laptop to LCD tv issues - Beyond.ca - Car Forums
Results 1 to 7 of 7
Thread: laptop to LCD tv issues
    Oct 2006
    Parked in Baygirl's garage.
    '21 F150 PowerBoost
    Default laptop to LCD tv issues
    Alright, using a new last year laptop, and trying to connect to my 52" LCD 1080p 120hz tv.
    My issue is that when I do connect, my display adapters won't let me fill the LCD screen, and what does show on there, is off color, everything has a pretty bad green hue to it.
    this happens no matter if I use the S-video out to a component into the tv, straight s-video, or if i use a VGA connection.
    does not seem to be any settings that I can find to change things up, was hoping someone could offer up some ideas.
    i guess for referance i am using a Compaq Presario A900 and the tv is a Toshiba 52XV545U
    thanks guys
    Boosted life tip #329
    Girlfriends cost money
    Turbos cost money
    Both make whining noises
    Make the smart choice.
    Originally posted by Mibz
    Jan 2006
    Axis powers
    things to check
    default resolution of the screen, can you stretch the image to make it fit
    try the laptop with another screen
    try the tv with another computer
    Sig nuked by mod.
    Most HDTV's don't support SVGA resolutions, which is why you're having the problem. I've only seen a handful of HDTV's (mostly larger monitors that double as TVs) that can do it properly.
    Really, your laptop needs to support 1920x1080 or 1280x720 to get it fit right, and even then, you'll get overscan issues, unless your TV can map 1:1.
    For my media center, I specifically went for a HDMI video card that can do 1920x1080 60hz to make it work properly on any HDTV.
    May 2004
    New York
    Subway / Rav4
    I have the exact same TV. Initially I was using a S-Video cable which was great for a couple weeks, then everything turned B&W. Switched over to a VGA cable and its crystal clear.
    I had similar issues to yours. What you might want to try is to switch your display (on the laptop) from 'Dual Screen' or 'Clone' to 'Single' display and pick 'Analog'. Make sure your tv input is on 'PC' (9, i believe) before you try this, as my laptop only allows a 10 second window to accept changes to an external monitor.
    "Having a war about religion is like having a fight over who's got the best invisible friend" - Yasser Arafat
    Oct 2006
    '21 F150 PowerBoost
    Thanks rage, do you happen to know the model number of your vid card? I am debating just building a PC dedicated to being a media center.
    Turbos cost money
    Oct 2006
    '21 F150 PowerBoost
    thanks man, I will give that a try tonight and see what happens.
    Turbos cost money
    Any video card with an HDMI port will be able to output HDMI 1080i/p and 720p resolutions.
  1. issues with laptop LCD screen
    By nonlinear in forum Computers, Consoles, and other Electronics
    Latest Threads: 06-17-2009, 06:34 AM
  2. Laptop issues
    By bashir26 in forum Computer Help Desk
    Latest Threads: 04-19-2009, 01:38 PM
  3. Lcd screen issues.
    By Thaco in forum In Car Entertainment / Electronics
    Latest Threads: 03-22-2007, 03:12 PM
  4. Laptop issues
    By ddmmak in forum Computers, Consoles, and other Electronics
    Latest Threads: 11-20-2006, 05:45 PM
  5. Heat expansion issues with laptop?
    By Xentric in forum Computers, Consoles, and other Electronics
    Latest Threads: 12-14-2005, 12:09 PM
