1955 Buick with a Hemi - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 44
Thread: 1955 Buick with a Hemi
    Soon to drive a 1955 Buick, then a 1929 Willys
    Default 1955 Buick with a Hemi
    I am in progress of building a 1955 Buick Special with a Gen 3 5.7 Hemi, and air ride suspension. I am from the Calgary area and have posted here a little bit before. I am trying out making YouTube videos of showing the progress and the work that goes into it. I have a intro video where I tell you about the history of this car and the changes up to Dec 2020, then I started making individual videos for the little project I do along the way. Here is a link to the playlist for this Buick. I will be uploading a new video every week so subscribe if you find them interesting!
    https://youtu.be/7-2gVWtqmyM
    Neat and unique car.
    Thanks man! Also thanks to the mod for putting this in the right area.
    Aug 2019
    Ram truck and some bikes
    Cool car. Tough deal on the rear axle. At least it worked.
    Interested to see this with a boat behind it.
    Quote Originally Posted by Andy643 View Post
    With good disc brakes on all corners, 350hp, and good trailer brakes I think it will handle a 5k lb boat pretty well. I was doing some reverse engineering on other newer cars and I think I have enough vehicle weight to keep everything under control.
    Here is the build thread for the car I worked on before this Buick, a 1929 Willys I build from ground up! It was alot of fun to make!
    https://youtu.be/rlbSYqdBxxU
    I also finished the video for the air ride suspension setup. The car has around 7" of air ride travel.
    https://youtu.be/IAkCiGkTtkY
    I did a few more little jobs while waiting for some parts. Worked on beautifying the parts you will pretty much never see because that seemed like a good use of time! It was a lot of work so I drafted in a helper. Let me know if you liked the paint schemes!
    https://youtu.be/bATIVeVvgAg
    https://youtu.be/NUMJf9A3sWo
    Aug 2019
    Looking good. That oil pan seemed like a ton of effort went into it.
    For something that no one will ever see it was a ton of work..... Those are the type of thankless jobs that go into building a car cheaply though I think.
    Sep 2008
    NE
    Ram 1500, '68 Camaro, S14
    Cool build man!
    Somehow in the past 50+ years the fuel filler assembly from the car vanished. I have tried searching for a stock replacement with no luck. I decided to make my own using a generic fuel filler assembly from Amazon, some mandrel bend 2". pipe, and a whole lot of cutting and welding. I am happy with the result other than I need to replace the silicone orange coupler from the tank to the first hard line since silicone isn't fuel rated. I have a rubber piece on the way and will install it before I fill it up for the first time.
    ​​​​​​​Here is the video!
    https://youtu.be/GECzLXq5tN0
    Oct 2011
    Lotus Land
    G37X
    Thank you for doing something different vs "LS with twin turbskis"
    LS with twins is almost too cheap, dependable and powerful now. I would rather waste my money on a engine that has less aftermarket options, worse components, lower redline etc...... I am not a smart man.
    A long time since the last update but I have made a fair bit of progress. Torque converter installed, Engine/Trans dropped in, and getting ready to start! Here is the video:
    https://youtu.be/THDH-fI0i68
    Aug 2019
    Lots of progress. Getting real close to have this running. cant wait to hear it.
    Sep 2008
    NE
    Quote Originally Posted by kberjian View Post
    haha! i thought your hoist was just kinda hooked on the block because the bolts were outta frame, that made my butt clench
    I did actually almost drop the engine, the equalizer/adjusting lifting bar I was using decided to spontaneously disassemble while I had the engine and trans in the air. It fell about 2' and then caught itself when the bent mess bound up again.
    Now the scary part, trying to manage the ECU and setup the tune correctly! I would appreciate anyone providing advice/feedback on this stuff!
    https://youtu.be/YjA6K_UHiBc
    Sep 2008
    NE
    look up Trevor Couture (TC Tuning) on facebook and let him do it, he'll send you a base tune then after you drive it for a bit he will fix it up! are you using a Term X?
    Good info, I will look him up. I am using the HP ECU.
  1. 1955 Sears Camera Catalogue
    By D'z Nutz in forum Photographer's Corner
    Latest Threads: 03-28-2009, 12:36 AM
  2. Mafia Battle - 1955
    By Mixalot27 in forum Computers, Consoles, and other Electronics
    Latest Threads: 05-29-2007, 06:31 AM
  3. 1955 Mercedes-Benz 300SL Gllwing on eBay
    By /////AMG in forum General Car/Bike Talk
    Latest Threads: 11-22-2005, 06:21 PM
  4. Housekeeping Montly - May 1955 HAHahaa
    By Ekliptix in forum General
    Latest Threads: 09-07-2003, 09:24 AM
  5. FA: 1955 Ford Thunderbird
    By Colin_West in forum Automotive Parts
    Latest Threads: 04-29-2003, 03:12 AM
