Made a post here https://forums.beyond.ca/threads/364...68#post4918768 but since it will probably entail a few things to happen figured I'd just create a new thread.
Basically what has happened is I have discovered the lack of a proper humidifier in this house which I will be fixing soon as wall as an issue with a lot of cold air coming through the vents in the basement.
Also as @Nufy asked the furnace is from 1999 original to the house and according to the tag crappy on the efficiency scale
Here is what I have discovered...
This part dumps a ton of cold air into the room and was suggested to put into a bucket and leave room for circulation so that is simple.
Then you can see from this picture three ducts going and they are in order (closest to furthest)..
1) Recirc fan - It would seem at some point this was installed to pull air from INSIDE to outside the house but really doesn't feel like it doesn't much
2) 1st black duct - This is running into the return and the source of cold air into the ducting and probably where the cold air is being fed from. It does have a damper lever on it.. but don't see a point in that.
3) 2nd black duct - This is the duct of which I will feed into a bucket to help keep cold air out of the room
And this is our wonderful not working and no humidistat humidifierThat is installed on the supply side not return side.
