Don't use a sponge, and I probably wouldn't use a machine if the spot is that small. If the paint still looks really good (no swirls elsewhere) I would apply a polish by hand to try and lessen the damage from the poo. Use the least aggressive polish first to see if it works, if it doesn't try something a little more aggressive. I'm not even sure what you could find over the counter around here. I saw some professional meguire's products in canadian tire the other day (denoted by numbers like #80,#26,#7) - do some research on those and find out what you need. I've never used those but have heard good things about them. Find a microfiber or foam applicator to apply the polish and don't forget to wax afterwards. And also don't forget to wash really well before you do anything.
Several studies have investigated the relationship between intelligence and the degree of religious belief (excluding humanism), with most showing an inverse correlation between intelligence averages and the "importance of religion" to the testee.
