Air compressors - Beyond.ca - Car Forums
Results 1 to 20 of 22
Thread: Air compressors
    May 2003
    4Runner Trail Edition
    Question Air compressors
    I'm a complete noob when it comes to air compressors and I was seeing if any experts on here can help.
    I'm looking into purchasing a compressor for just basic tasks, changing tires, filling up air in tires etc... I came across two compressors and can't figure out why the one with a smaller capacity would be more expensive than a bigger one.
    20 gallon
    11 gallon
    To me they seem to have the same details, just one has a bigger tank capacity. Also, would these be more than what I need for my tasks?
    If anyone can chime in with some knowledge it would be greatly appreciated.
    Nowhere
    May 2007
    Oil-less compressors are not really built for the long term. They are noisy, and when they break they are disposable. I'd second Sugarphreak; I only break out my compressor when I have something that needs it (leak down tests, blowing out passages). Otherwise I use my 1/2" cordless impact (which I use often) and 12V compressor.
    BTW, I got my oil-less 17 gallon compressor for $85. Looking back, it wasn't a good deal.
    If you are dead-set on getting a compressor, get an oil-type that puts out >4 cfm@90 psi (120V) or something like this: https://www.kmstools.com/california-...mpressor-93436. If you are serious, get a 240V compressor that puts out >10 CFM @ 90 psi
    Elbonia
    Jeep of Theseus
    For general homeowner stuff with occasional car work, I'd look at something like this:
    http://www.canadiantire.ca/en/pdp/ma...l#.Vgl1epfGpJM
    It's not got a huge tank, it's not super powerful, but it's got an oiled compressor and it's cheap. I bought basically the same unit years ago, assuming I'd eventually upgrade to a bigger 240V one. I never bothered, it runs my impact and air wrenches just fine even if it does run more frequently than one with a big tank. I'll probably only upgrade if I get a blasting cabinet.
    Dec 2007
    Airdrie Alberta
    For running an impact reasonably,no little compressor does that.
    as said, stick to an electric impact, or get a bigger compressor. I have the 60 gallon sanborn from princess auto. I got it on sale for under 600 i think if i remember. Its done me well for 2 years so far.
    Red Deer, Alberta
    1995 WRX STi
    Too many people think too hard about the diaphragm vs piston/oil vs oilless compressor.
    I've had the same diaphragm compressor for a decade. It still works fine
    For your uses, practically any compressor will work. It starts to become more important when you start using air powered tools (at least 5scfm @ 90psi is a typical requirement).
    As for the pricing difference, Canadian Tire does this all the time with plenty of their products. The pricing doesn't have to make sense, they just have to convince you to buy it!
    Stampede Central
    is pretty sharp lookin'
    I would just recommend going with an electric impact wrench from CT, and then a small automotive tank-less air compressor for filling up your tires
    I would assume my little impact driver has enough torque for this? Where would I find adapters for lug nuts?
    click for larger version
    May 2007
    That's an impact driver. Great for driving in deck or fence screws. You can buy an adapter for it, but they tend to hammer rather than twist. Not really up to the task for lug nuts, but can work with 1/4 and 3/8's stuff (depending on the torque output).
    Something like this is what you want for lug nuts:
    Nowhere
    I have some shitty electric impact driver from crappy tire. I always break the lug nuts when the car is on the ground using a breaker bar, and a do final torque with a torque wrench, so i don't think torque output of the electric tool is really that big of a deal.
    Stampede Central
    Yea I wouldn't mind if I need to break it before using my little driver... still need to figure out how to get approriate adapters then...
    I got in the habit of breaking them first on the ground after I saw a vehicle fall off the jack when being yanked on. Not really the same safety issue with an impact wrench, but I still do it that way.
    May 2007
    I got mine from Lowes
    https://www.lowes.ca/drill-accessori..._g2251786.html
    Stampede Central
    Thanks!
    Jan 2006
    ^lots of places like Home Depot, princess auto or even crappy tire have those as well. Dewalt are very good ones that last a long while. We've had our Dewalt ones for probably 10 years now, they've outlasted numerous drills, still work perfectly fine.
    Stampede Central
    I don't think I'll do enough work in this lifetime to break a crappy tire one. Maybe I'll cheap out
    Mar 2010
    '16 GMC HD '94 MKIV SUPRA
    I have an air compressor at home, the only thing I use it for now is my air riveter and blowing out the sprinklers in the fall, I use my dewalt cordless imact driver for everything, if its a larger bolt, crack it by hand and zap it off with the dewalt. I can't stand the noise an air compressor makes.
    May 2004
    Calgary, AB -- Canada
    Default Re: Air compressors
    Originally posted by Canadian Tire
    These products 1995704 and 0588386 both have the same motor. This item# 1995704 is cheaper because it is a limited time promotion with limited quantities available! We may not be able to issue rainchecks for this special promotion.
    So yes, they are identical except for the tank size.
    As others have stated, give some serious thought to what you want a compressor to do before you invest the time, money, and space in one. Many times, hand tools are more than adequate, and for those occasional larger jobs (framing, shingling, laying hardwood floor, etc), rent a compressor at the same time you rent specialty tools and you'll be money ahead.
    Apr 2005
    Airdrie
    I have an air compressor and air tools but they've pretty much been replaced by my Milwaukee Fuel impact. The one I have has 700 ft-lb of torque. Having no cord or hose hanging behind you is awesome.
    http://www.jccayer.com/Milwaukee-276...ol-Only/p/7910
    Dec 2004
    1917 Model T, VW Baja, '18 Ram 2500 CTD/6spd
    I've been curious about those. I wonder if the Bosch is any good? I've got a couple Bosch tools and battery packs already and it's nice to keep things interchangeable.
  1. Compact air compressors
    By D'z Nutz in forum General Car/Bike Talk
    Latest Threads: 10-01-2012, 04:43 PM
  2. Advice: Compressors
    By Myz in forum Car Care, Detailing and Body Work
    Latest Threads: 10-13-2010, 12:16 AM
  3. Compressors
    By Sharpie in forum General
    Latest Threads: 01-08-2007, 09:39 AM
  4. FS: ViAir 400 air compressors
    By Mad$ella in forum Automotive Parts
    Latest Threads: 10-17-2005, 10:56 AM
