buying a block with a spun rod bearing - Beyond.ca - Car Forums
Results 1 to 5 of 5
Thread: buying a block with a spun rod bearing
    The depths of despair!
    Anything topless.
    Default buying a block with a spun rod bearing
    so is it advisable to buy a block that has had a spun rod bearing? It's basically a bare block and the plans are to have it sleeved with after market pistons and rods...and bearings of course!! haha, but what things should be taken into consideration?
    Also, what will be needed to be transferred over, crank, oil pump, etc.
    And if you don't know, don't bother answering!
    WTF!! I am a moderator!!
    It's fine, as long as you're sleeving it. Rod bearing damage, depending on how extensive, contaminates oil and scores the cylinder walls. Since you're sleeving, it's not a problem.
    Jun 2003
    YWG
    in the chevy small block world you can just machine the block and buy oversized bearings
    calgary alberta
    Ill sell you my jacked up 350 if the price is right....whats 400HP worth to you?
    Apr 2003
    Red Deer, Alberta
    Really FAST Ones
    I would definately get it align honed and make shure it didn't do hard parts damage to the bearing set holders.
    Lookin Good is Goin FAST
    "HOME of the AWD DYNO"
  1. FS: 90-96 300zx NA 5lug Front Hubs/Bearing/Spindles. & brakes
    By SpoonEK9@STRD in forum Automotive Parts
    Latest Threads: 01-21-2004, 06:36 PM
  2. Wheel bearing
    By redline_13000 in forum Mechanical
    Latest Threads: 11-24-2003, 06:08 PM
  3. Removing a tie rod
    By 5gluder in forum Mechanical
    Latest Threads: 03-27-2003, 02:55 PM
  4. Major Power Civic in Hot Rod Mag.
    By hjr in forum General Car/Bike Talk
    Latest Threads: 03-02-2003, 11:02 PM
  5. Steering tie rod....
    By RiceCake in forum Mechanical
    Latest Threads: 11-27-2002, 01:57 PM
