Fuel Injector Cleaner - Beyond.ca - Car Forums
Results 1 to 12 of 12
Thread: Fuel Injector Cleaner
    Vancouver
    X3 3.0, CLK500, FZR600
    Default Fuel Injector Cleaner
    Any thoughts of this stuff? After how many kms should I use?
    Listen fam, she had a big rack of lamb
    And they caused mad problems like math exams
    Ask my man, her tits caused traffic jams
    Oct 2002
    335xi 70 c10 84 c10 Indian chief
    i heard that it is not good for your engine??
    9.872604, -85.498802
    Turbos n Stuff™
    it makes a minor difference, but your best bet is to clean them manually
    Travel
    '08 Mitsubishi Lancer, '97 GMC Jimmy
    Who knows how good of a job "Fuel injector cleaners" actually do...but i heard that if used alot they tend to dry up seals etc..
    Anyone know of any truth to that? or are they fine?
    Oct 2002
    Moose Jaw
    2004 Mitsubishi Lancer Ralliart
    a lot of them use xylene or toulene so they can dry up seals if they sit in your tank for awhile in a fairly concentrated form (like you have an 1/8 of a tank, dump a bottle in and then don't drive the car for 2 weeks).
    The best way to clean your whole fuel system (without disassembling and doing everything manually) is to dump 4 liters of xylene in with an 1/8 tank of gas and then run the car damn near dry. Fill up fully with gas after to dilute anything in the system.
    ecstasy_civic's Avatar
    ecstasy_civic is offline MMA guru, but still rage2's bitch
    Aug 2002
    08 Si
    from what i understand its only good if you drive at low rpm's, that is when the most carbon or "gunk" is built up on the injector tips. someone like me who likes to rev my car high, i have no worries with injector issues
    335i
    Does anyone know where to get injectors cleaned and balanced?
    Original Post NAZI Moderated
    Originally posted by r3cc0s
    Felon or Mistermeiner
    Vancouver
    hmm mixed answers but better than nothing, thanks guys
    c-town
    AI Servo
    RC Engineering.
    Tuner1's Avatar
    Tuner1 is offline Tunerworks Guru (E36S50B32)
    Jul 2002
    ///MPower, 4x4, Bianchi & Trek
    I see it as inexpensive maintenance/insurance. There is no way a small bottle of quality injector cleaner will harm anything and if all goes as planned/advertised it will help keep your $$injectors$$ flowing well and spraying evenly. I regularly use Redline SI1 and Motul Fuel Sys Cleaner.
    Rob
    ya, that stuff rob sells at TW works nice man!
    http://www.sfu.ca/~joh/teg/fastlane.gif
    Mr. Forex technical
    a tank
    ive heard the same, it somehow forms a seal inside ur engine somewhere so that over time it wont destablelize ur compression ratio. and I think it works best for older cars.. sorta restores hp.. I might be wrong maybe im refering to the wrong stuff. I Waz told maybe after 30k I can start adding one bottle every 2nd trip to the gas pump..
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  1. Fuel Injector Cleaners
    By Zephyr in forum General Car/Bike Talk
    Latest Threads: 02-19-2003, 12:57 PM
  2. fuel injector cleaners
    By Hipermax_d in forum General Car/Bike Talk
    Latest Threads: 02-14-2003, 03:19 PM
  3. Fuel Injector Cleaner stuff
    By GTS Jeff in forum Mechanical
    Latest Threads: 02-12-2003, 01:36 PM
  4. Calgary fuel injector cleaner?
    By Loose in forum Performance Modifications
    Latest Threads: 10-25-2002, 05:41 PM
  5. Fuel Injector Cleaner
    By Davan in forum Mechanical
    Latest Threads: 08-22-2002, 03:29 PM
