Putting this here to get more exposure. Lost all motivation to work on my car since I realized its a money pit. These are all top shelf parts at solid prices.
for 95-99 DSMs...
Ground Control coilovers ($300 brand new)
Koni Yellow adjustable struts ($500 brand new)
Ingalls Front Camber Kit ($50 brand new)
for 5x114.3 bolt pattern cars...
Axis Seven MOD 18" rims
Yokohama Parada Spec 2s 225/40ZR18 only have about four months driving on them
($1500)
for 420A engined cars...
Hahn Racecraft turbo manifold (flanged for a T3) ($200)
universal parts...
Garrett internal wastegate actuator (17psi I think) (comes with turbo)
Vortech 12:1 FMU ($50)
Two 3" stainless steel U-J bends ($110 for both)
One 2.25" mild steel U bend ($10)
the standalone... will work on any 420A motor, any 4G63 with one mod, and any car with a couple mods
Megasquirt and Spark with board mods:
- modified to read 420A stock hall effect sensor
- modified with VB921 modules to control ignition without external module
- includes 10' wiring harness with connector
- includes the cable to hook it up to your laptop
- includes all the software you need to use it
$500
the REALLY BIG turbo...
Holset HE351 (late model) HY35 includes electronic boost controller that can be controlled by the megasquirt, basically on par with those $300+ boost controllers but for far far less. Flows enough for 550whp, standard T3 flange, gigantic internal wastegate, and it still spools by 3300rpm on a 2 liter. On par with a GT35R only not ball bearing.
$500 only 3,000 miles
4" v-band clamp for the turbo $15
4" inlet elbow and K&N filter for the turbo $50
universal low impedance injectors...
Accel 625cc injectors one of them doesn't seem to work $200
the really big sidemount...
MkIV Supra Sidemount Intercooler ($200)
5 speed swap parts for non-turbo Eagle Talon/Mitsu Eclipse 95-99, Dodge Avenger 2.0 liter
All parts for 5 speed transmission swap except for the clutch and transmission ($200)
