Install thread- Holley EFI Sniper on '72 402 big block - Beyond.ca - Car Forums
Results 1 to 20 of 37
Thread: Install thread- Holley EFI Sniper on '72 402 big block
    2008 Z06
    Default Install thread- Holley EFI Sniper on '72 402 big block
    Part 1 Video https://youtu.be/ZOTmKqEPsHo
    Moving the truck into the shop
    Old vs New
    On the engine. Vacuum and throttle/trans cable connected.
    3/4" hole drilled for O2 sensor. It's 10+ degrees above horizontal and near the collector.
    Derp. Included 2.5" exhaust clamps for O2 sensor mounting don't fit my 3" exhaust. I'll need to go buy some 3" clamps:
    Draining some coolant to install the new temp sensor
    Temp sensor install location. May need to relocate it as I've read the reading back there can be too low.
    To be continued!
    Current Cars:
    2019 BMW X3 M40i Stage 2, 12.44 at 110mph
    1972 Chevy Super Cheyenne C10 Pickup 402 big block, 700R4
    2004 GMC 2500HD 8.1L
    Past Cars:
    1970 Chevy Blazer, 2wd
    2003 BMW X5 4.6IS Doushmobile, moneypit
    2015 Ford Fiesta ST | Cobb Stage 1, catless downpipe
    2008 Corvette Z06 - 11.39 at 123.8mph
    2002 Corvette Z06 - 12.10 at 116.5mph
    2005 Jeep Wrangler LJ
    1993 5L Mustang - 12.59 at 108mph
    1989 5L Mustang
    1990 Jeep Cherokee
    1991 Acura Integra RS 403Honda
    Aug 2008
    Medicine Hat
    God I love your truck, soo nice
    May 2009
    Medicine Hat AB
    General Motors Competizione
    I'll be following along, I want to do this to my truck too.
    2007 GMC 2500 Duramax
    1981 GMC C1500 454
    Mar 2006
    Very interested in how you end up running the fuel. It's the #1 thing holding my back on swapping the 455
    2008 Z06
    Quote Originally Posted by Ca_Silvia13 View Post
    For the fuel source side (tank to elec fuel pump to throttle body) it should be straight forward.
    For the return (throttle body to tank) I have a place near the tank where I plan to add a simple T fitting to a rubber hose (shown in video), but I have not yet figured out a hole in the cab where I want to run the return hose.
    Current Cars:
    Past Cars:
    1989 5L Mustang
    1990 Jeep Cherokee
    Turbo stuff
    2008 Z06
    I don't need to cut my tank to do this install, if I'm understanding the purpose of that thing. If I'm missing the point can you explain?
    Current Cars:
    Past Cars:
    1989 5L Mustang
    1990 Jeep Cherokee
    Turbo stuff
    It's a quick easy sump, if you want to sump the tank instead of using 45 year old lines.
    Mar 2006
    Quote Originally Posted by Ekliptix View Post
    I didn't see the inline pump previously. Looks like a very complete kit, would you agree?
    2008 Z06
    It sure is. So far, the only thing lacking is the exhaust clamps for the O2 sensor being suited for 2.5" dia exhaust, while I have 3". I bought the optional fuel kit with the EFI system. If I was going more hardcore, I'd get a new rear fuel tank with a build in electric fuel pump. However, this kit has the in-line elec fuel pump, hose, filters, fittings, etc.
    Aug 2002
    992 T-hawk Golf R
    Is the system strictly for fuel delivery or can it control timing as well?
    I like neat cars.
    2008 Z06
    I don't believe to, but this part can be connected to the Sniper EFI computer to control timing: https://www.holley.com/products/igni.../parts/565-100
    It's on my 'later' list of things to add.
    Sausage Wagon
    Looks good.
    Originally posted by teamPRO
    howbout suck my black kettle...
    Dec 2004
    1917 Model T, VW Baja, '18 Ram 2500 CTD/6spd
    Nice project. If you're switching to fuel injection, have you considered doing the tank swap to a frame mounted tank? Keeps the gas and associated smell out of the cab, bonus points for safety if you're in to that sort of thing, and clears up room behind the seat for subwoofers, gun racks, whatever floats your boat. They make nice clean tanks for those that sit between the rear frame rails, and are already set up for FI.
    2008 Z06
    Quote Originally Posted by carson blocks View Post
    I don't have any issue with the factory fuel tank in the cab. I've never smelled gas. If I were starting from the frame up, I'd put a rear fuel tank in. I the case of what I'm doing here, that's too big of a pain in the ass and cost to bother with.
    2008 Z06
    Got the fuel tank drained in to jerry cans.
    Removed the mech fuel pump.
    Assembled the elec fuel pump and filters.
    Found a factory return line I intend to use. Need to get a fitting to step down from the 3/8" fuel hose to the 5/16" steel return line going into the fuel tank.
    I intend to keep the 2 3/8" hoses (green and red below) next to each other, along the frame rail before running them up the firewall above the transmission, around the distributor into the EFI unit. I'd use the factory hard lines along the frame except they terminate way at the front by the radiator. The headers will be approx 3" away from the fuel line at the nearest point. I suspect this is OK for temps, but I'll look into something to wrap parts of the fuel hose with to protect it from heat as an extra step: https://www.amazon.ca/Heatshield-Pro...70_&dpSrc=srch
    Here's the plan:
    High flow mech fuel pump vs electric fuel pump.
    Current Cars:
    Past Cars:
    1989 5L Mustang
    1990 Jeep Cherokee
    Dec 2004
    Mounting the fuel pump on the frame under the cab?
    2008 Z06
    Correct. Near the stock fuel hard lines.
    Dec 2004
    Nice, just wanted to make sure it wasn't going in the cab with the tank, both for noise and safety.
    2008 Z06
    Part 2: https://youtu.be/hIClWrLBrBA
    Got the fuel system installed.
    Removed the mechanical pump and used the included plate to cover the hole. The original bolts were too long for the plate, so I had to find some shorter bolts.
    The electric fuel pump is mounted along the frame using some existing holes (lucky).
    I ordered some of these off amazon.
    And after a bunch of looking found this 3/8" to 1/4" step down to connect to the factory return steel line into the stock tank. From the EFI unit in the engine bay, the 3/8" rubber return hose goes down the firewall, along the frame, through 2 of the rubber retainer clamps, into the 3/8" to 1/4" step down fitting, into a new 1/4" rubber hose, into the factory 1/4" steel return hose which goes into the cab and tank.
    I heat tape wrapped some of the fuel line and post pump filter just as a precaution, and it looks cool.
    Also got the 3" exhaust clamps from amazon so O2 sensor is installed.
    Made some wiring progress tonight.
    This is an optional 10 pin connector. Most of the wires are for nitrous, etc, so I cut and heat shrinked most of them. I only need the brown wire remaining to send a signal to my tach.
    Started getting some things tucked away. I need to buy some black wire loom to cover those 3 wires at the top. I attached the fuse and relay to a screw by that AC box thing.
    Tried to hide the wires as much as possible. This is the power from the battery, ran through the fender.
    What's left is connecting a blue wire (power) to the fuel pump, grounding the fuel pump, ensuring the O2 sensor cable is secure, terminating the yellow wire to the distributor tach signal, connecting the brown wire to the tach, connecting the pink wire to 12v when the ignition is on.
    Then put some gas in the tank, follow the start up instructions including priming the pump and dumping gas into a can to fill the source hose with fuel.
    The end is in sight!
    Good news and bad news.
    The good: The truck is running!!! It idles super smooth and there's no unspent fuel coming out the exhaust.
    The bad: There's coolant leaking from the intake manifold where a crack has appeared, likely from me over tightened the heat temp sensor.
    Need to do:
    1) replace/fix intake manifold where it cracked.
    2) adjust throttle cable to provide 100% open throttle. Reads 85% position at peddle WOT.
    3) wait 3 months for snow to melt
    Part 3 Video: https://youtu.be/JSnHy1DTm8E
    Finished engine bay
    Running and warming up
    Me "What's that sound?"
    Green juice is good, right?
    Random pic of chains used to get 1 car and 2 trucks unstuck from my driveway this weekend. 305 studded winter tires, love 'em.
  1. Careless Driving, 402 dollars, for NOTHING
    By scat19 in forum Society / Law / Current Events / Politics
    Latest Threads: 04-16-2010, 09:09 AM
  2. FS: EB Games gift cards $402 total
    By Zero102 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 02-27-2009, 05:17 PM
  3. 402 C5 smoked on Autobahn by a Porsche
    By R!zz0 in forum Cars, Bikes, Machines
    Latest Threads: 03-17-2007, 04:12 PM
  4. FS: Panasonic 402-u
    By zain123 in forum Automotive Parts [Audio/Video/Radar Systems]
    Latest Threads: 11-17-2004, 04:32 PM
  5. Holley throttle body!!
    By ls/vtec-crx in forum General Car/Bike Talk
    Latest Threads: 07-17-2002, 06:21 PM
