*risks of doing shisha/sheesha/hookah* - Beyond.ca - Car Forums
Results 1 to 20 of 33
Thread: *risks of doing shisha/sheesha/hookah*
    Default *risks of doing shisha/sheesha/hookah*
    So like a lot of people i do smoke shisha on a regular basis, but i was just sitting here thinking what the the major effects or if they're are any. So i went to google and started looking. From what i know shisha is better for you than cigarettes, it has 99.9% less tar and 95.5% less nicotine. Well anyways as i was looking through the internet i seemed to come across may articles that say shisha is the same if not worse as smoking cigarettes. Why?
    Well for one if you use just your household foil that has a chemical layer on it and when it burns due to the coal it causing and increase in getting cancer.
    so this is from one of the news articles "the aluminium foil, which is usually of poor quality, reacts with the burning charcoal and produces aluminium fumes that are carcinogenic or in other words causes cancer"
    also in another article it states that the amount of carbon dioxide inhaled through shisha is very high compared to cigarette smoking, adding that one shisha smoke is equal to seven or 10 cigarettes depending on the packed ingredients.
    and also that when smoke goes through water humidity in smoke increases and it then tends to stay for a longer time in the lungs. Some germs, mainly bacteria that cause tuberculosis, live in the shisha pipe.
    Anyone here want to clarify if the information i been reading is wrong or maybe even just hyped up a little bit.
    Yes i do understand smoking is smoking and there is always the chance of cancer, just i didn't think shisha was this bad?
    Jun 2004
    its true, shisha is as bad if not worse
    May 2009
    My Car
    shisha is just a normal thing that was passed down threw arabic generations, it's worse then smoking, 1 head of a shisha is 1 pack of smokes or was that half i dont remember
    but i always thought there was less tobacco and nicotine in shisha? so therefore wouldn't the chances of getting cancer be less and also wouldn't this make it better than just smoking ?
    May 2009
    My Car
    its the same and even more worse, the diff is that shisha tobacoo has flavors, apple apple, mint, and alot of other frute flavoresclick for larger version
    72 Virgins
    I heard that you can't get a girl pregnant if you jerk off three times before fucking.
    Anyone here want to clarify if the information I've read is wrong or maybe even just hyped up a little bit?
    Originally posted by Spoons
    I can't even count the amount of times I took a pill with meth, heroine, speed, you name it laced with it. You gotta be careful.
    Aug 2008
    09 WRX
    First of all, smoking anything at all is obviously bad for you. Doesn't matter what you're smoking. Second, Nicotine and Tobacco are not the only carciogens associated with smoking, there are a ton of additives in each one tha gives you the buzz, and makes it burn slow, and those are the real bad things.
    May 2009
    My Car
    ^^^ WEED lol
    Calgary AB Canada
    M5 Competition
    Any type of smoke you inhale is very bad for your lungs. Its common sense.
    Sit in a room that is constantly filled with smoke with no fresh air, regardless of the source, you will die pretty damn quick...lol.
    its 4 times....in her bum
    89coupe is right ... Smoke is smoke, none of its good for you.
    Since thats the case, if your going to smoke, fuck the shitty buzz/recent hype of Shisha and smoke some good Weed.
    Aug 2008
    The YYC
    Mitsu Lancer
    the only difference is the smoke is thinner due to the water filtering.the lighter the smoke the longer it stays in your lungs. Otherwise its almost the same. smoking is smoking.
    still love it tho..!
    08 Civc LX, 03 Durango, 11 Duramax
    WHAT ABOUT WEESHA GUYS ?
    -the internetz says its good for yous.
    Depends if you get the tar free + nicotine free shit, which is slightly less bad for you. But smoke in your lungs is gonna be bad for you either way.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Default Re: *risks of doing shisha/sheesha/hookah*
    so how does this differ from using tin foil on the bbq? or oven?
    PSG / LA
    B5 S4, UrQ, UZJ100, 990 SMR
    Ingredients in my Al-Fakher shisha: Tobacco, Molasses. Not seeing any of these additives. The number of carcinogens is very dependant on the temperature that something is burned (or vaporized). I'm working on a heating element/bowl combo that plugs in and eliminates the need for a coal. In theory it'll work pretty similar to a Volcano, but minus the air pump.
    Originally posted by InRich
    Default Re: Re: *risks of doing shisha/sheesha/hookah*
    Srsly?! Because your not inhaling chemicals from the tin foil when its in the oven or on the bbq, your cooking with it.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Default Re: Re: Re: *risks of doing shisha/sheesha/hookah*
    and those chemicals go where? oh into your FOOD... that you eat...
    yes i do no that.. if you read the whole thread it clearly state that smoking is smoking.. i just thought that shisha wasn't as bad
    May 2009
    My Car
    ^^ Man who cares lol u only live once on this place called earth enjoy it
  1. Where to buy a hookah or Shisha
    By nit78 in forum General
    Latest Threads: 06-03-2011, 01:56 PM
  2. FS: Sheesha Hookah And Tobacoo [CHEAP!!]
    By al3 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 10-14-2007, 11:29 PM
  3. Fs: Herbal Shisha For Hookah!
    By X-mas in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 04-08-2007, 07:00 PM
  4. WTB: 2 or 3 hosed hookah or shisha bong
    By cycosis in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-24-2005, 02:51 AM
  5. FS: Shisha hookah
    By custommx in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 06-22-2004, 03:48 PM
