Rollin back the odometer???? - Beyond.ca - Car Forums
Results 1 to 20 of 35
Thread: Rollin back the odometer????
    Dec 2002
    Calgary,AB
    A Pearl Diamond
    Default Rollin back the odometer????
    If you find a car for sale and the kms seem too low how can you tell if it's been rolled back??? Is there anyway to find out?
    Carfax would give you some info on history. I would find out what dealer the guy used for service, get a service history and look for anything suspicious.
    oreo cookie
    a wrx.
    shaky speedo, how the car feels...
    i also like to look at the wear on the drivers seat...
    Jul 2002
    also look for wear on the pedals and steering wheel.
    Calgary ALberta
    WIP
    If anything, I'd try and see if there are any service records for that car. I have no idea how you would find them, maybe the registry or even call up a few service depots where the guy has been and see if they are on file. I would assume that they usually keep a record of when the car was serviced, as in how many clicks.
    Other than that, I don't think that there is any way to really tell.
    335i
    The easiest way to tell is that most numbers don't line up - but thats not the only indicator. Sometimes, a speedometer will shake as it moves up, indicating your speed. This, in turn with the unaligned numbers, is a dead giveaway that the km's have been rolled back. Another way is to check with carfax and your local registries to see whether the vehicle was ever registered with a higher km reading.
    Original Post NAZI Moderated
    Originally posted by r3cc0s
    Felon or Mistermeiner
    Seattle, WA, USA
    1995 Nissan 240SX
    hey how would a speedo's shaking have to do with numbers being rolled back? i dont quite understand the connection here..
    max
    240 ka-t
    oreo cookie
    a wrx.
    max
    when u fuck around with the dash(ie disconnecting it), then shit goes wrong (ie needle getting fucked).
    also, if u notice that the speedo needle and the rpm needle dont sync up the same way everytime u drive the car, theres another clue that the dash was tampered with.
    lammer Guest
    what if your installing indiglo gagues or some shit? does it still wreck your needles moving in sync and thus being called for the "rolled odometer"?
    ...searching
    I think newer odo's (obviously non-digital) would produce a red line across the numbers if they are rolled back....not positive on manufaturers or year they started though. Check all the dealerships of the make to find out thru the VIN # if it was ever serviced, compare dates and numbers
    335i
    You'd be surprised. Many manufacturers don't do this. Everytime I go to the wreckers, I take out a gauge cluster and play with the km's. They are surprisingly easy to roll back.
    Jun 2003
    CALGARY
    92SiR, 05B5G, 89KA24
    the numbers would not line up perfectly,
    Sometimes there is a seal that you would have to break to get at the numbers as well. But unless you knew the seal was there in the first place...
    Feb 2003
    94 VW Golf
    my car does that all the time and i know it hasnt been rolled back
    330 000km
    and i have a golf that the numbers dont match up because it is on the verge of switching numbers
    based on this i dont think you can find out if it has or not
    Jun 2003
    OC
    '02 Toyota Tundra
    I think my truck they rolled it forward lol ... well that would explain 43k miles in 1 year
    Jun 2003
    330 000km
    Most newer cars have the red line through the numbers if you try and fuck with them. Weapon_R says everytime he is at the junkers, he grabs a gauge cluster and plays with the kms, but how many newer cars have you done this with? In fact, I'm not 100% sure for Canada, but there are laws around that require manufacturers to install "anti-cheat" devices, such as the red line, to combat this fraud, which is what it is, criminal fraud.
    Jul 2002
    just a few months ago there was a special on that consumer reports that calgary 7 has at lunch time, and a guy was showing how easy it was to roll back the kms on a truck that was mainly used for driving back and forth from calgary to edmonton. it was like a 99 ford pickup, and the guy said by rolling down the kms with this pickup he could increase the value anywhere from 10-20 grand. so i am sure its possible on newer cars. also, when my dad was looking for a minivan, we went to some fob dealership and we were going to test drive a odyssey, until we noticed the kms were exactly at 100 000.
    Built not Bought.
    Jun 2003
    Doesn't mean that they were tampered with tho, could simply be crazy coincidence
    Dec 2002
    RX
    jus wonderin...........what are the fines, if someone does find out that u rolled back the odometer?!?.........or is there even a fine?
    so if u bought a car that later on u found out that it has been rolled back...........what do u do?.....jus gotta put up with it or what?
    thx
    dog sled
    Shaky speedo means thats theres a problem in the line to the tranny or the tranny it self, it never has anything to do with the cluste itself
  1. I got my rims back!!
    By Pete92SL in forum Cars, Bikes, Machines
    Latest Threads: 07-18-2002, 03:54 PM
  2. I'm back-here's my vacation pics
    By Ekliptix in forum General
    Latest Threads: 07-08-2002, 09:47 PM
  3. WTB 92-95 civic coupe cat-back exhaust
    By Ed the SOHC in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 07-05-2002, 05:01 PM
  4. Boost is Back in Town!
    By max_boost in forum General
    Latest Threads: 06-27-2002, 02:59 PM
