Originally posted by SilverRex
the only thing that it has is that it has output main A and out put main B.
not sure if that is the same thing if I simply hook up all 4 main output into two speakers.
That's for multi-room setups or running an extra set of speakers. When you enable both A & B at the same time, you will effectively half the power output to each as the amp will double the impedance of it's outputs to compensate for the extra power demand.
