My 15 year old German car has 250,000 km. Is it reliable or unreliable?
Until you start it and drive it, it is neither. It's Schrodinger's BMW.This quote is hidden because you are ignoring this member. Show Quote
This quote is hidden because you are ignoring this member. Show Quote![]()
When is OP picking up his A4?
Nah my BMW is 18 years old and only has 170,000 kmThis quote is hidden because you are ignoring this member. Show Quote
I'm going to this weekend to test drive the A4 and A3. If I can find a 2015 ish bmw 335 I will test drive that tooThis quote is hidden because you are ignoring this member. Show Quote
Mine n54 is 16 years old with 220k on it.....maintain them and they'll last.This quote is hidden because you are ignoring this member. Show Quote
I strongly suggest you don't waste your time. Better feel and a bit more reliable, 2011 335, even better reliability and newer, bit more expensive, 2015. Don't even look at the audi man.This quote is hidden because you are ignoring this member. Show Quote
I actually prefer the 2014 to 2017( or whatever was the first year with the new steering wheel) 335 in both looks an performance but keep hearing mixed feelings on the N55.This quote is hidden because you are ignoring this member. Show Quote
The N55 is one of the best they've had, the b58 is just better from everything I've been reading, but no experience with them.This quote is hidden because you are ignoring this member. Show Quote
N55 is good, B58 is better. N54 is hard on the wallet but can make 550hp if you want it to.
B58 is materially faster stock vs stock with N55 as well.
Yea but can you get one in an Audi?
N55 it is, fck the Audi idea
Did VAG ever develop a thermostat housing and water pump for the EA888 that doesn't leak? It was an epidemic when I owned my MK7 Golf R as it was a matter of when not if. Fortunately I would periodically check and found sweating prior to having a big leak which was a good thing seeing at the time thermostat housings were on national backorder and I had to wait almost two months to get it fixed.
I think they were too busy putting screens in front of their turbosThis quote is hidden because you are ignoring this member. Show Quote
Nope.This quote is hidden because you are ignoring this member. Show Quote
Ftfy. And the answer is no.This quote is hidden because you are ignoring this member. Show Quote
Same comment for timing chain tensioners/guides.
Did BMW ever fix its fuel pump issues? Can't remember offhand what model/yr that was so problematic with
That was the N54 cars more than others, IIRC.This quote is hidden because you are ignoring this member. Show Quote
That was two engine generations ago and yes fixed on later engines.This quote is hidden because you are ignoring this member. Show Quote
