Hi, Im looking for some torque specifications for a 83 ford 5.0.
headbolts-
timing cover bolts-
waterpump bolts-
oilpan bolts-
intake bolts-
exhaust bolts-
thanks
headbolts-
timing cover bolts-
waterpump bolts-
oilpan bolts-
intake bolts-
exhaust bolts-
thanks
Post the exact vehicle you have. Keep in mind, specs may be different with an aluminum intake and or heads.
The Auto Guru-Free Automotive Information and Advice
www.theautoguru.com
ya i agree wit knucklebuster... needs 2 be more specific...
83 mercury capri. steel heads, aluminum intake, and steel exhaust headers(duh).
C.J.
1997 TSi AWD 2.3L 6 bolt (Carillo Rods, Wiseco pistons, Cometic headgasket, ACL bearings, removed BS, FP3's, Crower springs/retainers, ARP hardware), FIC 950's, Aeromotive AFPR with SS lines, Walbro 255HP, PTE SCM61, Tial wastegate, Greddy Type S BOV, short route FMIC, 3" turbo back, AEM EMS, 3 bar map conversion, BJs SMIM, 75mm TB, Innovate LC-1 Wideband, 18" Focals, Bridgestone Potenza RE040's, Tokiko suspension.
The cylinder head torque is in two steps. 1st step is 55-65 ftlbs. 2nd step is 65-72 ftlbs. Exhaust manifold bolts is 18-24 ftlbs. Water pump bolts 12-18 ftlbs. I don't know if OEM intake was aluminum. Either way my computer is listing 23-25 ftlbs. See if this is an aftermarket intake. You may want to ease it up to the torque. No listing on timing cover-probably similar to water pump specs seeing some of the bolts pass through. No listing on oil pan specs-probably light torgue 12-16ft lbs? I'll try to check another source. These specs were from Mitchell on Demand. Talk to you.
www.theautoguru.com
thanks a lot, more than helpful enough already!!
C.J.
