Bike build and maintenance - Page 18 - Beyond.ca - Car Forums
Page 18 of 32 FirstFirst ... 8 17 18 19 28 ... LastLast
Results 341 to 360 of 632
Thread: Bike build and maintenance
  1. #341
    The SHBARUS
    Don't be scared, embrace it lol. d fly is a must with di2. You can see your gearing and battery level on your computer. It also beeps to let you know before you hit the last gear or before the FD shifts in synchro mode. The latest ultegra di2 shifters have the hidden buttons that you can customize, super sweet.
  2. #342
    Jul 2006
    The C
    Anyone running 650B tires care to comment how you like it?
  3. #343
    lilmira where did you put your dfly? Guessing the closer it is to the head unit the better. I've got it sitting near the bb right now, but wondering if there's going to be interference there.
  4. #344
    The SHBARUS
    That's how they did it for me on 3 bikes. I haven't had any issue. Well there might have been 1 or 2 times with funky connection but that could be with Garmin.
  5. #345
    k maybe I'll just give it a try in the bb with an option to move to the seatpost using a long di2 cable to connect it. If that becomes an issue I'll move it to the handlebar, I've just got everything wired up right now with the bike completely disassembled, and doing the internal wiring for the handlebar was brutal. Probably took me 3-4 hours to do all the di2 wires and brake cables.
  6. #346
    The SHBARUS
    oh yeah, I remember the guy complaining about the difficulty of installing the end plug junction for me, money well spent lol.
  7. #347
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Well... finally built a downhill bike... of sorts
    Picked up a couple parts:
    Then tore this useless thing down:
    Then tinkered a little and ended up with this:
    Old school 24/26” wheel combo banshee scream V1
    Just need to locate a front brake, and get new pads for the rear... then maybe some safety gear and I’m ready to try this shit out!
    Didn’t want to invest a whole lot for my first bike, but if I like it I shouldn’t lose any money on what I’m invested into this for when it’s time to upgrade
  8. #348
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Well that escalated quickly... guide RS all around, when I was grabbing adapters to run 210mm front and 180mm rear I grabbed some new grips too, old ones were gross and migrated a ways inwards. These brakes are waaay better than the old hayes nines
  9. #349
    '14 Taco
    So my new whip has 'tubeless ready wheels'. Is tubeless worth it for a roadie, knowing that i'd have to get new tires and such?
  10. #350
    At this point for true road tubeless I'm going to say no because the high pressures from what I've seen make it difficult for sealant to do it's job, gravel I'm on board with because of the lower pressures . I'm sure someone will chime in with a yes but for me the downsides are too big for road tubeless at the moment. Take a look at the whole Enve tubeless fiasco, lawsuits everywhere because of it. The lack of standards across tire and wheel manufacturers has caused a big rift in the industry where many tires aren't compatible with many rims, the industry is starting to adopt standards and it looks like Mavic's UST standard might win but other manufacturers will probably fight it tooth and nail.
    For the road...I still prefer tubulars or latex tubes instead of butyl.
  11. #351
    The SHBARUS
    I tried tubeless and I'm back to clincher and tube. For me, the ease of changing a tube beats the benefit of tubeless.
  12. #352
    Sep 2002
    CGY
    Cayman, F150, Crosstour
    Quote Originally Posted by bigboom View Post
    I'm sure someone will chime in with a yes but for me the downsides are too big for road tubeless at the moment..
    ...And ya, I'm that guy.
    After 3 flats in Ironman Canada a few years ago I converted all my bikes to road tubeless and no looking back. But agree it does come down the the rim/tire combo that you're running to ensure compatibility.
    The early tubeless tires (mostly Hutchinson) were a pain in the ass to get on the rim. The schwalbe pro ones, and Conti tires are way easier to mount. Last set I did not need a tire lever and could roll it on the rim.
    Anyways...my choice for long unsupported rides of 180 - 250km. I still carry 1 spare tube, patch kit and a tire boot.
    Latex tubes - I wasn't a fan because of heat fluctuations. Had tubes blow on me twice while my tri bike was sitting in transition. Maybe i'm doing something wrong....
  13. #353
    '14 Taco
    Quote Originally Posted by CLiVE View Post
    Have you noticed a significant decrease on flats?
  14. #354
    Sep 2002
    CGY
    I have not had a flat in 3 seasons and 4 ironmans....
    In all my years of road riding at ~10-15k per year. I've only had a catastrophic tire (not tube) failure twice from road debris cutting the tire. If that happens I have the tire boot and a backup tube.
    I do inspect my tires pre/post ride for any small cuts, etc I may have pick up also.
    Now the initial setup for tubeless is not easy. A tubeless tire booster pump makes things a LOT easier.
  15. #355
    Sep 2002
    CGY
    thought I would follow-up on this post....and I got a flat at IM Boulder that refused to seal. Appeared to seal during the race (noticed it race morning - and rode 180km on it), but every time I try to add pressure now it sprays.
    Small pin hole puncture. Schwalbe Pro ones w/Stans sealant. Guess it did what I needed it to do for the race ?!?
  16. #356
    Oct 2009
    rally pig
    I'm building a single speed bike by reusing some old parts, have a triple crank and planning on using the 50t along with a 16t cog.
    Is this good enough for around downtown Calgary and mostly flat areas, or too hard and use a 39t instead?
    on my road bike I tend to be riding 50t and 16t or 18t and on the hybrid its 42t and 12t to 14t
  17. #357
    Sep 2002
    CGY
    Most fixed gears / single speeds come standard with a 46/16 or 2.88 ratio or similar. With that being said, give it a try and if it works for you...go with it.
    I commute on my fixed gear now and then, and ride up hill to the NW and up and over over nose hill on a 46/16.....hard, but can get over the hills. You may want a narrow/wide chain ring on the front. The middle position on the triple will likely give the best chainline also.
  18. #358
    Oct 2009
    rally pig
    I've been reading that 46 or 48 is the optimal chainring on the front but it seems hard to find for 5 bolt 94bcd crankset.
    2 options that I have is
    1. get a 42 ring
    2. use a square tapper bottom bracket and pre-made fixie cranket
    I'll try 50/18 or 50/16 first and look into a smaller chainring later on if too hard.
    50/18 is 2.78 ratio so this might work, otherwise 42/16 with 2.62 ratio if I want something easier
    Even on a single speed I should still use narrow/wide chain ring?
  19. #359
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    I like my 48/16... but keep in mind that you only get one skid patch with that setup
  20. #360
    Not Aspen
    Two from Freemont
    I like this idea. I have an old Madone that I haven't ridden in 10 years. The freewheel is ceased, so it is basically a single speed. haha.
    How hard is it to convert? I am sure there are online tutorials. Any suggestions?
    Is a carbon single / fixie not cool?
  1. Replies: 87
  2. Low maintenance, or maintenance free yard
    By z24_wheels in forum Home and Garden
    Latest Threads: 09-07-2017, 06:58 PM
  3. Got my bike - maintenance walkthrough?
    By woodywoodford in forum Cycling
    Latest Threads: 08-08-2014, 01:28 PM
  4. New Bike Maintenance
    By flipstah in forum Cycling
    Latest Threads: 05-19-2009, 10:10 AM
