what did you do around the house today? - Page 73 - Beyond.ca - Car Forums
Page 73 of 158 FirstFirst ... 63 72 73 74 83 ... LastLast
Results 1,441 to 1,460 of 3157
Thread: what did you do around the house today?
  1. #1441
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    Anyone know of a store that's based in Canada that's similar to superbrightleds? Been meaning to do some under-cabinet lighting. Or if anyone has any specific recommendations on strips, I do have two longish areas that would require the use of extender cables though(approx 1.2m each)
  2. #1442
    You can hack together the IKEA Ledberg strip lights for very cheap and with minimal hassle. 60" runs without swapping the driver, and much longer with the bigger driver they also sell. Not as many options as other kits, but a dead easy modular system.
  3. #1443
    2020 Subaru Forester Sport
    Built a BBQ cover....aka Cat Escape Prevention. One of my cats used to jump on the BBQ and then over the fence, not anymore! She can't jump that high but gave me a few scares before, so this was built Indoor cat...has no idea how good she has it!
  4. #1444
    Not sure that’s going to really stop a motivated cat... but looks great.
  5. #1445
    Beauty cay ladder
  6. #1446
    Bunch of Honda's
    Wrapped up the garage painting on Friday. Glad we ended up painting ourselves, got lots of practice for painting inside the house now. Cutting the ceiling/walls 12'-14' up sucked. And rolling the 14' ceiling was no fun but the rest was pretty easy and quick.
    Now we're onto lights, shelves and tire racks.... then floors.... then cabinets.
  7. #1447
    Stampede Central
    is pretty sharp lookin'
    Would you recommend just paying to rent scaffolding next time?
  8. #1448
    Bunch of Honda's
    Probably not. I bought an extension pole to paint the walls/ceiling (which actually worked quite well). The scaffolding would have been nice for cutting in the corners but that's it. When I was rolling the ceilings I mostly walked back and forth on the floor which wouldn't work on scaffolding.
    Edit: also this thing was a great investment for hauling paint up/down the later for cutting
    https://www.homedepot.ca/product/woo...ail/1001186566
    click for larger version
  9. #1449
    06 S2000
    Garage looks great. I wish I had that much real estate.
    My car sounds like shit.
  10. #1450
    Only 15min from Aspen!
    Nothing interesting anymore
    Playing in the dirt.
  11. #1451
    Jun 1987
    SK
    Fit Dugan Signature (2016)
    Quote Originally Posted by Ekliptix View Post
    Filled up.
    @Ekliptix what was the purpose behind it?
    Originally posted by SJW
    Originally posted by snowcat
    ^^ Fact Checked
  12. #1452
    Jun 2007
    ATS, XC90
    Do you have 2 versions of the same ladder, or did you catch it in 2 different spots in the pano? Because it would be hilarious if you had 1 ladder and moved it each time so it looked like you had an entire roomful that you used to do the painting.
  13. #1453
    Bunch of Honda's
    Quote Originally Posted by Doozer View Post
    There was most definitely 2 ladders and they're not the quite the same.
  14. #1454
    Jun 2007
    ATS, XC90
    Well they're awfully close. Too bad, lost opportunity there.
  15. #1455
    Bunch of Honda's
    One is slightly shorter then the other. Ask me how tall the taller on is.... exactly the height of the dropped beam.
    And how many times did we smash it into the beam while mudding, sanding and painting... >5 times
  16. #1456
    Aug 2011
    Strathmore
    2005 Dirtymax
    So I have a outside tap that is completely frozen shut and can not be used. I went into the basement to start looking for a shut off valve and eventually found it. But the issue is this awesome maze of plumbing.
    There are two lines feeding the outside taps and there is only 2 shut off valves for the water lines.. shut off #1 is the main feed into the home and shut off #2 is the small valve that you see.
    So I can turn the water off to 1 tap outside but to turn the water off to the other tap I would have to shut the main water supply off.
    Looks like I'm going to the school of learning how to crimp pex successfully.
    Name:  water lines.jpg
  17. #1457
    Apr 2006
    2011 Ralliart SB
    Had an electrician buddy in to help beef up the lack of outlets in the garage. Only 2 in the whole place origionally. Also had amazon next day some 40W led 5k light bars to replace 2 single construction lights in there.Name:  20200622_210246.jpg
  18. #1458
    N/A
    Quote Originally Posted by colsankey View Post
    Garages, they are never big enough.
  19. #1459
    Quote Originally Posted by speedog View Post
    As someone with an 800 sq.ft garage I agree. I wish I had an attached double for parking in, and then my alley triple could be the shop/storage
  20. #1460
    '14 Taco
    nvm
  1. What did you do to your car today?
    By 6Speeder in forum General Car/Bike Talk
    Latest Threads: 01-09-2018, 09:39 PM
  2. What did you do to your FoST/FiST/Fusion today?
    By RedApe in forum Ford ST Owners Club
    Latest Threads: 06-21-2015, 09:33 PM
  3. What Electronics did you buy 10 years ago ? and which do you still use today?
    By thetransporter in forum Computers, Consoles, and other Electronics
    Latest Threads: 11-01-2012, 07:45 PM
  4. Did you have turkey today?
    By Awd-Tsi in forum General
    Latest Threads: 10-11-2010, 04:49 PM
  5. Replies: 27
    Latest Threads: 11-13-2004, 05:25 PM
