Deck Stain - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 55
Thread: Deck Stain
    85 toyota 1 ton, AE86, 04 Taco
    Default Deck Stain
    Read the olds posts thought i would start somthing new encase anyone knows of new products.
    I have spent the last 3 weeks removing semi-transparent stain from my pressure treated deck. I have redo it 3 times in the last 5 years. I have had it so i want to start with a clean slate. Looking for your thoughts on what products you have had luck with that hold up in our winter months. I want to do it right this time and i am leaning to oil based products. Also been looking hard at the sikkens line.
    Sep 2007
    A vehicle or two
    I am in the same boat. My stain lasted all of a year until it started getting scratched up by our dog and peeling in areas. Since I am selling the house, I just gave it a quick touchup but with our new house I'm not even going to put down any stain on the walking surfaces; only the risers and rim joists. Same with our front veranda.
    Use this method to save time...I actually tried it and it works quite well
    https://www.youtube.com/watch?v=iwaJcn5Q3kg
    We just built out our deck to 4x the original size, and trying to debate what to stain/paint it with. Not sure I want to do this, the maintenance will be hell every couple of years. The wood is treated, and crazy enough the original 15 y/o part of the deck that we kept looks almost exactly the same as the new deck.
    Is there a point in even staining/painting aside from looks? Unpainted wood doesn't even look bad at all to me.
    Foothills County
    is faster than yours
    Messmers is good, oil based/soaks in, not some crappy top coat product. So touch ups/refreshes are easy.
    http://www.messmers.com/messmers-uv-plus-deck-stain
    Cloverdale Paint locations throughout the city stock it.
    I looked into this extensively - I was about to drop the ball on some marine grade, deck treatment for sail boats (also used in cold climates) .... but then I read about Cabot products from other users in various discussion group.
    https://www.lowes.ca/exterior-stains..._g1346314.html
    I would have chosen Australian Timber oil (slightly more pricey) but they didn't have a light enough colour me.
    Essentially, you want the nastiest, most volatile stuff you can apply to wood. No cheap acrylic or some other "coating" garbage like Thompsons - you want something that will SOAK into the wood thoroughly and repel water.
    I had an older deck (pressure treated) that I just flipped around the boards on, sanded the wood and CLEANED the wood with a proper wood chemical cleaner., and push brush.
    Then I used the same hard plastic push-brush (no roller) and literally, shoved this Cabot stuff into the boards. It was absorbed really well. Repels 100% of water. Lasted through last winter just fine and looks great.
    There's a sale on creosote over at West Village.
    LOL or tar ..... one house I know they put USED transmission oil on the cedar plank siding. Worked well for about 10 years that we lived there.
    But seriously, poor prep-work is 1/2 of the problem, the other half is the product used.
    Aug 2005
    '01 B15 Sentra & '10 C11X Versa 6Sp 5Dr
    I applied the Thompson's stuff just under 2 years back. It looked terrible after a year. Going to restain front porch and back deck together this Spring. No idea what to get yet, but probably something grippier if that makes sense. The water repellent qualities were neat to look at in the Summer, but it was slippery as fuck in the Winter, especially on the stairs.
    Someday we may need to activate the halo structure off Deerfoot and destroy the North East.
    Unknown
    I used Thompson's stain on my pressure treated deck, and some other stain I don't recall a year later. After the winter, both stains started peeling off.
    In hindsight, I wish I would have spent more and gone with composite.
    I was going to say, with all the hassle and effort and recurring expense you guys are having, composite is seeming like a better and better deal.
    This. I thought my mother was crazy spending 4x more on composite... and now y'all make me understand why she's not
    BTW with the Cabot product, you could easily add some grit particles for more traction in the winter.
    I like this idea our front walk way is alos wood into the house and can get very slick in the winter.
    Agreed if i had to do it over again i would not stain at all or use composite. the deck is far to new to just rip it up and start over i am going to give it one more try and if it dosent hold up i will just let it rot.
    Unknown
    What really pisses me off, is that all that shit is advertised as Deck STAIN that PENETRATES into the wood, but it doesn't stain at all despite proper prep. After the first winter, it peels and flakes off like paint, and the exposed surface shows no indication of the so called stain penetration.
    May 2014
    Pt Cruiser
    Some great deck stain;
    Unknown
    I'm thinking of getting the rest of the stain off and going with this unique burnt look:
    https://www.google.ca/search?q=blow+...w=1133&bih=503
    Unknown
    I just thought of another kind of crazy ass idea
    Ever used clothing dye? Well that stuff stains just about anything and a $1 makes a huge bucket full.
    I've got some spare planks left so I'll try it out tomorrow.
    What product did you use?
    Did you sand and clean the deck prior to application? (or was it clean and sand, cant recall exactly)
    Beyond
    As an owner of a composite deck, I do not recommend it for surfaces facing the sun. It becomes super heated and fades quickly. Additionally, if you clear the snow off of it using a shovel you may damage the surface which then ends up peeling away.
    Was the #1 Forum Warrior
  1. Best stain for new cedar deck?
    By kenny in forum Home and Garden
    Latest Threads: 09-11-2015, 01:43 PM
  2. Deck Stain
    By visualk in forum Home and Garden
    Latest Threads: 08-12-2009, 08:43 AM
  3. Bug stain removal on 3m film
    By spyce in forum Car Care, Detailing and Body Work
    Latest Threads: 08-27-2006, 11:10 PM
  4. Paint Stain removal
    By teggypimp95 in forum Car Care, Detailing and Body Work
    Latest Threads: 07-14-2006, 12:42 PM
  5. good oil stain remover?
    By bart in forum General Car/Bike Talk
    Latest Threads: 01-28-2006, 04:38 AM
