:03 PM
  5. Does anyone need amp/subs wiring or a cap?
    By JJLuke in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-03-2003, 02:01 AM
