Bike build and maintenance - Page 20 - Beyond.ca - Car Forums
Page 20 of 32 FirstFirst ... 10 19 20 21 30 ... LastLast
Results 381 to 400 of 632
Thread: Bike build and maintenance
  1. #381
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    So acquired most of the parts for this build... just down to the little things, chain, cables, shorter chainring bolts, etc... but one part I should have added to my Jenson order might be a little tricky...
    https://www.jensonusa.com/Shimano-St...k-Shift-Bosses
    Anyone know if one of the local shops would have these in stock? Or anyone have some kicking around? The originals on the bike were broken and I would like to run the cable for the derailleur this way vs zip ties
  2. #382
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    First parts order turned up... have to add 1 1/8” to 1 1/4” stem shim to the list as this threaded to threadless adaptor wasn’t what I expected... waiting on shifter before wrapping the other side of the bars
  3. #383
    Jan 2003
    Quote Originally Posted by ercchry View Post
    Thought I was looking at some samurai sword on first glance
  4. #384
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Quote Originally Posted by ZeroGravity View Post
    Yeah, I was getting that sort of vibe too haha, I really am liking this over grips... should also have enough wrap in this kit to redo it once too
    UPS finally updated that they should be delivering the rest of the parts tomorrow, so should be able to finish it up this weekend... just in time for my new DT commute that I’m starting Tuesday
  5. #385
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Before:
    After:
    1x11 conversion (reused 46T chain ring)
    105 derailleur
    105 11-32 cassette
    Shimano 11sp chain
    Brand X bars and stem
    Threaded to threadless adaptor
    Shimano RS11 wheelset
    RS-700 shifter
    Brooks bar wrap
    Pedals/toe cages/leather straps
    Clark’s brake levers
    Leftover seat from some other bike
    All new cables
    Rides great, super playful... should be perfect for my 36km round trip
  6. #386
    (maah raahde)
    Looks good!
  7. #387
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Hrm... so dropped the chain twice on the way to work, noticed my bike lock had slipped and was touching the chain, so tossed the lock in my bag in the way home and dropped it 3 times on the way home! Twice in a row in the lowest gear climbing sandy beach hill... then once in the second highest on the flats... think I might need a narrow wide chain ring. Screwed around with tweaking the derailleur as best I could prior to this ride so not sure what else I could do... damn 1x
  8. #388
    May 2005
    Wankels!
    Yes, get a narrow wide chain ring. That should fix all your problems. 1x without narrow wide is unreliable unless you are running something else on the front to prevent it from jumping off the chainring.
  9. #389
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    Seemed better today, chainring bolts were creaking so I tightened them, may have been part of the issue... will monitor
    Not a huge fan of the tires on this bike though... slipped out on me going down sandy beach hill (rear locked up) ...that was a fun start to the day
  10. #390
    Hybrid
    I do most of my own simple bike maintenance (tires, chain, brakes, cassette, indexing), but some things I'm shit at or don't care to learn - wheel truing, hub/bottom bracket bearing overhauls, etc. Any shop recommendations for road/gravel bike servicing for these types of things? LBS vs dedicated mechanic?
  11. #391
    (maah raahde)
    Quote Originally Posted by Strider View Post
    I've not done any bearing overhauls, but I brought in one of my winter wheels for truing to Bike and Brew when I was picking up a new bike there. A minor true is $14.95 and a major is $29.95.
  12. #392
    CGY
    Cayman, F150, Crosstour
    Meh - don't pay for truing. It is super easy. Google DIY truing stands, I built one on my work bench with an old Thule wheel carrier.
  13. #393
    Ioniq 5
    i heard most bike shops are having their biggest months ever... exercise is good!
    Yeah I called a couple shops, 1-2 month wait times to get a tuneup. Ended up finding someone on kijiji and was quite happy. Took 2 days and both bikes are running great now.
  14. #394
    Aug 2006
    calgary/AB
    95B
    Quote Originally Posted by pheoxs View Post
    Can you send me the contact details of the Tech please? I need some bike tuneup.
  15. #395
    Quote Originally Posted by ganesh View Post
    I've used this guy in the past with no issues:
    https://www.facebook.com/pages/categ...6191620869916/
  16. #396
    Aug 2006
    calgary/AB
    95B
    Quote Originally Posted by roopi View Post
    Thanks. Contacted him, the first available opening is on June 22nd .
  17. #397
    Ioniq 5
    https://www.facebook.com/SCBikeMechanic/
    This is the guy I used in the NW. Was happy, 40$ for each of my bikes which was pretty good considering my mountain bike (that doubles as a winter commuter) needed quite a bit of work. Brakes weren't great as one started dragging a bit and both front and rear shifters needed adjusting from skipping between gears. Chain was in rough shape and needed a nice cleaning, etc. Lots of abuse from a full winter of riding it every day. Bike runs way better now and very happy.
  18. #398
    Aug 2006
    calgary/AB
    95B
    Thanks for the Info.
    I dropped my first bike off .
  19. #399
    Model X Plaid
    hey guys i didn't want to start a new thread but i need some help trouble shooting. i have a cervelo S2 2x11 ultegra 50/34 front 11-28 on the back, almost 6000km of use. now when i am coasting at moderate to higher speeds, say >25kph, there is occasionally (but becoming more frequent) a very loud grinding sound that i think is coming from the back wheel or freehub. nothing appears to be rubbing on visual inspection, the wheel is moving great, the gears are tuned perfectly. the noise lessens and almost goes away if i continue pedaling. i thought initially that it may have been the cassette or something was loose, so i took the cassette off, did some general checking, put it back on tight and it's still there. any ideas?
    on another note, that may or may not be related, i had found over the winter while zwifting, when i was climbing a hill or had lowered my cadence into the 60s, there was an intermittent, subtle but notable clunking sound that also seemed to be coming from the back.
    TIA
  20. #400
    The SHBARUS
    I know what your problem is, you need a new bike
  1. Replies: 87
  2. Low maintenance, or maintenance free yard
    By z24_wheels in forum Home and Garden
    Latest Threads: 09-07-2017, 06:58 PM
  3. Got my bike - maintenance walkthrough?
    By woodywoodford in forum Cycling
    Latest Threads: 08-08-2014, 01:28 PM
  4. New Bike Maintenance
    By flipstah in forum Cycling
    Latest Threads: 05-19-2009, 10:10 AM
