I'm using a linksys BEFSR41 4 port router
how do i setup the proxy setting so i can use ICQ or some other P to P programs to transfer files?
is there a website that kind of teach or explain about this topic?
我係阿仔
you can either choose to DMZ your computer specifically or disable the firewall completely and expose yourself effectively turning your router into a simple switch - those are the methods I remember anyways.
I believe that the linksys site has a FAQ on this one - they'd be the best to answer questions. I had the BEFSR41 a while back, but I've moved just a workgroup switch since and have firewall duties handled by a standalone symantec unit.
I just findout how to setup ICQ but is there a site a can learn about this? because the site i went to just show you how to setup the ICQ but there is no explaination on why and what number represents what!
我係阿仔
DMZ Host
The DMZ Host setting allows one local user to be exposed to the Internet to use a special-purpose service such as Internet gaming or Video-conferencing. To expose one computer, enter the computer’s IP address and click the Apply button. Inactivate DMZ by entering a zero (0).
http://www.linksys.com/support/support.asp?spid=1#adv
ummm what's the site? I might be able to help you with the config, but I haven't used ICQ in years so I'd be doing it blind
If you set up the port forwarding properly, you don't need to DMZ your machine (because that would defeat the purpose of having the firewall in the first place). The trigger port for ICQ is TCP 5190, then set the open ports to whatever range you like. Make sure you set the same range in the ICQ setup as well. Post a screen shot of your firewall configuration screen and I can probably help you figure it out.
Thank You for your reply! but I don't understand "choose to DMZ" and how to "disable the firewall" or how to "turning your router into a simple switch".
我係阿仔
I followed the instructions from Linksys's FAQ, but the default IP seems not working! what can i do T___T god help me!
4wheeldrift - I notice you drives a 2.5 RS do you know anyone that could do a STi swap for me? i know there is a subaru specilist on 32nd ST N.E. but they don't do Turbos!
我係阿仔
I don't know who could do that in town, I don't know of anyone having done that kind of swap in calgary. Head to the canada forum at nasioc.com and ask around there, someone else might be able to answer it for you.Originally posted by winson2001
Here's a site with some excellent FAQS on configuring ICQ to work with port forwarding, and setting up your router.
http://www.tuneld.com/
Thank You people! I kinda figure out how to play around the firewall!
我係阿仔
