Bike build and maintenance - Page 27 - Beyond.ca - Car Forums
Page 27 of 32 FirstFirst ... 17 26 27 28 ... LastLast
Results 521 to 540 of 632
Thread: Bike build and maintenance
  1. #521
    Quote Originally Posted by flipstah View Post
    In terms of bike mechanics, should I also try and move the saddle forward vs finding a shorter stem?
    Those are two independent adjustments, by moving your saddle forward you are going to be making changes to your knees in relation to the crank spindle and that may or may not cause you issues. The stem length is for your upper body reach, the saddle position is to make sure your legs are moving properly.
  2. #522
    Jul 2008
    Transnistria
    Exploded.
    Quote Originally Posted by bigboom View Post
    Oh okay, thanks! When I ride, I definitely feel like I'm over reaching for the bars and my boys feel the pinch. Granted it was the first ride without any adjustments so I'll find out this weekend what I can do. The frame isn't big because I clear the cross bar but I guess I have T-Rex arms.
    Will definitely need to replace shifter/brake cables so have to figure out which ends I have.
    - New saddle/seat post
    - New bar tape
    - Brake hoods
    - Brake cables
    - Shifter cable
    - Frame cleanup
    - Overall greasing/adjusting
    - Maybe new brake pads (do pads go bad? They're still thick...)
  3. #523
    Standover height isn't really much a tell in regards to frame size though. I would look at potentially raising the stem up first, sounds like maybe there's too much saddle to bar drop along with a potential reach issue. You might want to get fit though before you dump a bunch of money into this bike. Brake pads will go bad especially if they are cracked and dried out.
  4. #524
    Jul 2008
    Transnistria
    Exploded.
    Adjusted the saddle/drop bars and the reach is way better; pedalling felt more efficient too so might have been just too far back. Has a 110mm quill stem extension so might get an 80mm
    As for cables, these are the ends.... Is there a term I should use on Amazon?
  5. #525
    Feb 2008
    Not Aspen
    teslo murdel free
    Just go to crappy tire or Walmart and get brake cables
  6. #526
    Jul 2008
    Transnistria
    Exploded.
    Oh yeah good call thx man!
  7. #527
    Jul 2008
    Transnistria
    Exploded.
    Should be done my Norco today so I got bored and looked on Facebook. Ended up with two frames; one is a chromoly!
    Time to build a fixie!
  8. #528
    You sure you want to do that? Personally not a fan of fixed gear bikes for anything but track riding. I'd rather be on a single speed bike with a free wheeling hub any day of the week...
  9. #529
    Mar 2010
    Ioniq 5
    So I was out for a ride and it looks like one of my spokes came loose. Is this something that can be fixed by a shop if I bring my wheel in? Or do I need to but a new one. Heard a ting then noticed my brake was dragging as the rim is warped where one came loose
  10. #530
    Likely easy enough to fix as long as the rim isn't excessively bent or damaged. Shouldn't be too expensive likely somewhere around 30mins of the labour rate if it's just replacing a spoke and retruing the wheel.
  11. #531
    Jul 2008
    Transnistria
    Exploded.
    Quote Originally Posted by mazdavirgin View Post
    I’ve been back and forth on it and learning about bike frames along the way. Like cars, a frame isn’t a frame!
    MTB frame isn’t road frame so what I’ll be doing is restoring the Kuwahara as a SS hybrid with some fun coloured Gravelkings. I also learned about cantilever brakes and v brakes.... This has been fun!
    Side note: if anyone wants a 60cm Viscount Sebring frame for their roadie build, Id be willing to trade for a S/M road frame or $40.
  12. #532
    Sep 2002
    CGY
    Cayman, F150, Crosstour
    Love my fixed gear. For urban riding / pathways / errands and commuting I ride my fixed gear a lot. It will make you a stronger rider (especially on the hills). Also find it is a great way to get a good workout in when I don't have time for a long highway cruise on the road / tri bikes. The level of speed control you have with fixed is also nice, makes it tough to go back to other bikes. And yes - I run brakes in the city.
  13. #533
    Jul 2008
    Transnistria
    Exploded.
    Quote Originally Posted by CLiVE View Post
    In most build videos I've seen, when they do a fixed gear conversion it doesn't need a tension arm and SS conversion needs an arm. However, my SS cruiser doesn't have a tension arm. Is this related somehow to the dropouts?
    I thought if you keep the chain tension tight, it's fine SS/fixed... I'm pretty lost.
  14. #534
    Subaru Outback
    I really enjoyed riding my single speed as well. It was easy to work on and I didn't have to any adjustments. The only reason I sold it was because I started biking to downtown in the summer. On the way home, going up the Edworthy Park hill to get to to Sarcee and Bow and then going up the Bow trail hill was taking all the fun out of biking.
  15. #535
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Omg... you’d need some big legs to get up edworthy on a single speed
    I’m running a 16/48 ratio and even sandy beach kills me!
    Love the fixed for DT though, great brewery hopper
  16. #536
    Subaru Outback
    Quote Originally Posted by ercchry View Post
    I would get 1/3 up and have to walk it the rest as I needed my legs to get to the to of Bow trail.
  17. #537
    May 2005
    Wankels!
    It's all about gearing. I've done Edworthy repeats on my single speed bike. However, that bike on the pathways means 100rpm to do 27km/h. I guess that also means 50-55rpm on some sections of Edworthy.
  18. #538
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Quote Originally Posted by Penguin_Racecar View Post
    Yeah... 100rpm is about 38km/h for my 700c/25 16/48 setup... just the way I like it for the flats
  19. #539
    Jul 2008
    Transnistria
    Exploded.
    What gearing combination do you recommend on a single speed setup around bike paths in the city? It will help me on my MTB single speed build
  20. #540
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    You want to keep cadence (rpm) between 80-100 for optimum efficiency... so keeping that in mind plug the rest of your variables into this
    https://www.sheldonbrown.com/gear-calc.html
  1. Replies: 87
  2. Low maintenance, or maintenance free yard
    By z24_wheels in forum Home and Garden
    Latest Threads: 09-07-2017, 06:58 PM
  3. Got my bike - maintenance walkthrough?
    By woodywoodford in forum Cycling
    Latest Threads: 08-08-2014, 01:28 PM
  4. New Bike Maintenance
    By flipstah in forum Cycling
    Latest Threads: 05-19-2009, 10:10 AM
