1961 land yacht… Beyond needs more builds build. - Beyond.ca - Car Forums
Results 1 to 20 of 28
Thread: 1961 land yacht… Beyond needs more builds build.
    missy
    Exclamation 1961 land yacht… Beyond needs more builds build.
    I’m a glutton for things that are different, because I’m a strange duck. I picked up a 1961 Chrysler Saratoga, because I like wings as much as the next they/them. The 61 was only made in Canada, for one year and one body style. End of history lesson. Got it as a barely limping driver, did an rpm intake manifold on the factory big block and 600cfm carb, to which I grenaded the cast push button boat anchor of a trans. I’m not going to show pics of this, because it’s boring. Here is the unit when purchased
    As much as the 215s were too wide to handle, ended up changing out the wheels, 18x9.5 tears with 315/40/18 nt01s fit with no modification minus hammering the leaf spring clamps like a professional would
    End of build… wait, this isn’t a world of wheels car…. After pulling the motor and trans / undercoating the floor which is mint thankfully and stopping and reselling the trunk, also mint and can fit a small army, I moved to the brakes. Note, tapered bearings + old means I’m making a puller that made life too easy
    Not going to post a video of me in daisy dukes and mesh belly top doing the brakes, but rocked them… getting the return springs back on the shoes is a real gem. After the motor was yanked, I stripped the bay, sanded too much, and hit it with some cloverdale marine paint, cause who doesn’t like to sparkle
    I ended up sanding and doing another coat, doing the booster and subframe blah blah blah…. Next was the sweet padded dash that was for safety according to the brochure, you don’t need seatbelts when you have an inch of foam
    -end 5 attachments only
    CNC Guru*
    * This is not an advertisement or porn..... but pm me lol
    Instagram: goreski_rdd
    (maah raahde)
    missy
    Against my better judgment, I stripped it, sanded, filled holes, fixed a few dents, and wore a mask for once when painting inside a car. I won’t show the newspaper masking pics, which is the only use for the high river times, but here was the end result
    Carpet is new too, but it’s carpet, so… ya. The headliner was gross and the back was, missing we will call it, so I started an in car repair as the roof is so long you have to take glass out to remove it, and I’m not that cool
    I need to piece in another at the back with a strip of polished aluminum hiding the seam, but I had bigger fish to fry… rear speaker deck was re-covered too
    Although the deck isn’t the prettiest, my couldn’t give a shit / better than most sema cars was good enough
    CNC Guru*
    missy
    Now, I know what you’re thinking, d series all the way. As much as rage2 I’m guessing would have wanted me to, I went k20… or bought a charger. Here’s a pic on the utility trailer, and yes, I backed it off, and yes, it saved me at least an hour on the engine pull
    Yes, the wheels and tires are for sale, no, I’m not making a listing. Drove the car 10 minutes away, completely legally might I add to my buddies bay, as the car is 20 feet long and my shop isn’t length friendly.
    A bit of painters tape to hold headlights to where I’m guessing they were bolted, made it safely. Yanked the motor / trans and cut the cats like I was in forest lawn. That’s pretty much up to speed, I’m selling the trans and got a 71 727 I’m going to build (no overdrive Sam, supporting the economy). Got the flex plate adapter on the way, led halo Amazon special black bezel headlights to retrofit, and bolt it in with no modifications needed. Or, bash the freshly painted firewall and grind / weld mounts, but we will cross that river in the weeks to come
    One last pic of my car getting to my buddies behind his killer tow rig, which is smaller than the damn car
    CNC Guru*
    Dec 2006
    Nothing worth mentioning.
    That mercury gives me wood.
    "Look at my small penis everyone,"
    missy
    That merc makes 450hp, sitting on interceptor running gear, and has a wild interior. Towed like a champ too
    CNC Guru*
    May 2009
    Medicine Hat AB
    General Motors Competizione
    I like the cars and trucks featured in this thread.
    2007 GMC 2500 Duramax
    1981 GMC C1500 454
    Thread of the month right here.
    Dec 2005
    not calgary
    changes every year
    Very cool.
    Subscribed.
    Looks like a great winter project.
    missy
    Winter project? That’s the bodywork and paint. I’d like this doing donuts before December
    CNC Guru*
    Dec 2006
    Quote Originally Posted by gretz View Post
    Do you do the painting and bw?
    missy
    Ya, I’ll do it. I’m a glutton for hating myself lol
    CNC Guru*
    Nov 2005
    Very cool Gretz, like what you've done so far. Look forward to seeing your build/work on this. Be a rare and bad ass car once you finish it.
    "I cut the cats like I was in forest lawn." Hahaha.
    missy
    Small update, factory front sump oil pans are a no go. Cut the factory one and did some test drops to see where I needed to end up. Holley gen3 midsumps sat too far forward, ended up going with the speedway. I hate you ups for 3 out for delivery flip flops, but eventually it showed. Going to modify the Holley mid sump pickup to run in this pan, clears the k member / steering shaft perfectly. Picked up a flex plate adapter to run the 727, bolted everything up, and she goes in minty. No firewall banging which I would have enjoyed, but not needed. Now to weld mounts, make a trans mount, driveshaft, wiring, everything… still lots to do, but it’s moving now, not literally, but, ya
    CNC Guru*
    Out of curiosity, why 727 over A518/46RH? OD is very nice to have if you plan to cruise it.
    missy
    The factory gearing is a 2.93 in the rear, should be right around 2500rpm @ 70mph with the tire I’m running, not the worst. I didn’t want to mess with the abs garbage that’s needed to run the charger trans ecu. Ah for the 518, finding a reasonably priced core doesn’t really exist this day and age and the 727 kinda fell into my crotch. I can always switch things up when I do full retard, which will be in a year knowing myself. I like proving things out cost effectively before going to the end zone (definitely a turbo in the future)
    CNC Guru*
    Fair, if you got the 727 for cheap and you've got highway gears, should be pretty good going down the road.
    But if you still want a cheap 2WD 46RH core, there's one at PnP right now. Will have lockup and OD.
    https://row52.com/Vehicle/Index/1B7HC16Y2RS686363
    Add a lockup/OD control kit from PATC and you're golden.
    missy
    Ya, it was $300 with converter. Hard to beat. And it keeps things simple to get this unit rolling sooner with cheap rebuilds to make it stronger when need be. I’m not lazy or cheap, rather both of those things lol
    CNC Guru*
    missy
    Been a bit, time for an update… trans is built, upgraded clutches and all. Went with a new hughes converter and a burst shifter to do the dirty work. Hooker Blackheart hemi swap headers were needed and landed the outlets perfectly, new intake mani gaskets, machined some egr gasketed block offs, intake made, rad in and plumbed with upper/lower hose sensors, one for each electric fan, batterybox in, all wiring done and tucked with an obd port in the ashtray, new fuse box in the glove box, and all factory gauges work, even the speedo will work as the cable is identical to the factory. Finished the headliner and rear deck / made a bow where the front and rear seams as well… What’s left?
    Bolt the trans
    Hookup the shifter
    Tranny mount
    Driveshaft
    Retrofit headlights
Size:  186.3 KBName:  64FB104B-3AF6-4C54-AD7E-A15A39A700E0.jpg
    Hp tuners tune to get rolling
    And exhaust built. Should be kicking before Christmas if all stays on track
    CNC Guru*
  1. Condo: value of old builds vs new builds
    By ee2k in forum Real Estate / Finance
    Latest Threads: 08-22-2015, 11:21 PM
  2. land yacht by my house? lots of them.
    By Fly Fishin' in forum General Car/Bike Talk
    Latest Threads: 02-27-2015, 10:15 AM
  3. FS: 1961 Land Rover S2 *SOLD*
    By DeathBy240 in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 03-27-2012, 04:29 PM
  4. 1961 pontiac catalina 8 door limo
    By big A in forum General Car/Bike Talk
    Latest Threads: 07-24-2007, 09:22 PM
