anyone know how i go abouts testing to see if it's in my comp??
use a virus scanner.
You will have to look thru your registery. Most keyloggers hide install files and also don't show up in running processes or show up in the start menu.
Well it really depends on the type of keylogger.
A "simple" Key Logger normally consists of two files: a DLL which does all the work and an EXE which loads the DLL and sets the hook. The logger is invoked on boot via an entry in your registry -- these ones are pretty easy to find.
But, some of the new gen loggers boast some pretty serioues attributes making them difficult to find and remove. Ie. Stealth mode -- running invisible in the process list.
Because a keylogger can involve dozens of files, and has as a primary goal complete stealth from the user, removing one manually can be a terrifying challenge to the average dude.
I have actually seen some newer ones that re-install themselves before the user reboots after they were removed!
