09 Jeep SRT8 - Page 7 - Beyond.ca - Car Forums
Page 7 of 9 FirstFirst ... 6 7 8 ... LastLast
Results 121 to 140 of 169
Thread: 09 Jeep SRT8
  1. #121
    May 2004
    Red Deer, Alberta
    2009 TT Jeep SRT8
    i run a turbo smart ebc thats just done off a switch and with how it lets boost hit on the cavy, its not that great for overall power delivery its nothing then everything, a different controller would driving it night and day with ramp rates/gain.
    thats why with that experience im currently looking at the new greddy profec/ams500 or even a boost leash (heard it needs c02 indefinitely to work though)
    i dont want to take away from how smooth/linear the power of the jeep is right now and why id rather spend a bit and have a controller that can bring boost on possibly sooner and with control. the jeep is just like driving it stock until you finally put your foot in it and i enjoy that part of it
    Big 5000+lbs brick, a couple of 67mm turbos and a heavy foot......... now a best of 9.19 @ 152mph
  2. #122
    May 2004
    Red Deer, Alberta
    2009 TT Jeep SRT8
    *** got an email that my driveline parts (flexplate/converter/tranny/tranny cooler/axles showed up on friday and will be getting installed asap. hoping my B&M extra capacity tranny pan clears the exhaust but time will tell.
    2013's setup will be stock 370ci 6.1 thats bone stock aside from a 180* thermostat running 11ish psi, 2 step, fuel system, flexplate, stall converter, built transmission, wavetrac lsd with axles and PML extra capacity diff cover.
    im gunning for a consistent 10 second passes with a tranny that can hold the power and being able to get out of the hole with the 2 step/converter. prior to the combo i couldnt brake stall/build boost at all and was running stock 60fts so i should be good to drop almost a half second there even with not upping the boost. im hoping to be able to a couple runs without being booted but we know how that goes. im already in the works for a roll bar thats not intrusive and still allows rear passengers and the safety requirements to be met
  3. #123
    Dec 2008
    Unit 91 come in 91
    Very nice.
    Always loved these jeeps deffs on my to own list one day
  4. #124
    May 2004
    Red Deer, Alberta
    2009 TT Jeep SRT8
    Originally posted by Shlade
    Very nice.
    theyre great, well i love mine anyways but watch out with mileage/maintenance, stock i got maybe 525kms/tank of fuel on the highway and around $90 to fill up
  5. #125
    May 2004
    Red Deer, Alberta
    2009 TT Jeep SRT8
    aug 30th track day for new pb's of et and mph
  6. #126
    May 2004
    Red Deer, Alberta
    2009 TT Jeep SRT8
  7. #127
    Aug 2013
    ab
    what a sleeper... impressive for sure
    11.5x @ 12x ... ?
    couldnt really see clearly in the video
  8. #128
    May 2004
    Red Deer, Alberta
    2009 TT Jeep SRT8
    11.52 @ 122mph.
    wish it wouldnt have gone down, last run in the vid something let go and still did a 11.98 @ 94.xx mph.
    need a boost controller so boost can hit harder and ramp up quicker but even then its not too bad.
  9. #129
    Cochrane, AB
    Trucks
    Originally posted by LAFNGAS
    11.52 @ 122mph.
    A 75 shot does wonders on mine for boost off the line. Good runs with lots more potential.
  10. #130
    May 2004
    Red Deer, Alberta
    2009 TT Jeep SRT8
    dont need anything for off the line, i got that covered with the 2 step, even without airing the tires down i got 1.60's which isnt bad, the 1.5x will come just need to see wtf happened first and go from there
  11. #131
    May 2004
    Red Deer, Alberta
    2009 TT Jeep SRT8
    disappointed with the start of this year, sent my manifold for some work for the 90mm tb however ups yard saled it and broke it to all hell by snapping one of the fuel rail mounts off of it and then it actually cracked the flange which would be sealed by the intake gasket. had to buy a new core and should have it by the end of the week then its off for powdercoating and then reinstall.
    with that said, all the jeep is getting is a proper boost controller and setting it to 8psi for pump gas, will jump it to 12-14 with race fuel and having a proper pcv system built including a breather can to help with any pressure on the crank case, might look into a vacuum pump to aid in helping that as well
    should be a fun year once its back together and cant wait to disappoint some people locally
  12. #132
    Cochrane, AB
    Trucks
    Dude, that sucks. Do you still have the broken manifold?
  13. #133
    May 2004
    Red Deer, Alberta
    2009 TT Jeep SRT8
    broken manifold is in texas at the ups facility for my claim
  14. #134
    May 2004
    Red Deer, Alberta
    2009 TT Jeep SRT8
    so i got a tiny bit of an update, manifold all finished up and going back together, still have a massive list of little things i need to do though
  15. #135
    May 2004
    Red Deer, Alberta
    2009 TT Jeep SRT8
    little 2017 update:
    put in a built engine, swapped the 6262's to the bigger 6766's and on 8psi ran a best of a 10.71 @ 127mph. Unfortunately found out that my converter was a bit too loose and it wouldn't lock up so couldn't add more boost or run any faster
    here's my 10.91 @ 124mph run, didn't get a video of the 10.71
    got a couple things sorted out and see what 2018 brings
  16. #136
    Aug 2004
    Edmonton/Calgary
    This and that.
    It's a beast! Nice job with it.
  17. #137
    Dec 2008
    All over
    CAEB, 6G72
    Nice! Good to see it's still around and doing well. I used to see it cruising around Red Deer, and at the car show back in the day.
  18. #138
    May 2004
    Red Deer, Alberta
    2009 TT Jeep SRT8
    still have it, won't be going anywhere
  19. #139
    Oct 2011
    Lotus Land
    G37X
    So awesome that you still have your SRT8
  20. #140
    May 2004
    Red Deer, Alberta
    2009 TT Jeep SRT8
    so far 2018 has been some tweaks and getting everything sorted out.
    the 10.71 @ 127mph on 8psi was done with..... passenger wastegate stuck open (now fixed), converter not locking up as it was too loose (swapped to a superpro transmission and the much tighter converter), couple pre turbo exhaust leaks (fixed)
    also for 2018 i installed a scavenge pump and a reservoir for the oil to drain into. that has stopped any smoking/oil issues thus far as with the stroker, we removed the oem piston squirters so oil pressure went up a tiny bit.
    for peace of mind and with E85 looking like it might be available more, im also swapping my dual fuel pump Fore hat to a triple pump loaded with 3x 450lph pumps
    ready to finish up tuning and make some passes on double digit boost and get deep into the 10's and still hunting for that 9 at the end of the day
  1. Jeep Srt8 on Nitrous
    Latest Threads: 01-06-2009, 12:28 AM
  2. FS: 2007 Jeep SRT8 !! not an 06
    By NewLextasy in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 10-06-2008, 11:22 AM
  3. FS: 2007 Jeep Grand Cherokee SRT8.. financing available!
    By nbaker00 in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 07-15-2008, 02:51 PM
  4. FS: 2006 Jeep SRT8
    Latest Threads: 06-18-2008, 10:48 AM
  5. Fs: 2006 Jeep SRT8
    Latest Threads: 05-21-2008, 12:24 AM
