What do you use?This quote is hidden because you are ignoring this member. Show Quote
I'm using a neti pot every second day.
Going through a shit load of distilled water...
Sure. Just so long as you take all the blame if the pill leaves me stoned for the dayThis quote is hidden because you are ignoring this member. Show Quote![]()
With Benadryl, I feel like I can sleep while walking, happened at Disney World last year, luckily there was coffee available
The best ones I've found are the Compliments 24h non-drowsy
Sig nuked by mod.
Co-worker has mild symptoms, got tested on the 15th in Okotoks. STILL no results.
Warm Calgary tap water, a homebrew mix of fine kosher salt and baking soda (3-1 ratio), and one of the neilmed squeeze bottles.This quote is hidden because you are ignoring this member. Show Quote
I think that's a clear sign why they cancelled asymptomatic tests.This quote is hidden because you are ignoring this member. Show Quote
Tap water boiled first I would hope?This quote is hidden because you are ignoring this member. Show Quote
https://www.cbc.ca/news/canada/briti...oman-1.4935966This quote is hidden because you are ignoring this member. Show Quote
I remember reading that, and then another case elsewhere in the world, when I started using the Neilmed daily.
Even with the high quality of our Calgary water, I'm good with the $2 4L distilled water purchases.
Update for @Disoblige we got our results. 24 hours even tho they said 5 days. Back to school he goes!
Basically, nobody knows how long it takes. The last time we did a test (asymptomatic) took 5 or 6 days when they said it'll take 2 or 3.
Thanks bossmanThis quote is hidden because you are ignoring this member. Show Quote
Must be nice. Bet your truck has a sunroof, too!This quote is hidden because you are ignoring this member. Show Quote
#DoubleMeatLife
LoL!!
Definitely dont use straight up tap water up there. I know the chances are slim but boiled or distilled is the way to go.This quote is hidden because you are ignoring this member. Show Quote
you'd think I'd of had some kind of infection in the 5+ years I've been doing this? I mean, when I travel, I use boiled, but here c'mon. Anyway, whatever water you use, start rinsing. That shit will change you life.
You may have had a minor issue or an infection but not always manifest.This quote is hidden because you are ignoring this member. Show Quote
Its not like you will likely get bacteria in Calgary tap water, its a degree of chance. You could do this for 10 years and be fine, and someone else gets immediately sick from having chloramine up the nose the same (irritant).
Sorry but, check your units, you'd be unable to use ammonia based cleaners (windex) or bleach (chlorine) in your house if the quantity of chloramine in a litre of tap water causes you immediate illness.This quote is hidden because you are ignoring this member. Show Quote
That is the same one I use... Works a charm!This quote is hidden because you are ignoring this member. Show Quote
Same as me. Much better than the aerius i was using previously
I know people personally who cannot use most household cleaners because of this exact issue - but my point was that everyone reacts differently to having non sterilized/ common tap water up into their sinuses. Great place for bacteria to proliferate for some (like me) with sinus issues.This quote is hidden because you are ignoring this member. Show Quote
