Suggestion needed - Need 2" hole drilled through concrete into utility room - Beyond.ca - Car Forums
Results 1 to 20 of 20
Thread: Suggestion needed - Need 2" hole drilled through concrete into utility room
    2008 Z06
    Default Suggestion needed - Need 2" hole drilled through concrete into utility room
    I'm having a sink drain run from my garage into my utility room, through a concrete wall, by my plumber. He doesn't have method to drill through the concrete into the utility room. Not sure what the wall thickness is.
    Anyone have a coring bit and associated drill that'd work? Happy to pay something.
    If not, I'm considering buying this and renting a hammer drill: https://www.amazon.ca/Bosch-HC5099-S...ustomerReviews
    Current Cars:
    2004 GMC 2500HD 8.1L
    Past Cars:
    1970 Chevy Blazer, 2wd
    2005 Jeep Wrangler LJ
    1989 5L Mustang
    1990 Jeep Cherokee
    Aug 2004
    You should be able to rent what you need from Home Depot... Drill and Bit.
    Unless you really need a coring bit that big for personal use...
    2011 Ram 1500 QC Sport
    2017 Jeep Cherokee Limited
    Isn't there a possibility this "wall" is foundation and it's >12" thick?
    2008 Z06
    This is the only 2" bit they appear to rent. The issue is I don't think this bit (hole saw) can go any deeper then the bit depth, right?
    https://www.homedepot.ca/en/home/too...max.01137.html
    - - - Updated - - -
    Maybe. The $180 bit at my amazon link at the top is 23" deep, so it could do it, with a strong hammer drill.
    Last time I rented one from Home Depot it was a Bosch twice the size of the one I used when I actually worked in concrete.
    aka fucking enormous!
    What kind of plumber is this guy? He can’t drill a hole?
    Aug 2002
    992 T-hawk Golf R
    https://www.rogersrentall.ca/equipme...key=011%2D0014
    You likely need a hammer drill to first drill a hole to insert a concrete anchor, aka red head, to mount this to the wall.
    I like neat cars.
    Jan 2017
    Summer car or work truck
    You can use what you have shown. Just get a chisel bit too. Drill to depth, break it out. Drill to depth again.....profit.
    Home fepot will have what you need
    Sep 2008
    NE
    Ram 1500, '68 Camaro, S14
    as stated, just rent a hammer drill and fuckin lean into it lol. You don't need that gnarly coring drill above lol.
    https://www.rogersrentall.ca/equipme...key=011%2D0076
    you're not supposed to have any openings between your house and garage though so seal that SOB up with some silicone.
    (i did one at my old house for my garage conduit, and then again for my AC)
    Cochrane, AB
    Trucks
    Having the hole drilled while you drink a beer and watch will cost you $150-200.
    Toilet_X charges way less for similar work.
    2008 Z06
    Quote Originally Posted by JfuckinC View Post
    This is exactly what I'm going to do. Thanks!
    Get good hearing protection.
    For this job or if @Toilet_X helps out.
    2008 Z06
    I'll wear ear plugs + over ear protection. I have it left over from my rural living days shooting a shotgun at the moon (and clays).
    Feb 2003
    DT 780
    LEXUS LX470
    Knock knock. Did somebody say they needed a 2” hole drilled??
    Heh heh
    Tap, Rack, BANG!
    Im used to punching glory holes through stalls at the flyin j, but i think i can take a whack at this. I can provide concrete evidence that i am the man for the job.
    Apr 2004
    Keep a small bucket of water nearby to dip the bit in every once in a while as you drill. Will keep it from getting too hot.
    Only 15min from Aspen!
    Nothing interesting anymore
    The smart kind that doesn't want the legal liability of drilling through concrete.
    Off topic but I remember seeing one of those Vegas reno shows on TV. The flipper wanted to not pay for a concrete scan before cutting into it to build a kitchen island with a sink (needed cuts to run the water services).
    Long story short, I didn't clue in that with no basements and concrete floors, the power sometimes gets run in the concrete.
    The guy cutting the floor would have died. Main power supply to house went right through one of the cut lines.
    Sep 2008
    NE
    lol my stepdad poked a hole in the back of our gas meter once drilling a hole for hot tub cables
  1. Replies: 4
    Latest Threads: 08-04-2009, 06:37 PM
  2. Eric Goes Through The Deep Hole Again
    By porsche2121 in forum Cars, Bikes, Machines
    Latest Threads: 08-17-2008, 01:37 PM
  3. suggestion for the suggestion area
    By rollinv4l in forum Suggestion/Comment Box/Forum Related Stuff
    Latest Threads: 12-16-2005, 11:59 PM
  4. Magnum Cross Drilled Rotors or KVR Cross Drilled Rotors
    By JDM_RS13 in forum Performance Modifications
    Latest Threads: 06-13-2005, 07:51 AM
  5. Drill hole through firewall?
    By custommx in forum Mechanical
    Latest Threads: 06-02-2004, 09:10 PM
