will downpipe create creep? - Beyond.ca - Car Forums
Results 1 to 11 of 11
Thread: will downpipe create creep?
    Calgary/Cochrane
    cavalier
    Default will downpipe create creep?
    I've been reading around about all kinds of mods to do to my talon, and from what i've read if i put a 3" downpipe and catback on my otherwise stock car (except intake) it will create boost creep. Is this true, and if so what do i have to do to keep the boost from happening?
    Sep 2003
    Calgary Alberta
    ...BNT0B0X...
    if you have left your boost stock, and have only done the BCS mod...you SHOULD be ok...and within totally safe limits...the way to eliminate the potential problem is to port the O2 housing and surrounding area...as well and increase the flapper for your wastegate and port that area as well...check the FAQ's for more answers to most of your DSM related queries...I have included a link...
    DSM FAQ
    ...@therealarifjina...
    Go with a 2.5", 3" is overkill.
    Feb 2004
    Bavaria
    Model 3 Performance
    Honestly I think it varies from car to car. I have seen threads where two guys will have the same mods and one guy will have creep problems and the other guy won't. The only way to find out is to get the downpipe. If you get boost creep try porting the O2 housing and turbo exhaust housing, etc. until you get rid of it.
    Also like 5.9RT said, 2.5" will suffice for the downpipe feeding a 3" catback exhaust. There are varying opinions on this though.
    Apr 2004
    Turbod Honda
    turbo car=you want no back preasure= you get the biggest you want.
    DSM=not a turbo honda=you don't know what you're talking about!
    If Buschar racing can run a 2.5" downpipe and still run 10's then why would a stock DSM need 3"? You're just asking for boost creep that way.
    6.7 CUMMINS, E50 AMG
    Why not just convert to external wastegate?? I welded a turbosmart flange on redec's talon manifold and it turned out fine. Looks good too.
    a van down by the river
    Bmw and ford
    plus that o2 housing is only, maybe 2" even with a 4" downpipe you still have the 2" restriction
    May 2004
    FAT tires
    im running a mandrel bend 3" turbo back with no boost creep issues. My setup isnt stock tho. evo3 16g & O2 housing with ported everything.
    the bottom line is if your wastegate is working/flowing properly you wont have boost creep issues. You will likely have to port it for it not to creep tho.
    As for the O2 housing only having a 2" outlet, well a stock 1G is. An evo3 is 2.5" from the factory, ported its possible to get it around 2.75" (mine measured at 2.65") I also wouldnt call this a restriction in the exhaust as right out of the turbo is a 2" hole (less at the wheel, it makes a cone shape) and the gas is flowing fastest, and can carry its velocity through the O2 housing. If the 2" section was after a 3" section then id call it a restriction.
    Nov 2003
    '13 F150
    Tsi_Neal is correct. 99% of boost creep is caused by a faulty wastegate actuator or a too-small wastegate opening on the turbine housing.
    I'd say put the 3" downpipe and exhaust on the car, but be prepared to have the wastegate opening ported if needed or even to upgrade the flapper to a larger size if the creep is too serious (shouldn't be, lots of people run 3" DPs with the 14B.)
    Calgary/Cochrane
    cavalier
    k awsome thanks
    Brent
  1. Suggestion: Create a FDT section. (read inside)
    By GTS Jeff in forum Suggestion/Comment Box/Forum Related Stuff
    Latest Threads: 12-07-2003, 03:01 AM
  2. Create your own list.....
    By DJ Lazy in forum General Car/Bike Talk
    Latest Threads: 10-28-2003, 08:20 PM
  3. Create your very OWN FART
    By Sky in forum General
    Latest Threads: 12-10-2002, 10:52 PM
  4. Create-a-Ride
    By Ferio_vti in forum General
    Latest Threads: 08-29-2002, 11:42 AM
  5. NEW create a ride
    By MYKN in forum General
    Latest Threads: 05-23-2002, 01:04 AM
