Solar Panel No Power - Beyond.ca - Car Forums
Results 1 to 5 of 5
Thread: Solar Panel No Power
    Jan 2007
    CALGARY
    Default Solar Panel No Power
    Last night I purchased a coleman 20 watt 1.5 amp solar panel.
    Used the voltage meter and was working great 15.83-16.73 when sun was going down.
    With a voltage meter this morning I'm only showing 1 on the display
    Having the voltage meter at DC 20
    Plugging in my radar detector into the panel the detector works!
    What am I doing wrong?
    Clearly the panel is working as its powering my detector but yet can't read the power.
    Hook my voltage meter to a car battery and it works fine.
    Sometimes you have to take a chance, whether that be on someone, or something!
    Jan 2007
    CALGARY
    Figured it out, the panel is only spose to be putting out 20 watts but its actual is 23.4 no you need the volt meter to be on 200DCV NOT 20 DCV
    Nice detective work. Funny how the little things can cause us the most grief.
    Mar 2008
    Busa
    You're mixing up voltage and wattage. Most 12v solar panels will provide an output voltage between 16v and 20v+. Obviously your panel was putting out more than 20 volts and the voltmeter reported an overflow when it was on the 20v range.
    The good news is that your solar panel is performing really well. The amp rating on the 20-watt coleman panels is 1.17, which means you could actually be seeing 27.4 watts.
    Also, you should not plug accessories directly into the solar panel. The variance in the voltage can kill many devices. It's recommended that the panels be connected to a battery bank through a charge controller, and that any devices be connected down stream of the charge controller.
    acura TYPE A
    I have a 2000 watt solar sharp system, (it provides 36volt out DC) once its connected to an inverter, (AC ) the max watts I can draw in DC on a sunny day is about 700 watts- Which is a great! .
  1. Solar panel roads trial in Calgary
    By speedog in forum Society / Law / Current Events / Politics
    Latest Threads: 11-29-2016, 12:23 AM
  2. Elon Musk... world biggest solar panel company...?
    By Toma in forum Society / Law / Current Events / Politics
    Latest Threads: 06-21-2014, 10:45 PM
  3. Alternative Power Sources (Solar Power)
    By Gorilla in forum General
    Latest Threads: 11-13-2007, 12:07 PM
  4. Replace Civic 96-98 heater control panel with 99-00 panel, need help
    By snow_daniel in forum General Car/Bike Talk
    Latest Threads: 09-07-2006, 12:05 AM
  5. solar panel battery charger
    By pyro in forum General Car/Bike Talk
    Latest Threads: 02-25-2005, 03:31 PM
