HDD's overheating! - Beyond.ca - Car Forums
Results 1 to 15 of 15
Thread: HDD's overheating!
    9.872604, -85.498802
    Turbos n Stuff™
    Default HDD's overheating!
    Ok, so a couple days ago I lost a HDD, 60GB Maxtor 7200RPM, overheating issue, sucker was scorching hot.
    I havent been HDD intensive at all, but the ones I'm running now are really hot too. I have no sides on my computer at all, and my room is 18 degrees, 2 case fans, so airflow is not a problem, and there is no dust clogging anything. Anyone have any ideas on how to kep these suckers cool? seems like more than just a regular cooling issue, never had this prblem before? Something must be messed. Any ideas?
    Travel
    I'm somewhere where I don't know where I am...
    That Blue Car
    could be your power supply is screwed and is pushin too much power to them
    Not Aspen
    Two from Freemont
    I actually find that my PC runs cooler with the sides on the computer.
    I think that this is because you actually get flow throughout the case instead of just around the fan.
    Feb 2003
    L-Tuned
    Having no sides on the computer can create an airflow problem. Put them back on. Otherwise, buy a HDD cooler.
    Jul 2003
    the larger ones run wayyy hotter to i find - my 120gig required me to get another fan put in!
    Left Coast
    Audi
    Make sure there's at least an inch between the hard drives (so they are not stacked in the case). Consider moving one of the drives to a 5 1/4" slot (rails and a cooler kit) if it is still really bad...
    If your case allows it, put a fan infront of the drives blowing in air over the drives.
    btw, did the replacement videocard fan I sold you work out ?
    oreo cookie
    a wrx.
    hm thats weird. ive got 2x120gb with 1 slot separating them. ive got a case fan right in front of them, but thats it. they feel scorching hot sometimes but they dont fail...
    Aug 2003
    Medicine Hat, AB
    My raptors run a little warm too. HDD usualy run warm but i doubt it will fail. I just added a fan and blamo. I would run warm if i were spinning at 10k rpm!
    hmm maybe i should get a fan for mine 2, it feels pretty warm....
    Sep 2002
    I would go with a HDD cooling case Ben!
    A fancy one with a LCD temperature read out, and a variable fan speed which can be automatic or user oscillated! Now that would be PIMP!
    And put those sides back on the case, they are there for a reason.
    Keep in mind that the rear fan is designed to pull the hot air OUT of the case. If the sides arent on the case there is no "vacuum" persay and overheats are common!
    Nov 2003
    I have 5 Western Digital HDs 2X200gig And 3X120gig never had a prob with cooling. But maybe you need a better fan or power suply.
    frostyda9 Guest
    If you feel like upgrading your case you could go for an Antec SOHO case. They have a fan mount right in front of the HDD slots and suck cold air directly over your drives. My Barracuda stays cool to the touch at all times. In my experience, taking off the side panels drops CPU temp but raises everything else...I'd put them back on.
    Carolina
    GMC Acadia
    I've got two 160GBs, 2 slots apart I think. Top one is at 26C, bottom is at 34C with sides on, and clunked up next to my desk and surrounded by crap my dad put there.
    I had a similar problem with a CD burner though, my dad fried mine. We pulled it out and it was scorching after just about 10 seconds of being on. Check the power supply and make sure your connections are good.
    Originally posted by VIZSLA
    Seems that running qualifying in three heats worked so well we're now running the race in three parts too.
    1, On the track
    2, In the steward's box
    3, In Paris
    A place more stinky than Alberta!
    89 Dodge Lancer Shelby
    The only drives that should be normally running hotter than you can bare are SCSI. Otherwise, you may soon have a bunk drive.
    Remember kids, when someone offers you rice, just say NO!
    Objects in mirror no longer matter.
    Oct 2002
    Ya...leaving the sides OFF could actually get you a higher temp. if you have good air flow going through your comp to begin with.
    A simple solution would be to strap a slim heatsink on them, with a good tight elastic band and some silicon paste on it to your drives.
    "I was walking around trying to act cool, like I had no fear at all.
    But I was afraid, afraid that somebody would find out just how scared I was.
    Now I'm finally realizing that fear is the opposite of love."
    -SRV
  1. Replies: 16
    Latest Threads: 02-19-2004, 12:22 PM
  2. 1G dsm overheating?
    By Canadian 2.5RS in forum Mechanical
    Latest Threads: 09-08-2003, 07:19 AM
  3. HDD Modes (Re: Quiz Questions)
    By Davetronz in forum General
    Latest Threads: 04-04-2003, 12:55 AM
  4. WTB: 240GB of HDD 7200RPM space
    By Ben in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 03-09-2003, 03:04 AM
  5. HELP NEEDED: HDD Password Removal Tool
    Latest Threads: 10-23-2002, 11:39 AM
