Hey, has anyone ever used an engine stand on their B16. How do you mount it on the stand?
the same way any engine mounts on any engine stand....
Originally posted by rage2
Never mounted one before:
Where to attach the brackets from the stand?
Can I mount it with the Transmission still attached?
take the tranny off, get some bolts that are the same size as the tranny bolts and mount it....Originally posted by freeeked
Thanks muchly. For hoisting I see there is a bolt hole on the back of the head on the timing belt side. And the clutch cable bracket. Is this correct?
Dude if you are putting this motor on a stand to rebuild it yet are havin difficulties even mounting the motor to the stand I might think twice about doing your own rebuild. At least get someone around who knows more at anyrate.
Lookin Good is Goin FAST
"HOME of the AWD DYNO"
I agree,Originally posted by Dr. Lightspeed
At this time I am only tackling the swap not the rebuild (need time to learn). Just taking a B16 out of a wrecked CRX and putting it it mine. I just need a place to put the engine while I take the old one out. I wasn't sure if I could mount it on the stand with the Tranny (engine stand documentation sucked). I have my answer so I will sitck it on a crate or a dolly before I drop it in my car.
I got the helms and Beyond to help me with the technical stuff.
