what if you opened the xbox up and swapped out the board and then returned it to walmart
The serial number is viewable through the box on the actual console. So this will not work. Microsoft isn't that dumbOriginally posted by anarchy
That's not the issue. When you purchase the xbox from walmart or whatever retail place, they'll scan the outside of your box. These guys are suggesting switching out the xbox, and when they return it, its still the same outside of the box that'll be scanned. but what the employees are supposed to do is check to make sure the serial number on the box matches the one on the console, and natejj was saying they are usually two lazy to do that.
If you switch out the casing and put the good serial number back into the box it'll work
Original Post NAZI Moderated
Originally posted by r3cc0s
Felon or Mistermeiner
sure that would work if the worker is stupid to not check the warranty sticker when you take the face plate off. You take that case apart there is a good chance your going to break the warranty seal. A friend of mine is a Walmart manager and he told they're starting to do that. I don't even know why you guys are even discussing this fraud.Originally posted by Weapon_R
