The question of whether to use a bank vs. a mortgage broker seems to come up every few weeks and this might help those that are unfamiliar with the pros/cons of each. .
BANK SPECIALIST
This would be the person you would use if you went to your local TD/BMO/RBC e.t.c. (Some of them even can come meet you...mobile specialists I believe)
Advantages
Convenience/ease of viewing current mortgage balance:
If you already do your banking with the bank you are seeing, then you have one central location for all your banking/mortgage financing needs. You can view balances online with the rest of your statements and such.
Mortgage might make you eligible for more perks/features with the bank:
As an example, RBC may waive the monthly account fees (for your ATM transactions and such) if you have a mortgage, visa and chequing account through them. You are also building a relationship with a bank and they do have lots of services that you may need later on, auto Insurance/ property insurance e.t.c
Possibility of less paperwork when applying for the mortgage:
If you plan on using the bank you already bank with, then they already see your direct deposit pay stubs and any other assets (rrsp's, saving...e.t.c). They would not require you to provide them with the info. This is a minor pro, but still a pro.
Disadvantages
Banks posted rates are typically higher than the competition:
Usually you have to negotiate with a bank; they don't come out firing with the best rate available. It is possible that they'll match what you get elsewhere...but why should they make you go shop for the best rate?
Bank Specialist works for the bank, NOT for you:
The bank specialist is employed by the bank and is looking out for the banks best interests. The specialist might also try convincing you to add on other of the banks products. I could go on about how much of a negative this is but I'll leave it at that.
You will need a separate credit check for each bank specialist you plan on visiting:
This is a minor negative, but still a negative. Also, if one bank disapproves you, then you will most likely be wasting your time by visiting other banks, thus possibly minimally affecting your credit score.
MORTGAGE BROKER
This would be the person helping you if you went to a mortgage brokerage office. Typical names that might be familiar are The Mortgage Group, CanEquity, AlbertaMortgageCentre..e.t.c
Advantages
Mortgage Broker works on YOUR behalf:
The broker is independent of the lending institutions and has no ties to any of them. The borrower can be confident that they are receiving the best rate accessible by that particular broker. There is no need to negotiate and wonder/ponder if you received the best possible rate.
Mortgage Broker has access to many lenders:
This is pretty simple, based on the information collected the broker will know which lending firm would be able to best cater to the individual. Some lenders like first time buyers, some like investment borrowers, some like sub-prime applicants e.t.c
Better access to your mortgage broker, most are available 24/7:
Most banks are your typical 9-5, but with a broker most are available pretty much any time. Kind of like a real estate agent.
I'm not sure how the bank mobile specialists’ work, but they may also be available 24/7.
One credit check:
The broker only uses one credit check and does not need to request multiple records for each lender that he decides to submit your application to.
Training:
Mortgage brokers usually undergo a much more rigorous training in order to be legally allowed to sell mortgage products. There is a governing body and there are rules/guidelines that have to be followed. Mortgage brokers also work with multiple lenders and should be knowledgeable in products offered by the various lenders they use.
Disadvantages
NoName/Unknown, Too many small/independent Brokerages:
There are very many mortgage brokerage companies out there now, some have no actual offices and have been in business for very short periods of time. This could be a concern incase complications happen two or three years after you have bought a house. Ideally you would like to have a well established company handling your biggest purchase.
Just ensure you do your research on the mortgage company you plan on using.
The other disadvantages of a mortgage broker are the exact opposite of advantages to using a bank specialist.
You would have to go to a separate site (possibly email or call the mortgage company) to get up to the minute balances. This is more of an inconvenience than a disadvantage.
Most banks now have many non-banking related products, auto/property/travel/health&dental insurance. There may be discounts available if you have your mortgage and everything through them. Although, there are very knowledgeable mortgage brokers who can point you in the right direction for all your other needs.
I will update this if I can think of anything else, hopefully it is unbiased. If not, mods please advise me and I’ll make the recommended adjustments
Bemnet
