Civic's leaking oil somewhere or burning oil? - Beyond.ca - Car Forums
Results 1 to 14 of 14
Thread: Civic's leaking oil somewhere or burning oil?
    Aug 2002
    Canada
    Default Civic's leaking oil somewhere or burning oil?
    Oct 25: my oil light flash intermittently as I was warming up the car at my work parking lot. Shut off the car, let it sit for a few min and check the oil dip stick. NO oil on the stick. I was like wtf? I did buy 8 bottles of Castrol GTX 5-30 the nite before but I took them out of my trunk. So I walked to Zellers to buy 2 bottles of Castrol GTX 5-30 so I can get home. Put in another bottle of oil. Level indicator at Full.
    Nov 6 (today): check oil dipstick before starting the car. indicator at 1/4 mark between low and full??????????
    Should I get a leak down test done?
    No signs of oil on the driveway.
    The White Ghetto
    Altima Se-R
    that's the same problem i'm having. did u check ur plugs??
    It's probably burning off in your exhaust, sign of rings or seals. Is this the car your friend sold you after driving it for a week? (Maybe this is why he sold it?)
    Aug 2002
    Canada
    Yeah that's the car. No he wasn't my friend just someone that posted an ad in the edmonton journal.
    No i haven't check the plugs.
    Ah, perhaps I'll take it in to the shop and see what's up.
    The White Ghetto
    Altima Se-R
    check the colour of ur exhaust smoke. if it's black or blue, ur burning oil
    Black is fuel (rich), blue/grey is oil, white is coolant.
    '21 F150 Lariat Nardo Grey
    Same thing happened to my car. I'm pretty sure it's the seals!
    oreo cookie
    a wrx.
    coolant...hmm thats the stuff i smell when i turn the heat on!
    335i
    So whats the easiest way to repair piston rings? I hear it's basically an engine rebuild?
    Original Post NAZI Moderated
    Originally posted by r3cc0s
    Felon or Mistermeiner
    Oct 2002
    White smoke can be just condensation, but if the white smoke don't go away after the car is warm, then it is coolant.
    If the valve seals are bad, then you will notice it when you first start the car. It goes away after the car is warm.
    Worn pistons
    Blown head gaskets
    Warped cylinders
    That's all I can think of.
    Replacing pistons rings will take some time, because the pistons has to come out.
    http://www.polepositionproducts.com
    Aug 2002
    Okotoks North
    green smoke, then blue, then red, then yellow means your exhaust LEDs are working just fine!
    Oct 2002
    240sx, 300c, turbo TE72, FG1 Civic, Pilot
    does it smoke alot?
    contact me before wednesday so i can do a compression test or do a visual inspection for leaks.
    Chinatown
    NC1
    Should of just pop on a set of winters and drive the S2k for the winter
    I am user #49
  1. ITR burning above average oil?
    By The Raptor in forum Mechanical
    Latest Threads: 05-04-2009, 10:14 PM
  2. Burning ISO files
    By RickDaTuner in forum General
    Latest Threads: 12-17-2002, 02:08 AM
  3. Burning a MP3 CD
    By [GaGe] in forum General
    Latest Threads: 11-18-2002, 09:39 PM
  4. anyone recomend a place for fixing leaking clutch master cyl??
    By TomTom in forum General Car/Bike Talk
    Latest Threads: 09-25-2002, 05:47 PM
  5. i need somewhere....
    By Illusionsir in forum General
    Latest Threads: 09-22-2002, 01:26 AM
