Got the tires last summer for new rims but sold the rims. 3 of the tires was driven for about 2 months with at ATLEAST 90% left.....1 is pretty much NEW at about 98% because it was replace due to a nail on the older one.
Never seen the track.
Hardly ever driven on it and took it off after I sold the rims.
Ultra High Performance
Performance at an exceptional value. Yokohama innovation strikes again with the AVS ES100. It is uniquely designed to deliver true ultra-high performance looks and handling, plus everyday needs like low noise and ride comfort, at an exceptional value
Excellent Handling - Continuous Shoulder Block Design The AVS ES100's long, continuous shoulder blocks reduce tread squirm and enhance stiffness to deliver crisp, sharp cornering.
Steel Sidewall Inserts - These extra-strength sidewall inserts complement the square casing design for responsive steering and greater control when cornering at high speeds.
Solid Center Rib - The unbroken solid center rib maintains continuous road contact to enhance high-speed stability and traction, while helping reduce noise.
Silica Composite Carbon (SCC) Technology - Yokohama's newly developed silica tread compound delivers superb wet and dry traction. The AVS ES100 is the first tire in the U.S. to incorporate Yokohama's patented Silica Composite Carbon (SCC) Technology. During the compounding process, silica and carbon are combined. The result is reduced rolling resistance, outstanding grip and longer mileage.
High-Traction Groove Design - Two wide circumferential center channels combine with unidirectional tusk grooves to efficiently evacuate water. The compound and tread design work together to help the AVS ES100 attain an AA traction rating - the highest possible.
Rim Protector Bar - The AVS ES100's Rim Protector Bar provides expensive wheels an added protection against curbside scuffing damage.
Stepped Shoulder Profile - Through a unique shoulder design, excess heat is eliminated, thereby reducing rolling resistance and increasing high-speed stability.
UTQG 280
SOLD!
